We require assistance in fixing the below error in Nextcloud. Please give a solution to fix the error
Maintenance mode
This nextcloud instance is currently in maintenance mode, which may take a while. This page will refresh itself when the instance is available again.
Contact your system administrator if this message persists or appeared unexpectedly.
Also, we would like to inquire about the paid support for our Nextcloud instance. Could you please provide information on how we can purchase paid support services to ensure the smooth functioning of our Nextcloud instance?
First you should check your log files to find-out why Nextcloud is not accessible anymore, because different reasons could force enabling of the Maintenance Mode, like e.g. a missing PHP module etc.
In general you can manually switch the maintenance mode by using the occ command line tool:
> ./occ maintenance:mode --help
Description:
set maintenance mode
Usage:
maintenance:mode [options]
Options:
--on enable maintenance mode
--off disable maintenance mode
-h, --help Display help for the given command. When no command is given display help for the list command
-q, --quiet Do not output any message
-V, --version Display this application version
--ansi|--no-ansi Force (or disable --no-ansi) ANSI output
-n, --no-interaction Do not ask any interactive question
--no-warnings Skip global warnings, show command output only
-v|vv|vvv, --verbose Increase the verbosity of messages: 1 for normal output, 2 for more verbose output and 3 for debug
Are you still on the lookout to hire someone to maintain your Nextcloud instance?
If so, I am open to providing personalized assistance to ensure the smooth functioning of your Nextcloud instance.
I generally provide priority troubleshooting, customized solutions, and ongoing maintenance to prevent future issues.
