How to setup System-Mails with E2E encryption at hosted NC?
    • 32.0.3
    • hosted without shell access
    • na
    • na
    • na
    • na
    • na
I am not able to encrypt system mails via PGP or s/mime
  1. login as an admin
  2. go to Basic settings
  3. populate the mail related things
Why I am looking for E2E mail encryption?
Cause system mails could include sensitive data ( like the password for external file shares ) and could traverse a lot of mailservers at different administrative domains.
As the NC, I am working on, is for something like health care and I classified it as critical, I deactivate the feature which sends a mail back to the invitator.
Running NC on-premise could be a solution to fix this but maybe there is an other solution?
kind regards
Thilo
I don’t think that is possible like this right now. If you want to encrypt all notifications, you would need to have all the public keys for the people you are notifying. Not sure, but usually passwords are not sent, you can reset your account but then you get a link to change the access.
You shouldn’t run that on hosted environments, there are too much things out of your control.
fully agree!
For this I found a workaround by disabling sending mails to the invitator.
But for the future I expect that I run in security critical situations where workarounds are not acceptable or not available.
I will collect some more experience with the hosted envionment and in parallel I will setup my self hosted environment.
just for clarification:
I don´t want to encrypt all notifications.
I only want to encrypt mails from nextcloud instance to the invitator ( only a few NC accounts ) nothing else.
You’d first need to implement that Nextcloud notifications can be encrypted, or in a first stage be signed. Then each user would need in his profile a field to put their public key, and then notifications could be sent encrypted as well.
For the mail app, they already included S/MIME support:
Check out if there are already feature requests at GitHub · Where software is built
