HMAC does not match. .wellknown URLs fail2ban not helping
    • 32.0.3
    • Ubuntu 24.04LTS
    • Apache 2.4.58
    • replace me
    • 8.4
    • Yes
    • Unknown at least a week
    • Bare Metal
    • Cloudflare is my DNS registrar
[HMAC does not match. may similar acme messages: many .well-known urls
Have fail2ban blocking the IP addresses and it continues to happen.
  "reqId": "sOkfTJEKFrLV4vXGL9l3",
  "level": 3,
  "time": "2026-01-01T07:52:34+00:00",
  "remoteAddr": "4.213.136.62",
  "user": "–",
  "app": "core",
  "method": "GET",
  "url": "/.well-known/acme-challenge/index.php",
  "message": "Could not decrypt or decode encrypted session data",
  "userAgent": "Mozilla/5.0 (Linux; Android 12; 2201116SG) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Mobile Safari/537.36",
  "version": "32.0.3.2",
  "exception": {
    "Exception": "Exception",
    "Message": "HMAC does not match.",
    "Code": 0,
    "Trace": [
        "file": "/var/www/html/nextcloud/lib/private/Security/Crypto.php",
        "line": 98,
        "function": "decryptWithoutSecret",
        "class": "OC\\Security\\Crypto",
        "type": "->",
        "args": [
          "*** sensitive parameters replaced ***"
        "file": "/var/www/html/nextcloud/lib/private/Session/CryptoSessionData.php",
        "line": 70,
        "function": "decrypt",
        "type": "->",
        "args": [
        "line": 47,
        "function": "initializeSession",
        "class": "OC\\Session\\CryptoSessionData",
        "type": "->"
        "file": "/var/www/html/nextcloud/lib/private/Session/CryptoWrapper.php",
        "line": 75,
        "function": "__construct",
        "type": "->"
        "file": "/var/www/html/nextcloud/lib/base.php",
        "line": 421,
        "function": "wrapSession",
        "class": "OC\\Session\\CryptoWrapper",
        "type": "->"
        "line": 699,
        "function": "initSession",
        "class": "OC",
        "type": "::"
        "line": 1192,
        "function": "init",
        "class": "OC",
        "type": "::"
        "file": "/var/www/html/nextcloud/index.php",
        "line": 23,
        "args": [
        "function": "require_once"
    "File": "/var/www/html/nextcloud/lib/private/Security/Crypto.php",
    "Line": 162,
    "exception": [],
    "CustomMessage": "Could not decrypt or decode encrypted session data"
  "id": "6956451d5f5a9"
  1. Just wait multiple hits a day
{"reqId":"sOkfTJEKFrLV4vXGL9l3","level":3,"time":"2026-01-01T07:52:34+00:00","remoteAddr":"4.213.136.62","user":"--","app":"core","method":"GET","url":"/.well-known/acme-challenge/index.php","message":"Could not decrypt or decode encrypted session data","userAgent":"Mozilla/5.0 (Linux; Android 12; 2201116SG) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Mobile Safari/537.36","version":"32.0.3.2","exception":{"Exception":"Exception","Message":"HMAC does not match.","Code":0,"Trace":[{"file":"/var/www/html/nextcloud/lib/private/Security/Crypto.php","line":98,"function":"decryptWithoutSecret","class":"OC\\Security\\Crypto","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/Session/CryptoSessionData.php","line":70,"function":"decrypt","class":"OC\\Security\\Crypto","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/Session/CryptoSessionData.php","line":47,"function":"initializeSession","class":"OC\\Session\\CryptoSessionData","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Session/CryptoWrapper.php","line":75,"function":"__construct","class":"OC\\Session\\CryptoSessionData","type":"->"},{"file":"/var/www/html/nextcloud/lib/base.php","line":421,"function":"wrapSession","class":"OC\\Session\\CryptoWrapper","type":"->"},{"file":"/var/www/html/nextcloud/lib/base.php","line":699,"function":"initSession","class":"OC","type":"::"},{"file":"/var/www/html/nextcloud/lib/base.php","line":1192,"function":"init","class":"OC","type":"::"},{"file":"/var/www/html/nextcloud/index.php","line":23,"args":["/var/www/html/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/var/www/html/nextcloud/lib/private/Security/Crypto.php","Line":162,"message":"Could not decrypt or decode encrypted session data","exception":[],"CustomMessage":"Could not decrypt or decode encrypted session data"},"id":"6956451d5f5a9"}
