Hi all,
Just wondering how much php upload max filesize to give and post max size to give
Do you think i should set this to how much ram I have in the server?
Thanks,
Rob
Hi all,
Thanks,
Rob
Why consider ram? What you should consider should be the actual usage.
If you have a lot of users and they use it free-of-charge, set it low and check their feedback to adjust.
If they paid, ask them what will they do with it first. Or how you position your service.
If you have a few users … well, for the sake of convenience, I set mine 10G.
so has ram got nothing to do with this?
as i thought it gets written to the cache ie ram when people upload/downlaod and then once finished it copies it to the hard disk
for upload over Internet, bottle neck is network traffic condition.
for local files, use external storage and select local inside.
