I have been spending days on Google and a few forums without an answer to my questionā¦
How can I make wifi work with NextcloudPi 1.55.3 on Raspberry Pi 5?
I have tried turning wifi on with wpa_supplicant.conf but that didnāt help.
I have tried using sudo -i raspi-config but then when I get to confirm my Wifi settings I get an error message stating:
And also I can see the following error message that disappears really quick when I get the s1 wireless plan error message :
File ā/usr/share/netplan/netplan/libnetplan.pyā, line 79, in _checked_lib_call raise LibNetplanException(err.contents.message.decode(āutf-8ā)) netplan.libnetplan.LibNetplanException: Error parsing YAML: did not find expected ā,ā or ā)ā
I know that the Wifi works if I setup Nextcloud manually using Raspberry Pi Manager SD card flasher tool. But I would rather use NextcloudPi for its simplicity.
How can I make my RaspberryPi 5 NextcloudPi connect to Wifi?
To get Wi-Fi working on NextcloudPi 1.55.3 with your Raspberry Pi 5, start by checking your wpa_supplicant.conf for correct formattingāensure there are no syntax issues or extra characters. Verify your netplan configuration in /etc/netplan to confirm itās properly formatted and matches your Wi-Fi interface. Restart network services and try running raspi-config again to set up Wi-Fi. If errors persist, use nmcli for manual Wi-Fi connection testing to rule out hardware issues. Lastly, update your system to the latest packages. If all else fails, re-image your SD card and set up Wi-Fi during initial configuration.
Yeah I tried that also before posting here but all I am getting is command not found (as seen HERE. From my understanding if like others on the web you suggest that command then it is expected to work as is. Therefore why is my download (NextcloudPi_RaspberryPi5_v1.55.3.zip) from Releases Ā· nextcloud/nextcloudpi Ā· GitHub misses that script/program? And what do I have to do to get it on there?
Ok, I will triple check (I double checked before posting) wpa_supplicant.conf for correct formatting and all and come back to report. I will investigate the netplan configuration thing too. That I havenāt looked into yet. Note that thereās nowhere to setup wifi in the GUI after balenaEtcher flashing NextcloudPi_RaspberryPi5_v1.55.3.zip.
UPDATE: HERE it is saying wpa_supplicant is no longer used or relevant on Raspberry Pi 5.
UPDATE 3: Considering NMCLIP is related to NetworkManager my guess is that I need to figure out how to get NMCLIP working first. Any suggestion? I have dug around but I think I will need a bit more help here. Note that I know the wireless interface (wlan0) is in fact not defective as I am actually able to connect through wifi if I use Raspberry Pi Imager instead
of the NextcloudPi_RaspberryPi5_v1.55.3.zip (but as I previously said I actually want to use the NextCloudPi package and not a Nextcoud setup all on my own). I have looked into /etc/netplan and found a 10-dhcp-all-interfaces.yaml file but looking at the renderer value networking is managed through networkd instead of NetworkManager. I have balenaEtcher flashed multiple times and I am starting to believe that thereās something not quite right in the wifi department of Raspberry Pi 5ā NetcloudPi 1.55.3 image.
I canāt believe what Iām seeing here
That is not the login screen I would expect from an armbian based ncp,
Did you do an update/upgrade after setting up your instance?
Said aside, I prefer rpi-imager no presets to write the image.
Activate ncp, activate ssh,
Okā¦ I didnāt customize much yet (my setup is very close to vanilla) because I figured thereās no point wasting time customizing stuff when I canāt get the basics (more specifically the wifi) going considering that I am in the process of going through multiple flashes through trial and errors.
So I guess NextcloudPi isnāt really all that great after all.
Come on, give it another shot, do it with an image written with rpi-imager.
I just started up an pi5 with an ncp 1.55.2 image and will take a look on wifi.
Never thougt of setting up server with wifi. But first letās do an update.
Will try Raspberry Pi Imager WITH NextcloudPi_RaspberryPi5_v1.55.3.imgā¦ I was not aware that it was possible to use both together. I used BalenaEtcher as seen HERE
secure and steady is important, an server never sleeps.
Yes, but everything has 2 sides. Nextcloud is not the easiest home-server project. NextcloudPI is a nice attempt to get the user starting this thing, believe me, I started bare metal, that was to much fun, there is a life beneath. ncp is nice but the update-policy of nextcloud keep all busy, and the ncp maintainer Tobias and friends do a great job.
