How to enter nextcloud internally(nextcloud aio running behind nginx proxy manager)
Hello there,
I am new to all these self-hosted service and I am able to access nextcloud if I am accessing it through the domain and using external network, but how do access it internally? as I need to upload files to it using home network. if I enter the doamin when using the home network it will just point me to my router’s config page. I know it is kind of a dumb question, but could anyone help me out?
nextcloud aio is running using docker compose
version: “3.8”
volumes:
services:
nextcloud:
restart: always
volumes:
ports:
- 8080:8080
environment:
- APACHE_PORT=11000
- NEXTCLOUD_UPLOAD_LIMIT=100G
- NEXTCLOUD_MEMORY_LIMIT=4096M
- SKIP_DOMAIN_VALIDATION=true
thanks a lot
hello @bickyxd welcome to the forum :handshake:
Please use the search - lot of issues have been discussed already.
While it’s possible technically there lot of reasons not to use internal IP to access the system. Best approach is so-called split-brain DNS as described here: Lost acces from inside LAN - #14 by wwe and how-can-i-access-nextcloud-locally
