How to monitor the progress of trashbin restore
    • 31.0.0 (kubernetes)
    • Truenas 23.10.2
    • na
    • replace me
    • Yes
    • very recent
    • Truenas App
The Shell that is executing a trashbin:restore went into the background and now I can’t see if it is doing the restore
Opened the Nextcloud App on Truenas GUI
Opened the Nextcloud App Containers sh terminal
using www-data I executed the cmd “occ trashbin:restore --all-users”
it started restoring the files.
later I returned to that terminal in the GUI and the process had gone into the background.
Now I can’t see if the restore is happening or if it has frozen or waiting a prompt.
  1. How do I get the terminal to the foregound so I can see the files being restored?
  2. Is there a log I can tail -f to see the progress?
  3. Can I cancel the restore and restart it and keep it in the foreground.
Excellent question - I don’t know where to look for them.
As soon as I find the logs I'll put them here
n/a
n/a
        "htaccess.RewriteBase": "\/",
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "redis": {
            "port": 6379
        "upgrade.disable-web": true,
            "localhost",
            "192.168.1.101",
            "127.0.0.1",
            "localhost",
            "nextcloud-init-sync.lock",
            "nextcloud"
        "dbtype": "pgsql",
        "version": "31.0.0.18",
        "overwrite.cli.url": "http:\/\/localhost",
        "dbport": "",
        "overwritehost": "192.168.1.101:9001",
        "overwriteprotocol": "https",
        "twofactor_enforced": "false",
        "twofactor_enforced_groups": [],
        "loglevel": 2
  • activity: 4.0.0
  • app_api: 5.0.2
  • bruteforcesettings: 4.0.0
  • circles: 31.0.0-dev.0
  • comments: 1.21.0
  • contactsinteraction: 1.12.0
  • dashboard: 7.11.0
  • dav: 1.33.0
  • federation: 1.21.0
  • files: 2.3.1
  • files_downloadlimit: 4.0.0
  • files_pdfviewer: 4.0.0
  • files_reminders: 1.4.0
  • files_sharing: 1.23.1
  • files_trashbin: 1.21.0
  • files_versions: 1.24.0
  • firstrunwizard: 4.0.0
  • logreader: 4.0.0
  • notifications: 4.0.0
  • oauth2: 1.19.1
  • password_policy: 3.0.0
  • photos: 4.0.0-dev.1
  • privacy: 3.0.0
  • profile: 1.0.0
  • provisioning_api: 1.21.0
  • recommendations: 4.0.0
  • related_resources: 2.0.0
  • serverinfo: 3.0.0
  • settings: 1.14.0
  • sharebymail: 1.21.0
  • support: 3.0.0
  • survey_client: 3.0.0
  • systemtags: 1.21.1
  • text: 5.0.0
  • theming: 2.6.1
  • updatenotification: 1.21.0
  • user_status: 1.11.0
  • viewer: 4.0.0
  • weather_status: 1.11.0
  • webhook_listeners: 1.2.0
  • workflowengine: 2.13.0
  • admin_audit: 1.21.0
  • encryption: 2.19.0
  • files_external: 1.23.0
  • suspicious_login: 9.0.1
  • user_ldap: 1.22.0
