Dear all,
I have a problem with some of my calendars using DAVx5. After setting up my account and syncing it, it shows this symbol for two out of my three CalDAV calendars which I interpret to mean that I have read-only permissions for them. (It looks like a dash inside a circle.) I have attached a screen shot that depicts this situation.
The first calendar is from Nextcloud’s Deck app. I can edit Deck boards without a problem in the browser and they do get synced to my phone but I cannot edit anything on the phone and make those changes sync with the cloud. I suspect that the dash-in-circle symbol means that I have read-only permission. (I’m not worried about the second calendar because those just follow from the “important dates” of the contacts in my address book; so no need to manually edit it.) The third calendar, which is my main personal calendar, gets synced as expected.
- Does the dash-in-circle symbol indeed mean that I only have read permissions? DAVx5 unfortunately does not provide a “permissions” section for the entries in this view to verify my assumption.
- Assuming that I indeed have a permissions problem, what can I do to grant read/write permissions for these CalDAVs?
Thanks and best,
CC
