I want to add a drop-down menu to the Transcribe Audio page to specify the language in the voice file. I can already add a drop-down menu to the page(modify /src/components/fields/MediaField.vue in assistant app).
<div v-if="value !== null"
class="media-info">
<div>Please select audio language:
<select v-model="selectedLanguage" @change="onLanguageChange">
<option value="zh">Chinese</option>
<option value="en">English</option>
</select>
</div>
</div>
I have also found the location of the API(in integration_openal app), but I just don’t know how to pass the parameters of the specified language. Can someone tell me how to modify it?
