How to best fix "WebP exif parsing fails due to bad composer autoload"-Error
This is my first time using Nextcloud for more than some testing and I just installed the latest version not much thinking about it. And it seems like version 33 has some kinks to work out.
My issue is mentioned in 500 error: WebP exif parsing fails due to bad composer autoload · Issue #3425 · nextcloud/photos · GitHub , but I’m not versed enough in how Nextcloud works yet. So I’m not able to figure out a temporary solution.
I would appreciate some help / guidance, so I can fix this locally, since it doesn’t seem like there is anybody working on this yet. At least nobody mentioned that in the Github issue.
    • 33.0.0
    • Linux 6.12.33-production+truenas x86_64
    • nginx/1.29.6
    • nginx-proxy-manager 1.3.3 (not relevant)
    • 8.4.18
    • Every time you upload a web
    • Docker (TrueNas package)
    • Yes
I have a library with some webp images, and every time I upload another one I’m getting this error - but no data is lost despite it saying the files can’t be synced. But the error’s are pretty annoying.
  1. Upload an webp image
  2. Get an error in the webui or desktop client that the upload failed, because of a server error (but upload is there)
The following log is copied from “no app in context”:
{"reqId":"Tu1dgD7brNl7ni3rKqNs","level":3,"time":"2026-03-21T09:42:04+00:00","remoteAddr":"172.16.8.6","user":"Agrarvolution","app":"no app in context","method":"PUT","url":"/remote.php/dav/files/Agrarvolution/Test/test.webp","scriptName":"/remote.php","message":"Uncaught exception","userAgent":"Mozilla/5.0 (Windows) mirall/4.0.8 (build 20260319) (Nextcloud, windows-10.0.26200 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"33.0.0.16","clientReqId":"d4778a93-6e5b-4fb8-9010-a1ff5a7171dc","exception":{"Exception":"Error","Message":"Class \"WoltLab\\WebpExif\\ChunkType\" not found","Code":0,"Trace":[{"file":"/var/www/html/apps/photos/lib/Listener/ExifMetadataProvider.php","line":180,"function":"decodeChunk","class":"WoltLab\\WebpExif\\Decoder","type":"->","args":[{"__class__":"Nelexa\\Buffer\\ResourceBuffer@anonymous\u0000/var/www/html/apps/photos/lib/Listener/ExifMetadataProvider.php:140$142"}]},{"file":"/var/www/html/apps/photos/lib/Listener/ExifMetadataProvider.php","line":82,"function":"getExifFromWebP","class":"OCA\\Photos\\Listener\\ExifMetadataProvider","type":"->","args":[null]},{"file":"/var/www/html/lib/private/EventDispatcher/ServiceEventListener.php","line":57,"function":"handle","class":"OCA\\Photos\\Listener\\ExifMetadataProvider","type":"->","args":[{"__class__":"OCP\\FilesMetadata\\Event\\MetadataLiveEvent"}]},{"file":"/var/www/html/3rdparty/symfony/event-dispatcher/EventDispatcher.php","line":220,"function":"__invoke","class":"OC\\EventDispatcher\\ServiceEventListener","type":"->","args":[{"__class__":"OCP\\FilesMetadata\\Event\\MetadataLiveEvent"},"OCP\\FilesMetadata\\Event\\MetadataLiveEvent",{"__class__":"Symfony\\Component\\EventDispatcher\\EventDispatcher"}]},{"file":"/var/www/html/3rdparty/symfony/event-dispatcher/EventDispatcher.php","line":56,"function":"callListeners","class":"Symfony\\Component\\EventDispatcher\\EventDispatcher","type":"->","args":[[{"__class__":"Closure"},{"__class__":"Closure"},{"__class__":"Closure"},{"__class__":"Closure"},{"__class__":"Closure"}],"OCP\\FilesMetadata\\Event\\MetadataLiveEvent",{"__class__":"OCP\\FilesMetadata\\Event\\MetadataLiveEvent"}]},{"file":"/var/www/html/lib/private/EventDispatcher/EventDispatcher.php","line":67,"function":"dispatch","class":"Symfony\\Component\\EventDispatcher\\EventDispatcher","type":"->","args":[{"__class__":"OCP\\FilesMetadata\\Event\\MetadataLiveEvent"},"OCP\\FilesMetadata\\Event\\MetadataLiveEvent"]},{"file":"/var/www/html/lib/private/EventDispatcher/EventDispatcher.php","line":79,"function":"dispatch","class":"OC\\EventDispatcher\\EventDispatcher","type":"->","args":["OCP\\FilesMetadata\\Event\\MetadataLiveEvent",{"__class__":"OCP\\FilesMetadata\\Event\\MetadataLiveEvent"}]},{"file":"/var/www/html/lib/private/FilesMetadata/FilesMetadataManager.php","line":100,"function":"dispatchTyped","class":"OC\\EventDispatcher\\EventDispatcher","type":"->","args":[{"__class__":"OCP\\FilesMetadata\\Event\\MetadataLiveEvent"}]},{"file":"/var/www/html/lib/private/FilesMetadata/Listener/MetadataUpdate.php","line":42,"function":"refreshMetadata","class":"OC\\FilesMetadata\\FilesMetadataManager","type":"->","args":[{"__class__":"OC\\Files\\Node\\File"}]},{"file":"/var/www/html/lib/private/EventDispatcher/ServiceEventListener.php","line":57,"function":"handle","class":"OC\\FilesMetadata\\Listener\\MetadataUpdate","type":"->","args":[{"__class__":"OCP\\Files\\Events\\Node\\NodeWrittenEvent"}]},{"file":"/var/www/html/3rdparty/symfony/event-dispatcher/EventDispatcher.php","line":220,"function":"__invoke","class":"OC\\EventDispatcher\\ServiceEventListener","type":"->","args":[{"__class__":"OCP\\Files\\Events\\Node\\NodeWrittenEvent"},"OCP\\Files\\Events\\Node\\NodeWrittenEvent",{"__class__":"Symfony\\Component\\EventDispatcher\\EventDispatcher"}]},{"file":"/var/www/html/3rdparty/symfony/event-dispatcher/EventDispatcher.php","line":56,"function":"callListeners","class":"Symfony\\Component\\EventDispatcher\\EventDispatcher","type":"->","args":[[{"__class__":"Closure"},{"__class__":"Closure"},{"__class__":"Closure"},{"__class__":"Closure"},{"__class__":"Closure"},"And 2 more entries, set log level to debug to see all entries"],"OCP\\Files\\Events\\Node\\NodeWrittenEvent",{"__class__":"OCP\\Files\\Events\\Node\\NodeWrittenEvent"}]},{"file":"/var/www/html/lib/private/EventDispatcher/EventDispatcher.php","line":67,"function":"dispatch","class":"Symfony\\Component\\EventDispatcher\\EventDispatcher","type":"->","args":[{"__class__":"OCP\\Files\\Events\\Node\\NodeWrittenEvent"},"OCP\\Files\\Events\\Node\\NodeWrittenEvent"]},{"file":"/var/www/html/lib/private/EventDispatcher/EventDispatcher.php","line":79,"function":"dispatch","class":"OC\\EventDispatcher\\EventDispatcher","type":"->","args":["OCP\\Files\\Events\\Node\\NodeWrittenEvent",{"__class__":"OCP\\Files\\Events\\Node\\NodeWrittenEvent"}]},{"file":"/var/www/html/lib/private/Files/Node/HookConnector.php","line":83,"function":"dispatchTyped","class":"OC\\EventDispatcher\\EventDispatcher","type":"->","args":[{"__class__":"OCP\\Files\\Events\\Node\\NodeWrittenEvent"}]},{"file":"/var/www/html/lib/private/legacy/OC_Hook.php","line":85,"function":"postWrite","class":"OC\\Files\\Node\\HookConnector","type":"->","args":[{"path":"/Test/test.webp"}]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/File.php","line":443,"function":"emit","class":"OC_Hook","type":"::","args":["OC_Filesystem","post_write",{"path":"Test/test.webp"}]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/File.php","line":363,"function":"emitPostHooks","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->","args":[false]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Directory.php","line":126,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":1098,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":504,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->","args":["method:PUT",[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Server.php","line":212,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/apps/dav/lib/Server.php","line":427,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->","args":[]},{"file":"/var/www/html/apps/dav/appinfo/v2/remote.php","line":25,"function":"exec","class":"OCA\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/remote.php","line":151,"args":["/var/www/html/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/html/apps/photos/vendor/woltlab/webp-exif/src/Decoder.php","Line":96,"message":"Uncaught exception","exception":"{\"class\":\"Error\",\"message\":\"Class \\\"WoltLab\\WebpExif\\ChunkType\\\" not found\",\"code\":0,\"file\":\"/var/www/html/apps/photos/vendor/woltlab/webp-exif/src/Decoder.php:96\",\"trace\":\"#0 /var/www/html/apps/photos/lib/Listener/ExifMetadataProvider.php(180): WoltLab\\WebpExif\\Decoder->decodeChunk(Object(Nelexa\\Buffer\\ResourceBuffer@anonymous))\\n#1 /var/www/html/apps/photos/lib/Listener/ExifMetadataProvider.php(82): OCA\\Photos\\Listener\\ExifMetadataProvider->getExifFromWebP(Resource id #176)\\n#2 /var/www/html/lib/private/EventDispatcher/ServiceEventListener.php(57): OCA\\Photos\\Listener\\ExifMetadataProvider->handle(Object(OCP\\FilesMetadata\\Event\\MetadataLiveEvent))\\n#3 /var/www/html/3rdparty/symfony/event-dispatcher/EventDispatcher.php(220): OC\\EventDispatcher\\ServiceEventListener->__invoke(Object(OCP\\FilesMetadata\\Event\\MetadataLiveEvent), 'OCP\\\\FilesMetada...', Object(Symfony\\Component\\EventDispatcher\\EventDispatcher))\\n#4 /var/www/html/3rdparty/symfony/event-dispatcher/EventDispatcher.php(56): Symfony\\Component\\EventDispatcher\\EventDispatcher->callListeners(Array, 'OCP\\\\FilesMetada...', Object(OCP\\FilesMetadata\\Event\\MetadataLiveEvent))\\n#5 /var/www/html/lib/private/EventDispatcher/EventDispatcher.php(67): Symfony\\Component\\EventDispatcher\\EventDispatcher->dispatch(Object(OCP\\FilesMetadata\\Event\\MetadataLiveEvent), 'OCP\\\\FilesMetada...')\\n#6 /var/www/html/lib/private/EventDispatcher/EventDispatcher.php(79): OC\\EventDispatcher\\EventDispatcher->dispatch('OCP\\\\FilesMetada...', Object(OCP\\FilesMetadata\\Event\\MetadataLiveEvent))\\n#7 /var/www/html/lib/private/FilesMetadata/FilesMetadataManager.php(100): OC\\EventDispatcher\\EventDispatcher->dispatchTyped(Object(OCP\\FilesMetadata\\Event\\MetadataLiveEvent))\\n#8 /var/www/html/lib/private/FilesMetadata/Listener/MetadataUpdate.php(42): OC\\FilesMetadata\\FilesMetadataManager->refreshMetadata(Object(OC\\Files\\Node\\File))\\n#9 /var/www/html/lib/private/EventDispatcher/ServiceEventListener.php(57): OC\\FilesMetadata\\Listener\\MetadataUpdate->handle(Object(OCP\\Files\\Events\\Node\\NodeWrittenEvent))\\n#10 /var/www/html/3rdparty/symfony/event-dispatcher/EventDispatcher.php(220): OC\\EventDispatcher\\ServiceEventListener->__invoke(Object(OCP\\Files\\Events\\Node\\NodeWrittenEvent), 'OCP\\\\Files\\\\Event...', Object(Symfony\\Component\\EventDispatcher\\EventDispatcher))\\n#11 /var/www/html/3rdparty/symfony/event-dispatcher/EventDispatcher.php(56): Symfony\\Component\\EventDispatcher\\EventDispatcher->callListeners(Array, 'OCP\\\\Files\\\\Event...', Object(OCP\\Files\\Events\\Node\\NodeWrittenEvent))\\n#12 /var/www/html/lib/private/EventDispatcher/EventDispatcher.php(67): Symfony\\Component\\EventDispatcher\\EventDispatcher->dispatch(Object(OCP\\Files\\Events\\Node\\NodeWrittenEvent), 'OCP\\\\Files\\\\Event...')\\n#13 /var/www/html/lib/private/EventDispatcher/EventDispatcher.php(79): OC\\EventDispatcher\\EventDispatcher->dispatch('OCP\\\\Files\\\\Event...', Object(OCP\\Files\\Events\\Node\\NodeWrittenEvent))\\n#14 /var/www/html/lib/private/Files/Node/HookConnector.php(83): OC\\EventDispatcher\\EventDispatcher->dispatchTyped(Object(OCP\\Files\\Events\\Node\\NodeWrittenEvent))\\n#15 /var/www/html/lib/private/legacy/OC_Hook.php(85): OC\\Files\\Node\\HookConnector->postWrite(Array)\\n#16 /var/www/html/apps/dav/lib/Connector/Sabre/File.php(443): OC_Hook::emit('OC_Filesystem', 'post_write', Array)\\n#17 /var/www/html/apps/dav/lib/Connector/Sabre/File.php(363): OCA\\DAV\\Connector\\Sabre\\File->emitPostHooks(false)\\n#18 /var/www/html/apps/dav/lib/Connector/Sabre/Directory.php(126): OCA\\DAV\\Connector\\Sabre\\File->put(Resource id #16)\\n#19 /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php(1098): OCA\\DAV\\Connector\\Sabre\\Directory->createFile('test.webp', Resource id #16)\\n#20 /var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php(504): Sabre\\DAV\\Server->createFile('files/Agrarvolu...', Resource id #16, NULL)\\n#21 /var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php(89): Sabre\\DAV\\CorePlugin->httpPut(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\\n#22 /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php(472): Sabre\\DAV\\Server->emit('method:PUT', Array)\\n#23 /var/www/html/apps/dav/lib/Connector/Sabre/Server.php(212): Sabre\\DAV\\Server->invokeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\\n#24 /var/www/html/apps/dav/lib/Server.php(427): OCA\\DAV\\Connector\\Sabre\\Server->start()\\n#25 /var/www/html/apps/dav/appinfo/v2/remote.php(25): OCA\\DAV\\Server->exec()\\n#26 /var/www/html/remote.php(151): require_once('/var/www/html/a...')\\n#27 {main}\"}","CustomMessage":"Uncaught exception"},"id":"69be6c0c6b2b6"}
        "htaccess.RewriteBase": "\/",
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "redis": {
            "port": 6379
        "upgrade.disable-web": true,
        "dbtype": "pgsql",
        "version": "33.0.0.16",
        "default_phone_region": "DE",
        "overwrite.cli.url": "http:\/\/localhost",
        "serverid": "1",
        "app_install_overwrite": [
            "memories"
        "memories.exiftool": "\/var\/www\/html\/custom_apps\/memories\/bin-ext\/exiftool-amd64-glibc",
        "memories.vod.path": "\/var\/www\/html\/custom_apps\/memories\/bin-ext\/go-vod-amd64",
        "config_preset": 3,
        "mail_smtpmode": "smtp",
        "mail_smtpauth": true,
        "mail_smtpport": "465",
        "mail_sendmailmode": "smtp",
        "mail_smtpstreamoptions": {
            "ssl": {
                "allow_self_signed": false,
                "verify_peer": true,
                "verify_peer_name": true
        "mail_smtpsecure": "ssl",
        "enabledPreviewProviders": [
            "OC\\Preview\\Image",
            "OC\\Preview\\HEIC",
            "OC\\Preview\\TIFF",
            "OC\\Preview\\Movie"
        "defaultapp": "files,memories",
        "maintenance_window_start": "4",
        "overwriteprotocol": "https",
        "loglevel": 2,
            "127.0.0.1",
            "localhost",
            "nextcloud",
            "nginx",
            "test.agrarvolution.at",
  - activity: 6.0.0-dev.0
  - admin_audit: 1.23.0
  - app_api: 33.0.0
  - bruteforcesettings: 6.0.0-dev.0
  - circles: 33.0.0
  - cloud_federation_api: 1.17.0
  - comments: 1.23.0
  - contactsinteraction: 1.14.1
  - dashboard: 7.13.0
  - dav: 1.36.0
  - federatedfilesharing: 1.23.0
  - federation: 1.23.0
  - files: 2.5.0
  - files_downloadlimit: 5.1.0-dev.0
  - files_pdfviewer: 6.0.0-dev.0
  - files_reminders: 1.6.0
  - files_sharing: 1.25.2
  - files_trashbin: 1.23.0
  - files_versions: 1.26.0
  - firstrunwizard: 6.0.0-dev.0
  - guests: 4.6.0
  - logreader: 6.0.0
  - lookup_server_connector: 1.21.0
  - memories: 7.8.2
  - nextcloud_announcements: 5.0.0
  - notifications: 6.0.0
  - oauth2: 1.21.0
  - password_policy: 5.0.0-dev.0
  - photos: 6.0.0-dev.0
  - privacy: 5.0.0-dev.0
  - profile: 1.2.0
  - provisioning_api: 1.23.0
  - recommendations: 6.0.0-dev.0
  - related_resources: 4.0.0-dev.0
  - richdocuments: 10.1.2
  - richdocumentscode: 25.4.903
  - serverinfo: 5.0.0-dev.0
  - settings: 1.16.0
  - sharebymail: 1.23.0
  - support: 5.0.0
  - survey_client: 5.0.0-dev.0
  - systemtags: 1.23.0
  - text: 7.0.0-dev.3
  - theming: 2.8.0
  - twofactor_backupcodes: 1.22.0
  - twofactor_totp: 15.0.0-dev.0
  - twofactor_webauthn: 2.6.0
  - updatenotification: 1.23.0
  - user_status: 1.13.0
  - viewer: 6.0.0-dev.0
  - weather_status: 1.13.0
  - webhook_listeners: 1.5.0
  - workflowengine: 2.15.0
  - encryption: 2.21.0
  - files_external: 1.25.1
  - onlyoffice: 10.0.0 (installed 10.0.0)
  - suspicious_login: 11.0.0-dev.0
  - twofactor_nextcloud_notification: 7.0.0
  - user_ldap: 1.24.0
since there is an accepted bug on the issuetracker (you found that yourself!) there’s nothing much we can do right here than just waiting for it to be fixed by devs…