{"reqId":"p6mE2VTtFAiE2rST1DcT","level":3,"time":"2026-01-01T01:00:20+00:00","remoteAddr":"4.197.176.207","user":"--","app":"core","method":"GET","url":"/.well-known/acme-challenge/index.php","message":"Could not decrypt or decode encrypted session data","userAgent":"Mozilla/5.0 (iPad; CPU OS 17_0_3 like Mac OS X) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/17.0.1 Mobile/15E148 Safari/604.1","version":"32.0.3.2","exception":{"Exception":"Exception","Message":"HMAC does not match.","Code":0,"Trace":[{"file":"/var/www/html/nextcloud/lib/private/Security/Crypto.php","line":98,"function":"decryptWithoutSecret","class":"OC\\Security\\Crypto","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/Session/CryptoSessionData.php","line":70,"function":"decrypt","class":"OC\\Security\\Crypto","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/Session/CryptoSessionData.php","line":47,"function":"initializeSession","class":"OC\\Session\\CryptoSessionData","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Session/CryptoWrapper.php","line":75,"function":"__construct","class":"OC\\Session\\CryptoSessionData","type":"->"},{"file":"/var/www/html/nextcloud/lib/base.php","line":421,"function":"wrapSession","class":"OC\\Session\\CryptoWrapper","type":"->"},{"file":"/var/www/html/nextcloud/lib/base.php","line":699,"function":"initSession","class":"OC","type":"::"},{"file":"/var/www/html/nextcloud/lib/base.php","line":1192,"function":"init","class":"OC","type":"::"},{"file":"/var/www/html/nextcloud/index.php","line":23,"args":["/var/www/html/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/var/www/html/nextcloud/lib/private/Security/Crypto.php","Line":162,"message":"Could not decrypt or decode encrypted session data","exception":[],"CustomMessage":"Could not decrypt or decode encrypted session data"},"id":"69564527620ff"}
{"reqId":"p6mE2VTtFAiE2rST1DcT","level":3,"time":"2026-01-01T01:00:20+00:00","remoteAddr":"4.197.176.207","user":"--","app":"core","method":"GET","url":"/.well-known/acme-challenge/index.php","message":"Could not decrypt or decode encrypted session data","userAgent":"Mozilla/5.0 (iPad; CPU OS 17_0_3 like Mac OS X) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/17.0.1 Mobile/15E148 Safari/604.1","version":"32.0.3.2","exception":{"Exception":"Exception","Message":"HMAC does not match.","Code":0,"Trace":[{"file":"/var/www/html/nextcloud/lib/private/Security/Crypto.php","line":98,"function":"decryptWithoutSecret","class":"OC\\Security\\Crypto","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/Session/CryptoSessionData.php","line":70,"function":"decrypt","class":"OC\\Security\\Crypto","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/Session/CryptoSessionData.php","line":47,"function":"initializeSession","class":"OC\\Session\\CryptoSessionData","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Session/CryptoWrapper.php","line":75,"function":"__construct","class":"OC\\Session\\CryptoSessionData","type":"->"},{"file":"/var/www/html/nextcloud/lib/base.php","line":421,"function":"wrapSession","class":"OC\\Session\\CryptoWrapper","type":"->"},{"file":"/var/www/html/nextcloud/lib/base.php","line":699,"function":"initSession","class":"OC","type":"::"},{"file":"/var/www/html/nextcloud/lib/base.php","line":1192,"function":"init","class":"OC","type":"::"},{"file":"/var/www/html/nextcloud/index.php","line":23,"args":["/var/www/html/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/var/www/html/nextcloud/lib/private/Security/Crypto.php","Line":162,"message":"Could not decrypt or decode encrypted session data","exception":[],"CustomMessage":"Could not decrypt or decode encrypted session data"},"id":"6956451d5f5bb"}
