Diskspace is 500 GB.
We have other servers which we want to link to this and use the storage to that.
As the current esx server hosting this is going to exhaust its storage.
And also, after deleting the files from nextcloud, still the used space is not decreasing.
Any suggestion on this please.
only nextcloud for 300 GB (sorry,not 500 GB) and on premise one.
I installed this on the local esxi server ubuntu VM.
I have installed an ftp on one of the physical machine.Want to link that to this.
WHere the hd space is 1 TB.ANd it is a windows 10 machine where ftp hosted using iis
I want to use this here.
Is it possible to mount on the nextcloud (Ubuntu VM) the ftp-filesystem directly from the physical machine and then use “local” in nextcloud gui like my screenshot (Configuration: /path/to/mountpoint/ftp-space-on-host-system) ? You must then set all rights to your nextcloud-user “www-data”.
Thank you I will try that and let you know.
And also, even after deleting files quoata is not showing changed.
Any suggestion for this?
Also, If I delete a file/folder inside a shared folder.
Will the original owner storage quoate is increased or not?Because it turned out to be two copies of recycle bin
And in the FTP, if I add any files, these are not showing in the nextcloud
You can use external storage as primary storage as well. However, there is little documentation about this, and perhaps not possible with all external storage types. I think it was possible with samba and object storage.
It’s a bit out of scope for normal users (most are probably enterprise users with subscription), however there were a few posts.
On premises, I’d just add a large hdd that’s much easier.
