Nextcloud version: 16.0.5snap3
Operating system and version: Ubuntu 18.04
Apache or nginx version: Apache 2.4.41
PHP version: 7.2.24
Hi, I moved my Nextcloud installation to Digital Ocean in order to use a DO space as primary storage. That went very well, I didn’t have any issues.
Previously I had some bash scripts running, which copy files from servers of the users to their Nextcloud-Storage via rsync
over ssh
. This was relatively easy, because I only had to copy those files to /var/snap/nextcloud/common/nextcloud/data/username/files/
and let Nextcloud rescan all files.
Apparently this is not an option with the object storage as primary storage anymore. The /data
directory stays always empty and I have no clue where this /tmp
folder would be and if it looks for new files anyways.
So how can I add files from the command line when I’m using object storage as main storage? I already tried WebDAV, but since it’s on the same server, that didn’t work. Is there another API for something like this? Or an option in the config files I’ve overlooked? Or maybe a hidden “import folder” which can be used for this case?
I would be glad if someone can help!
P.S. Sorry for my English - I’m not a native speaker.
