I’m trying to connect my home assistant (hass.io) to nextcloud to get the calendars. But I have a connection error.
Error while setting up platform caldav
Traceback (most recent call last):
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 157, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw
File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 84, in create_connection
raise err
File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 74, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
During handling of the above exception, another exception occurred:
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 672, in urlopen
chunked=chunked,
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 376, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 994, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 334, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 169, in _new_conn
self, "Failed to establish a new connection: %s" % e
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x7fe5db1f1790>: Failed to establish a new connection: [Errno 111] Connection refused
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 720, in urlopen
method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 436, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='TLD.com', port=443): Max retries exceeded with url: /remote.php/dav/ (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7fe5db1f1790>: Failed to establish a new connection: [Errno 111] Connection refused'))
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 150, in _async_setup_platform
await asyncio.wait_for(asyncio.shield(task), SLOW_SETUP_MAX_WAIT)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 442, in wait_for
return fut.result()
File "/usr/local/lib/python3.7/concurrent/futures/thread.py", line 57, in run
result = self.fn(*self.args, **self.kwargs)
File "/usr/src/homeassistant/homeassistant/components/caldav/calendar.py", line 74, in setup_platform
calendars = client.principal().calendars()
File "/usr/local/lib/python3.7/site-packages/caldav/davclient.py", line 118, in principal
return Principal(self)
File "/usr/local/lib/python3.7/site-packages/caldav/objects.py", line 370, in __init__
cup = self.get_properties([dav.CurrentUserPrincipal()])
File "/usr/local/lib/python3.7/site-packages/caldav/objects.py", line 219, in get_properties
response = self._query_properties(props, depth)
File "/usr/local/lib/python3.7/site-packages/caldav/objects.py", line 129, in _query_properties
return self._query(root, depth)
File "/usr/local/lib/python3.7/site-packages/caldav/objects.py", line 161, in _query
url, body, depth)
File "/usr/local/lib/python3.7/site-packages/caldav/davclient.py", line 133, in propfind
{'Depth': str(depth)})
File "/usr/local/lib/python3.7/site-packages/caldav/davclient.py", line 237, in request
auth=auth, verify=self.ssl_verify_cert)
File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 60, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='TLD.com', port=443): Max retries exceeded with url: /remote.php/dav/ (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7fe5db1f1790>: Failed to establish a new connection: [Errno 111] Connection refused'))
I think the problem comes from the fact that it is done directly via python without a web interface so it is not possible to make the web connection.
How can I do to perform this operation serenely.
thank you for your help.
