I am trying to setup my local Nextcloud suite with a local collabora server using the fallowing docker-compose file:
version: '3'
services:
db:
image: mysql:8.0.32
command: --default-authentication-plugin=mysql_native_password
volumes:
- ./db:/var/lib/mysql
environment:
MYSQL_ROOT_PASSWORD: nextcloud
MYSQL_DATABASE: nextcloud
MYSQL_USER: nextcloud
MYSQL_PASSWORD: nextcloud
networks:
- nextcloud
app:
image: nextcloud:25.0.6
ports:
- 45080:80
depends_on:
- db
- collabora
volumes:
- ./nextcloud:/var/www/html
restart: always
networks:
- nextcloud
environment:
- NEXTCLOUD_TRUSTED_DOMAINS=cloud.nextcloud.com
collabora:
image: collabora/code
restart: unless-stopped
networks:
- nextcloud
ports:
- "9980:9980"
environment:
- domain=cloud\\.nextcloud\\.com
- "extra_params=--o:ssl.enable=false --o:ssl.termination=true"
tty: true
cap_add:
- MKNOD
networks:
nextcloud:
I’ve also setup with success the like to my local collabora server in nextcloud:
But for some reason I still can not open any document to edit online, in my test, I can not open the “Welcome to Nextcloud Hub.docx” of this local link http://0.0.0.0:45080/apps/files/?dir=/Documents&openfile=7
Could any of you tell me what exactly I am missing?
