I understand the nextcloud talk uses peer to peer communications but what about the group call where you have 6 participants in the call, does it use P2P communications as well? Does it mean for each IP it has to send the data 5 times to the other participants?
yes, unless you use the high-performance backend. But in that case nothing is peer-to-peer anymore at the moment:
