Hi, just migrated from a NC server to another.
I had backups made with ownbackup.
I restored the oc_passwords* mysql tables with that backup.
But when I try to acces the Passwords app I get this error:
{“reqId”:“v8Zu5gPhaYYTxQxMpKiE”,“level”:3,“time”:“2019-07-19T14:13:51+00:00”,“remoteAddr”:“xxx.xxx.xxx.xxx”,“user”:“MyUserId”,“app”:“passwords”,“method”:“POST”,“url”:"/index.php/apps/passwords/api/1.0/password/list",“message”:{“Exception”:“Exception”,“Message”:“HMAC does not match.”,“Code”:0,“Trace”:[{“file”:"/var/www/nextcloud/apps/passwords/lib/Encryption/Object/SseV1Encryption.php",“line”:158,“function”:“decrypt”,“class”:“OC\Security\Crypto”,“type”:"->",“args”:["*** sensitive parameters replaced "]},{“file”:"/var/www/nextcloud/apps/passwords/lib/Services/EncryptionService.php",“line”:113,“function”:“decryptObject”,“class”:“OCA\Passwords\Encryption\Object\SseV1Encryption”,“type”:"->",“args”:[" sensitive parameters replaced "]},{“file”:"/var/www/nextcloud/apps/passwords/lib/Helper/ApiObjects/AbstractObjectHelper.php",“line”:111,“function”:“decrypt”,“class”:“OCA\Passwords\Services\EncryptionService”,“type”:"->",“args”:[" sensitive parameters replaced ***"]},{“file”:"/var/www/nextcloud/apps/passwords/lib/Helper/ApiObjects/PasswordObjectHelper.php",“line”:104,“function”:“getRevision”,“class”:“OCA\Passwords\Helper\ApiObjects\AbstractObjectHelper”,“type”:"->",“args”:[{“id”:2,“class”:“OCA\Passwords\Db\Password”},{“hidden”:false,“trashed”:false}]},{“file”:"/var/www/nextcloud/apps/passwords/lib/Controller/Api/AbstractObjectApiController.php",“line”:91,“function”:“getApiObject”,“class”:“OCA\Passwords\Helper\ApiObjects\PasswordObjectHelper”,“type”:"->",“args”:[{“id”:2,“class”:“OCA\Passwords\Db\Password”},“model”,{“hidden”:false,“trashed”:false}]},{“file”:"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php",“line”:166,“function”:“list”,“class”:“OCA\Passwords\Controller\Api\AbstractObjectApiController”,“type”:"->",“args”:[“model”]},{“file”:"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php",“line”:99,“function”:“executeController”,“class”:“OC\AppFramework\Http\Dispatcher”,“type”:"->",“args”:[{“class”:“OCA\Passwords\Controller\Api\PasswordApiController”},“list”]},{“file”:"/var/www/nextcloud/lib/private/AppFramework/App.php",“line”:126,“function”:“dispatch”,“class”:“OC\AppFramework\Http\Dispatcher”,“type”:"->",“args”:[{“class”:“OCA\Passwords\Controller\Api\PasswordApiController”},“list”]},{“file”:"/var/www/nextcloud/lib/private/AppFramework/Routing/RouteActionHandler.php",“line”:47,“function”:“main”,“class”:“OC\AppFramework\App”,“type”:"::",“args”:[“PasswordApiController”,“list”,{“class”:“OC\AppFramework\DependencyInjection\DIContainer”},{"_route":“passwords.password_api.listPOST”}]},{“function”:"__invoke",“class”:“OC\AppFramework\Routing\RouteActionHandler”,“type”:"->",“args”:[{"_route":“passwords.password_api.listPOST”}]},{“file”:"/var/www/nextcloud/lib/private/Route/Router.php",“line”:297,“function”:“call_user_func”,“args”:[{“class”:“OC\AppFramework\Routing\RouteActionHandler”},{"_route":“passwords.password_api.listPOST”}]},{“file”:"/var/www/nextcloud/lib/base.php",“line”:975,“function”:“match”,“class”:“OC\Route\Router”,“type”:"->",“args”:["/apps/passwords/api/1.0/password/list"]},{“file”:"/var/www/nextcloud/index.php",“line”:42,“function”:“handleRequest”,“class”:“OC”,“type”:"::",“args”:[]}],“File”:"/var/www/nextcloud/lib/private/Security/Crypto.php",“Line”:131,“CustomMessage”:"–"},“userAgent”:“Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/68.0.3440.106 Safari/537.36”,“version”:“16.0.3.0”}
Any idea/help would be greatly appreciated :s)
