I would like to install fail2ban for my Nextcloud. However, I found out that in my case you have to install fail2ban on my apache2 reverse proxy server. When I did that it did not work. I have created a log file with the necessary permissions. Created a filter.d/nextcloud.conf with:
[Definition]
failregex=^{"reqId":".*","remoteAddr":".*","app":"core","message":"Login failed: '.*' \(Remote IP: '<HOST>'\)","level":2,"time":".*"}$
^{"reqId":".*","level":2,"time":".*","remoteAddr":".*","user,:".*","app":"no app in context".*","method":".*","message":"Login failed: '.*' \(Remote IP: '<HOST>'\)".*}$
^{"reqId":".*","level":2,"time":".*","remoteAddr":".*","user":".*","app":".*","method":".*","url":".*","message":"Login failed: .* \(Remote IP: <HOST>\).*}$
and a jail.d/nextcloud.local
[nextcloud]
backend = auto
enabled = true
port = 80,443
protocol = tcp
filter = nextcloud
maxretry = 3
bantime = 36000
findtime = 36000
logpath = /var/log/nextcloud.log
However, this does not work. What can I do
