example
longer
example
here
Nextcloud version : 16.0.2
Operating system and version : 10.00
Apache or nginx version : Apache 2.4.38
PHP version : 7.3
I set the location for my data directory on a USB storage limited to 16 Go. I figured that this is not enough because I want to save all pictures from my iPhone.
So, I want to move the data directory to a new USB storage with 128 Go.
How can i change that?
I use Nextcloud on a Raspberry Pi.
Thanks in advance.
