I’m using jerge as a virtual box.
And how do I set it up? If you enter the ip address, you can’t connect to http, you can connect to https
afaik it’s designed like that.
I dunno if it’s possible at all to connect to OO using http, only. Maybe you wanna check their forums?
Yes, I’d like to check out their forum
pls provide us with the solution as well… ![]()