{"reqId":"GO1i5dR7fMVzWitxnGNm","level":3,"time":"2025-12-31T22:43:18+00:00","remoteAddr":"130.33.50.170","user":"--","app":"core","method":"GET","url":"/.well-known/acme-challenge/index.php","message":"Could not decrypt or decode encrypted session data","userAgent":"Mozilla/5.0 (Linux; Android 12; SM-A525F) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/117.0.0.0 Mobile Safari/537.36","version":"32.0.3.2","exception":{"Exception":"Exception","Message":"HMAC does not match.","Code":0,"Trace":[{"file":"/var/www/html/nextcloud/lib/private/Security/Crypto.php","line":98,"function":"decryptWithoutSecret","class":"OC\\Security\\Crypto","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/Session/CryptoSessionData.php","line":70,"function":"decrypt","class":"OC\\Security\\Crypto","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/Session/CryptoSessionData.php","line":47,"function":"initializeSession","class":"OC\\Session\\CryptoSessionData","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Session/CryptoWrapper.php","line":75,"function":"__construct","class":"OC\\Session\\CryptoSessionData","type":"->"},{"file":"/var/www/html/nextcloud/lib/base.php","line":421,"function":"wrapSession","class":"OC\\Session\\CryptoWrapper","type":"->"},{"file":"/var/www/html/nextcloud/lib/base.php","line":699,"function":"initSession","class":"OC","type":"::"},{"file":"/var/www/html/nextcloud/lib/base.php","line":1192,"function":"init","class":"OC","type":"::"},{"file":"/var/www/html/nextcloud/index.php","line":23,"args":["/var/www/html/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/var/www/html/nextcloud/lib/private/Security/Crypto.php","Line":162,"message":"Could not decrypt or decode encrypted session data","exception":[],"CustomMessage":"Could not decrypt or decode encrypted session data"},"id":"6956452762108"}
{"reqId":"UfAhlsmNDGxjGvdYlmQo","level":3,"time":"2025-12-31T22:22:54+00:00","remoteAddr":"4.197.176.207","user":"--","app":"core","method":"GET","url":"/.well-known/acme-challenge/index.php","message":"Could not decrypt or decode encrypted session data","userAgent":"Mozilla/5.g (Linux; Android 13; Pixel 7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Mobile Safari/537.36","version":"32.0.3.2","exception":{"Exception":"Exception","Message":"HMAC does not match.","Code":0,"Trace":[{"file":"/var/www/html/nextcloud/lib/private/Security/Crypto.php","line":98,"function":"decryptWithoutSecret","class":"OC\\Security\\Crypto","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/Session/CryptoSessionData.php","line":70,"function":"decrypt","class":"OC\\Security\\Crypto","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/Session/CryptoSessionData.php","line":47,"function":"initializeSession","class":"OC\\Session\\CryptoSessionData","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Session/CryptoWrapper.php","line":75,"function":"__construct","class":"OC\\Session\\CryptoSessionData","type":"->"},{"file":"/var/www/html/nextcloud/lib/base.php","line":421,"function":"wrapSession","class":"OC\\Session\\CryptoWrapper","type":"->"},{"file":"/var/www/html/nextcloud/lib/base.php","line":699,"function":"initSession","class":"OC","type":"::"},{"file":"/var/www/html/nextcloud/lib/base.php","line":1192,"function":"init","class":"OC","type":"::"},{"file":"/var/www/html/nextcloud/index.php","line":23,"args":["/var/www/html/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/var/www/html/nextcloud/lib/private/Security/Crypto.php","Line":162,"message":"Could not decrypt or decode encrypted session data","exception":[],"CustomMessage":"Could not decrypt or decode encrypted session data"},"id":"6956452762111"}
PASTE
anthony@www:/var/log$ tail -n 20 apache2/access.log
