Nextcloud 11.0.1 on Ubuntu 16.04, Nextant 1.0.3
According to the Nextant commands overview, this should be done by
./occ nextant:index --bookmarks
But in my case this does not work.
Here the output of the commands.
sudo -u www-data php occ nextant:index --bookmarks
nextant v1.0.3
* Indexing bookmarks:
/user1 0/ 0 [>---------------------------] 0%
/user1 2/ 2 [============================] 100%
/user3 20/ 20 [============================] 100%
/user4 1/ 1 [============================] 100%
0 bookmark(s) processed ; 0 orphan(s) removed
0 document indexed ; 0 fully extracted
Time spent: 00:00:02
Your index now contains 19 segments
As correctly displayed, user3 has 20 bookmarks
But they are neither indexed nor displayed on the search result page.
sudo -u www-data php occ nextant:check
Pinging 127.0.0.1:8983/solr/nextant : ok
Checking Solr schema fields
* Checking field-type 'boolean' : ok
* Checking field-type 'booleans' : ok
* Checking field-type 'double' : ok
* Checking field-type 'doubles' : ok
* Checking field-type 'tdouble' : ok
* Checking field-type 'tdoubles' : ok
* Checking field-type 'float' : ok
* Checking field-type 'floats' : ok
* Checking field-type 'tfloat' : ok
* Checking field-type 'tfloats' : ok
* Checking field-type 'int' : ok
* Checking field-type 'ints' : ok
* Checking field-type 'tint' : ok
* Checking field-type 'tints' : ok
* Checking field-type 'long' : ok
* Checking field-type 'longs' : ok
* Checking field-type 'tlong' : ok
* Checking field-type 'tlongs' : ok
* Checking field-type 'string' : ok
* Checking field-type 'strings' : ok
* Checking field-type 'tdate' : ok
* Checking field-type 'tdates' : ok
* Checking field-type 'ignored' : ok
* Checking field-type 'text_general' : ok
* Checking field-type 'text_general_edge' : ok
* Checking field-type 'text_general_word' : ok
* Checking field '_version_' : ok
* Checking field 'id' : ok
* Checking field 'text' : ok
* Checking field 'text_edge' : ok
* Checking field 'text_word' : ok
* Checking field 'nextant_path' : ok
* Checking field 'nextant_owner' : ok
* Checking field 'nextant_mtime' : ok
* Checking field 'nextant_share' : ok
* Checking field 'nextant_sharegroup' : ok
* Checking field 'nextant_deleted' : ok
* Checking field 'nextant_source' : ok
* Checking field 'nextant_tags' : ok
* Checking field 'nextant_extracted' : ok
* Checking field 'nextant_ocr' : ok
* Checking field 'nextant_unmounted' : ok
* Checking dynamic-field 'ignored_*' : ok
* Checking dynamic-field 'nextant_attr_*' : ok
* Checking copy-field 'text_edge/text' : ok
* Checking copy-field 'text_edge/text_word' : ok
Cleaning extra fields
Your solr contains 131 documents :
- 131 files
- 0 bookmarks
- 19 segments
0 bookmarks!
What is wrong there?
Thank you.