NextcloudPi v1.55.2 is outdated
update to v1.55.3 through āncp-configā or type āsudo ncp-updateā
Performance:
Load: 2% Up time: 17 min
Memory usage: 5% of 7.75G
CPU temp: 49Ā°C Usage of /: 19% of 29G
Commands:
Configuration : armbian-config
Monitoring : htop
Last login: Mon Dec 2 09:09:31 2024 from 192.168.2.20
pi@ncpi5:~$
Now ncp update.
Running nc-update-nextcloud
Running as unit: ncp-update-nc.service
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 810k 0 810k 0 0 878k 0 --:ā:-- --:ā:-- --:ā:-- 877k
Current Nextcloud version 29.0.8
Requested Nextcloud version latest
Selected Nextcloud version 29.0.9
INFO: You have requested an update to the latest available version that can be performed directly, which is ā29.0.9ā. Updates can only performed to the next major version (or the latest minor version of the current major version). If you run ncp-update-nc again after this update completes, a new version might be available.
Download Nextcloud 29.0.9ā¦
Error downloading
Clean upā¦
Nextcloud update failed (or was installed already).
Done. Press any keyā¦
Oh, we got trubble.
But we know, 29.0.9 was ceased, this thursday new relewases come to download, we wait. Now lets check wifi.
Oh, things get difficult. in the armbian-based ncp seems to be a firmware/kernel thing with wifi-chip.
As workaround: check with wifi-dongle.
My findings so far 2024-12-02 armbian based ncp images donāt work with wifi on rpi4/rpi5, it seems a firmware/kernel thing which now is at this time to much for me to do further investigatins.
Conclusion: My instance on a rpi400 has working wifi because it was set up with a version before introducing armbian, an test instance on rpi4 after introducing armbian has no wifi support. So I assume if wifi ist a must, ncp is not the choice at this time. I only have little experience in other setups, I started with Jay LaCroix on LLTV on youtube, nice explanation I run this instance for about 3 month, because I wanted check ncp I switched.
pi@ncpi5:~$ sudo ncp-config
Running nc-info
Gathering informationā¦
NextcloudPi version v1.55.3
NextcloudPi image
OS Armbian 24.11.2 bookworm \l . 6.6.63-current-bcm2712 (aarch64)
automount yes
USB devices none
datadir /opt/ncdata/data
data in SD yes
data filesystem ext2/ext3
data disk usage 5,2G/29G
rootfs usage 5,2G/29G
swapfile /var/swap
dbdir /var/lib/mysql
Nextcloud check ok
Nextcloud version 29.0.8.1
HTTPD service up
PHP service up
MariaDB service up
Redis service up
HPB service up
Postfix service up
Internet check ok
Public IPv4 217.X
Public IPv6 2003:c8:6706:4c00:X
Port 80 closed
Port 443 closed
IP 192.168.2.51
Gateway 192.168.2.1
Interface end0
Certificates none
NAT loopback no
Uptime 27min
On my RPi4 with NextcloudPi OS āArmbian 24.11.2 bookworm \l . 6.6.63-current-bcm2711 (aarch64)ā I got the internal WiFi card working with the following:
Thank you for your writing, installing the right firmware here is the mandatory step, than networkctl is there to configure.
networkctl --help
networkctl [OPTIONSā¦] COMMAND
Query and control the networking subsystem.
Commands:
list [PATTERNā¦] List links
status [PATTERNā¦] Show link status
lldp [PATTERNā¦] Show LLDP neighbors
label Show current address label entries in the kernel
delete DEVICESā¦ Delete virtual netdevs
up DEVICESā¦ Bring devices up
down DEVICESā¦ Bring devices down
renew DEVICESā¦ Renew dynamic configurations
forcerenew DEVICESā¦ Trigger DHCP reconfiguration of all connected clients
reconfigure DEVICESā¦ Reconfigure interfaces
reload Reload .network and .netdev files
Options:
-h --help Show this help
āversion Show package version
āno-pager Do not pipe output into a pager
āno-legend Do not show the headers and footers
-a --all Show status for all links
-s --stats Show detailed link statistics
-l --full Do not ellipsize output
-n --lines=INTEGER Number of journal entries to show
ājson=pretty|short|off
Generate JSON output
check your new config sudo netplan try
if ok sudo netplan apply
should look like this sudo networkctl
IDX LINK TYPE OPERATIONAL SETUP
1 lo loopback carrier unmanaged
2 end0 ether routable configured
3 wlan0 wlan routable configured
check ip adress / dhcp
ip a
Based on the default metric 600 for wlan0 your lan access is preferred.
Disconnect lan cable or take down lan to check/use wlan0 - take care open session will be uselesse/closed sudo networkctl down end0
