Anyone with an idea how “Combine polls” works?
I only get a screen saying "Select polls by clicking on them in the right sidebar! " but the button for the right sidebar does not do anything.
… and Yes, I do have multiple date polls open for voting!
Thank you,
kr,
Martin
It was broken. Fixed with 7.0.2
opened 09:54AM - 28 Mar 24 UTC
closed 04:38PM - 29 Mar 24 UTC
bug
### ⚠️ This issue respects the following points: ⚠️
- [X] This is a **bug**, no… t a question or a configuration/webserver/proxy issue.
- [X] This issue is **not** already reported on Github _(I've searched it)_.
- [X] I agree to follow Nextcloud's [Code of Conduct](https://nextcloud.com/contribute/code-of-conduct/).
### What went wrong, what did you observe?
index.php/apps/polls/combo
does not show any Polls the right menue isnt expanable, no reaction from browser console:
![grafik](https://github.com/nextcloud/polls/assets/63392812/5790510e-ee00-430e-8d03-cca202a870d4)
### What did you expect, how polls should behave instead?
https://github.com/nextcloud/polls/pull/2175
### What steps does it need to replay this bug?
1. have two date polls
2. click on the Combine Polls button
3. not finding any polls to combine
### Installation method
Installed/updated from the appstore (Apps section of your site)
### Installation type
First time installation
### Affected polls version
7.0.0
### Which browser did you use, when experiencing the bug?
- [X] Firefox
- [ ] Chrome
- [ ] Chromium/Chromium based (i.e. Edge)
- [ ] Safari
- [ ] Other/Don't know
### Other browser
_No response_
### Add your browser log here
_No response_
### Additional client environment information
_No response_
### NC version
Nextcloud 28
### Other Nextcloud version
_No response_
### PHP engine version
PHP 8.2
### Other PHP version
_No response_
### Database engine
MariaDB
### Database Engine version or other Database
10.11.6
### Which user-backends are you using?
- [X] Default user-backend _(database)_
- [ ] LDAP/ Active Directory
- [ ] SSO - SAML
### Add your nextcloud server log here
_No response_
### Additional environment informations
_No response_
### Configuration report
_No response_
### List of activated Apps
_No response_
### Nextcloud Signing status
_No response_
### Additional Information
_No response_