172.68.159.184 - - [01/Jan/2026:03:18:17 -0500] "GET /sendgrid.env HTTP/1.1" 301 569 "-" "Mozilla/5.0 (Windows NT 6.1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.90 Safari/537.36 OPR/47.0.2631.80"
104.23.223.86 - - [01/Jan/2026:03:18:18 -0500] "GET /twilio.env HTTP/1.1" 301 561 "-" "Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; InfoPath.3; .NET4.0C)"
172.64.198.14 - - [01/Jan/2026:03:18:18 -0500] "GET /twilio.env HTTP/1.1" 301 565 "-" "Mozilla/5.0 (Windows NT 10.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/53.0.2785.116 Safari/537.36 OPR/40.0.2308.81"
172.64.198.14 - - [01/Jan/2026:03:18:19 -0500] "GET /api/.env HTTP/1.1" 301 560 "-" "Mozilla/4.0 (compatible; MSIE 5.01; Windows NT 5.0; YComp 5.0.0.0)"
162.158.182.189 - - [01/Jan/2026:03:18:19 -0500] "GET /api/.env HTTP/1.1" 301 557 "-" "Mozilla/5.0 (Macintosh; U; PPC Mac OS X; fr-fr) AppleWebKit/125.5.5 (KHTML, like Gecko) Safari/125.11"
172.64.198.14 - - [01/Jan/2026:03:18:19 -0500] "GET /phpinfo/ HTTP/1.1" 301 560 "-" "Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.78 Safari/537.36 OPR/47.0.2631.39"
162.158.182.189 - - [01/Jan/2026:03:18:20 -0500] "GET /phpinfo/ HTTP/1.1" 301 556 "-" "Mozilla/5.0 (Android 6.0.1; Mobile; rv:46.0) Gecko/46.0 Firefox/46.0"
104.23.221.61 - - [01/Jan/2026:03:18:21 -0500] "GET /dev/.env HTTP/1.1" 301 557 "-" "Mozilla/5.0 (Macintosh; U; Intel Mac OS X 10_5_3; es-es) AppleWebKit/525.18 (KHTML, like Gecko) Version/3.1.1 Safari/525.20"
104.23.217.76 - - [01/Jan/2026:03:18:22 -0500] "GET /app_dev.php/_profiler/phpinfo HTTP/1.1" 301 599 "-" "Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; en) Opera 9.24"
162.158.103.61 - - [01/Jan/2026:03:18:22 -0500] "GET /admin/.env HTTP/1.1" 301 561 "-" "Mozilla/5.0 (Linux; U; Android 4.0.3; en-gb; GT-I9100 Build/IML74K) AppleWebKit/534.30 (KHTML, like Gecko) Version/4.0 Mobile Safari/534.30"
172.64.198.43 - - [01/Jan/2026:03:18:24 -0500] "GET /laravel/.env HTTP/1.1" 301 565 "-" "Mozilla/5.0 (Windows; U; Windows NT 6.0; en-US) AppleWebKit/532.0 (KHTML, like Gecko) Chrome/3.0.195.6 Safari/532.0"
104.23.221.61 - - [01/Jan/2026:03:18:25 -0500] "GET /.config.yaml HTTP/1.1" 301 564 "-" "Mozilla/5.0 (Windows NT 6.1; U; de; rv:1.9.1.6) Gecko/20091201 Firefox/3.5.6 Opera 11.01"
172.64.198.43 - - [01/Jan/2026:03:18:25 -0500] "GET /backend/.env HTTP/1.1" 301 564 "-" "Mozilla/5.0 (Windows; U; Windows NT 6.1; pl; rv:23.0) Gecko/20100101 Firefox/23.0 (.NET CLR 3.5.30729)"
172.64.198.43 - - [01/Jan/2026:03:18:26 -0500] "GET /secrets.env HTTP/1.1" 301 562 "-" "Mozilla/5.0 (Windows; U; Windows NT 5.2 x64; en-US; rv:1.9a1) Gecko/20060214 Firefox/1.6a1"
172.64.198.43 - - [01/Jan/2026:03:18:26 -0500] "GET /.env.example HTTP/1.1" 301 564 "-" "More Firefox 1.5.0.3 user agents strings -->>"
172.70.248.49 - - [01/Jan/2026:03:29:28 -0500] "GET / HTTP/1.1" 301 545 "-" "Mozilla/5.0 (iPhone; CPU iPhone OS 13_2_3 like Mac OS X) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/13.0.3 Mobile/15E148 Safari/604.1"
162.158.42.238 - - [01/Jan/2026:03:30:12 -0500] "GET /robots.txt HTTP/1.1" 301 561 "-" "Mozilla/5.0 (compatible; DotBot/1.2; +https://opensiteexplorer.org/dotbot; help@moz.com)"
172.71.144.177 - - [01/Jan/2026:04:10:30 -0500] "GET / HTTP/1.1" 301 541 "-" "Mozilla/5.0 (iPhone; CPU iPhone OS 13_2_3 like Mac OS X) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/13.0.3 Mobile/15E148 Safari/604.1"
192.168.1.165 - - [01/Jan/2026:04:52:26 -0500] "GET /data/.ncdata HTTP/1.1" 301 513 "-" "Nextcloud Server Crawler"
64.62.156.172 - - [01/Jan/2026:04:56:14 -0500] "GET / HTTP/1.1" 301 486 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/128.0.0.0 Safari/537.36"
anthony@www:/var/log$ tail -n 20 apache2/nextcloud_access.log
192.168.1.144 - - [01/Jan/2026:04:58:15 -0500] "POST /index.php/apps/passwords/api/1.0/folder/show HTTP/2.0" 200 1504 "-" "Official Passwords Client for Firefox on Linux"
