How to display appointments older than 3 months on mobiles?
I have a problem where past events in my Nextcloud Calendar on my smartphones are only displayed for up to about 3 months in the past. After that, they are no longer visible. Only recurring events are displayed. Fortunately, everything is still there in the web app.
I have already combed through all the settings of the calendar apps and the DAVx5 app on my smartphone, but I haven’t found anything.
How can I display individual appointments that are older than 3 months on my smartphones? Does anyone have any tips?
Unfortunately, I don’t have all the version numbers to hand. However, I suspect that this is a widespread issue, as it affects different smartphones with different update statuses. All of them use the CustomROM Lineage operating system. If the solution is not trivial, I will look up the version numbers and provide them.
Thank you for your help
What kind of mobile phone are you using, Android or iOS?
As far as I know, you can’t display only individual appointments, but you can adjust the time period for how far back past calendar appointments are displayed.
In DAVx5, click on the gear icon in the top right in your account, then scroll down to ā€œPast event time limitā€ and enter the desired number of days, or leave it blank for all events.
See also here: 5. Settings — DAVx⁵ documentation
Ah, thats it :slightly_smiling_face: Thank you very much!
