How to prevent users from using specific apps (permission)
Hello NC community, I hope you are well.
Im using for example forms app in the NC so is there any way to prevent users from using it even seeing it ?
also another apps,
regards.
Hi @BinLaggin,
go to the appstore:
  • https://yourcloud.bar.baz/settings/apps
… and click on the forms app.
In the right side bar you will see this:
Hit the checkmark as in this image and choose a group (you can create a new group for that e.g. “forms_users”)
Other people now will not see that app anymore.
I hope this was what you where looking for.
Much and good luck,
ernolf
eww brother thaanks alot for your explaination
