Ref. Howto: Use serverinfo with curl
Thanks to @Stefan.H for the wiki entry.
I am using Uptime Kuma, an open-source monitoring tool, and I am struggling to understand how to tweak the JSON query. Can somebody please point me in the right direction?
I can call the endpoint OK from the command line:
curl -H 'NC-Token: <mytoken> ' -X GET https://<mynextcloud>/ocs/v2.php/apps/serverinfo/api/v1/info?format=json
{"ocs":{"meta":{"status":"ok","statuscode":200,"message":"OK"},"data":{"nextcloud":{...
My Uptime Kuma config looks like this:
What do I need to change the JSON query and expected value to?
