example
longer
example
here
Nextcloud version (eg, 20.0.5): 21.0.1
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04
Apache or nginx version (eg, Apache 2.4.25): nginx 1.18.0
PHP version (eg, 7.4): 8.0
The issue you are facing: Cannot reverse proxy WebDAV url using nginx. I can get the common WebDAV url as https://example.com/remote.php/webdav
, but I want to make it shorter, using subdomains like https://dav.example.com
- Setup NextCloud as normal
- In
/etc/nginx/conf.d/dav.conf
, I wrote as follows:
server {
listen 443 ssl;
server_name dav.example.com;
ssl_certificate /etc/letsencrypt/live/example.com/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/example.com/privkey.pem;
location / {
proxy_set_header Host example.com;
proxy_pass https://example.com/remote.php/webdav;
- Access
using normal WebDAV client, and I get following file list:
- Folder 1
- Folder 2
- Folder 3
- webdav
- Even if I click any folder, I can’t see any contents of them.
'passwordsalt' => '****',
'secret' => '****',
0 => 'localhost',
1 => 'example.com',
'datadirectory' => '/usr/share/nginx/nextcloud/data',
'version' => '21.0.1.1',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextuser',
'dbpassword' => '****',
'instanceid' => '****',
'skeletondirectory' => '',
'overwrite.cli.url' => 'https://example.com',
192.168.1.1 - - [06/May/2021:18:39:25 +0900] "PROPFIND /remote.php/webdav/Private/ HTTP/2.0" 200 1281 "-" "Transmit/5.7.4"
192.168.1.1 - - [06/May/2021:18:39:25 +0900] "PROPFIND /remote.php/webdavremote.php/webdav/Private/ HTTP/1.0" 200 3306 "-" "Transmit/5.7.4"
From the nginx log, I think this issue is caused by infinite redirect of path, but I don’t know how to resolve it.
