how to Configure system limits for NextCloudPi
Maximum file size
Memory limit
PHP threads
Redis memory
What meaning do these parameters represent, what impact will be caused after the modification, what is the value range, is it effective immediately after the modification? Still need to restart the container.
Which configuration file are these parameters in
[/details]
Nextcloud version 25.0.3.2
|NextcloudPi version|v1.51.0|
|NextcloudPi image|NextcloudPi_docker_01-22-23|
|OS|Debian GNU/Linux 11. 5.10.92-v8 (aarch64)|
Apache/2.4.56 (Debian)
PHP 8.1.14 (cli) (built: Jan 13 2023 10:38:02) (NTS)
System Info
‣ You should run Lets Encrypt for trusted encrypted access
‣ You should open your ports for Lets Encrypt and external access
NextcloudPi version | v1.51.0 |
NextcloudPi image | NextcloudPi_docker_01-22-23 |
OS | Debian GNU/Linux 11. 5.10.92-v8 (aarch64) |
automount | no |
USB devices | none |
datadir | /data/ncdata/data |
data in SD | yes |
data filesystem | ext2/ext3 |
data disk usage | 18G/27G |
rootfs usage | 18G/27G |
swapfile | none |
dbdir | /data/database |
Nextcloud check | ok |
Nextcloud version | 25.0.3.2 |
HTTPD service | up |
PHP service | up |
MariaDB service | up |
Redis service | up |
HPB service | up |
Postfix service | up |
Internet check | ok |
Public IPv4 | 123.126.82.8 |
Public IPv6 | not found |
Port 80 | closed |
Port 443 | closed |
IP | 172.17.0.7 |
Gateway | 172.17.0.1 |
Interface | eth0 |
Certificates | none |
NAT loopback | no |
Uptime | 2days |
