I’ve been using TrueNAS Core + NextCloud jail for a few years and with its up and downs, it’s been working more or less okay. However, I’m in the process of moving everything I can to docker so it’s host agnostic and I can change it as I please.
With that being said, I embarked on a quest to get Nextcloud to do one thing, its job! I’ve been tinkering for a few days testing different configurations, DB and installation methods and while this might have errors and won’t be perfect it’s the most rock solid I could get it so far, including syncing from web and clients (Windows and macOS)
What we’re going to use
- Proxmox as the main host OS
- A container inside Proxmox (they call it LXC)
- We will use docker + portainer
- We will use docker image
nextcloud:production-apache(avoidlatest, there are quite a few bugs on V25) - We will use docker image
postgres:14. Forget about MariaDB, I’m not even sure why it’s recommended. If I use it I just get tons of deadlocks, etc. 0 problems with Postgres so far - We will use nginx proxy manager to add HTTPS for public exposure
Attaching below my docker-compose files
version: '3'
services:
db:
image: postgres:14
restart: always
volumes:
- /root/docker/nextcloud/db:/var/lib/postgresql/data
env_file:
- stack.env
redis:
image: redis:alpine
restart: always
app:
image: nextcloud:production-apache
restart: always
ports:
- 8082:80
volumes:
- /root/docker/nextcloud/nextcloud:/var/www/html
- /mnt/ncdata/nextcloud_data:/var/www/html/data
environment:
- POSTGRES_HOST=db
- REDIS_HOST=redis
env_file:
- stack.env
depends_on:
- db
- redis
cron:
image: nextcloud:apache
restart: always
volumes:
entrypoint: /cron.sh
depends_on:
- db
- redis
stack.env file
POSTGRES_PASSWORD=nextcloud
POSTGRES_DB=nextcloud
POSTGRES_USER=nextcloud
As you can see I’m also using a specific folder for the data directory so I can access my TrueNAS ZFS storage but the rest of nextcloud runs on my Proxmox NVME SSD
From here you might want to install Nginx-proxy manager or any other reverse proxy of your liking. Here’s my docker-compose for it
version: '3'
services:
npm:
image: 'jc21/nginx-proxy-manager:latest'
restart: unless-stopped
ports:
- '80:80'
- '81:81'
- '443:443'
volumes:
- /root/docker/npm/data:/data
- /root/docker/npm/letsencrypt:/etc/letsencrypt
You will also want to take a look at Nextcloud’s docker repo
