example
longer
example
here
Nextcloud version (eg, 12.0.2):Latest from linuxserver
Operating system and version (eg, Ubuntu 17.04): Unraid
Apache or nginx version (eg, Apache 2.4.25): Latest Nginx from linuxserver
My issue is not a bug problem, I just can’t figure out how to make own cloud notice that I am on LAN. I followed Spaceinvader Ones tutorial and everything works fine. My only issue is next cloud will redirect me to use my domain name even if I am on my LAN. I know he sets it up like this, but after two hours of googling I can’t find a way around this. I could only find people with redirect problems.
More clearly. If I am outside of my home, when I enter ‘mydoamin.duckdns.org’, It works fine. But when I am home, and enter the lan_ip_for_unraid_server:NextCloudPort into my browser (or click on webGUI in docker menu) I get redirected to ‘mydoamin.duckdns.org’, with has a speed penalty(I tested). How would I make it use lan_ip_for_unraid_server:NextCloudPort when I am inside the same network.
0 => 'ip_for_unraid_server:444',
1 => 'mydoamin.duckdns.org',
'version' => '16.0.1.1',
'trusted_proxies' => ['letsencrypt'],
'overwritehost' => 'mydoamin.duckdns.org',
'overwrite.cli.url' => 'https://mydoamin.duckdns.org',
'dbname' => 'nextcloud',