192.168.1.144 - - [01/Jan/2026:04:58:19 -0500] "GET /apps/logreader/api/poll?lastReqId=buZ6cTjLErc4TjL1kq4a HTTP/2.0" 200 547 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:146.0) Gecko/20100101 Firefox/146.0"
192.168.1.144 - - [01/Jan/2026:04:58:29 -0500] "GET /apps/logreader/api/poll?lastReqId=buZ6cTjLErc4TjL1kq4a HTTP/2.0" 200 547 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:146.0) Gecko/20100101 Firefox/146.0"
192.168.1.144 - - [01/Jan/2026:04:58:40 -0500] "GET /apps/logreader/api/poll?lastReqId=buZ6cTjLErc4TjL1kq4a HTTP/2.0" 200 546 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:146.0) Gecko/20100101 Firefox/146.0"
192.168.1.144 - - [01/Jan/2026:04:58:51 -0500] "GET /apps/logreader/api/poll?lastReqId=buZ6cTjLErc4TjL1kq4a HTTP/2.0" 200 547 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:146.0) Gecko/20100101 Firefox/146.0"
192.168.1.144 - - [01/Jan/2026:04:59:01 -0500] "GET /apps/logreader/api/poll?lastReqId=buZ6cTjLErc4TjL1kq4a HTTP/2.0" 200 547 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:146.0) Gecko/20100101 Firefox/146.0"
192.168.1.144 - - [01/Jan/2026:04:59:07 -0500] "GET /settings/admin/log/download HTTP/2.0" 200 173637 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:146.0) Gecko/20100101 Firefox/146.0"
192.168.1.144 - - [01/Jan/2026:04:59:11 -0500] "GET /apps/logreader/api/poll?lastReqId=buZ6cTjLErc4TjL1kq4a HTTP/2.0" 200 132 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:146.0) Gecko/20100101 Firefox/146.0"
192.168.1.144 - - [01/Jan/2026:04:59:21 -0500] "GET /apps/logreader/api/poll?lastReqId=buZ6cTjLErc4TjL1kq4a HTTP/2.0" 200 546 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:146.0) Gecko/20100101 Firefox/146.0"
192.168.1.144 - - [01/Jan/2026:04:59:31 -0500] "GET /apps/logreader/api/poll?lastReqId=buZ6cTjLErc4TjL1kq4a HTTP/2.0" 200 547 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:146.0) Gecko/20100101 Firefox/146.0"
192.168.1.144 - - [01/Jan/2026:04:59:41 -0500] "GET /apps/logreader/api/poll?lastReqId=buZ6cTjLErc4TjL1kq4a HTTP/2.0" 200 546 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:146.0) Gecko/20100101 Firefox/146.0"
192.168.1.144 - - [01/Jan/2026:04:59:51 -0500] "GET /apps/logreader/api/poll?lastReqId=buZ6cTjLErc4TjL1kq4a HTTP/2.0" 200 547 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:146.0) Gecko/20100101 Firefox/146.0"
192.168.1.144 - - [01/Jan/2026:05:00:01 -0500] "GET /apps/logreader/api/poll?lastReqId=buZ6cTjLErc4TjL1kq4a HTTP/2.0" 200 546 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:146.0) Gecko/20100101 Firefox/146.0"
192.168.1.144 - - [01/Jan/2026:05:00:11 -0500] "GET /apps/logreader/api/poll?lastReqId=buZ6cTjLErc4TjL1kq4a HTTP/2.0" 200 546 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:146.0) Gecko/20100101 Firefox/146.0"
192.168.1.144 - - [01/Jan/2026:05:00:21 -0500] "GET /apps/logreader/api/poll?lastReqId=buZ6cTjLErc4TjL1kq4a HTTP/2.0" 200 546 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:146.0) Gecko/20100101 Firefox/146.0"
192.168.1.144 - - [01/Jan/2026:05:00:32 -0500] "GET /apps/logreader/api/poll?lastReqId=buZ6cTjLErc4TjL1kq4a HTTP/2.0" 200 547 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:146.0) Gecko/20100101 Firefox/146.0"
192.168.1.144 - - [01/Jan/2026:05:00:42 -0500] "GET /apps/logreader/api/poll?lastReqId=buZ6cTjLErc4TjL1kq4a HTTP/2.0" 200 547 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:146.0) Gecko/20100101 Firefox/146.0"
192.168.1.144 - - [01/Jan/2026:05:00:52 -0500] "GET /apps/logreader/api/poll?lastReqId=buZ6cTjLErc4TjL1kq4a HTTP/2.0" 200 547 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:146.0) Gecko/20100101 Firefox/146.0"
192.168.1.144 - - [01/Jan/2026:05:01:02 -0500] "GET /apps/logreader/api/poll?lastReqId=buZ6cTjLErc4TjL1kq4a HTTP/2.0" 200 546 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:146.0) Gecko/20100101 Firefox/146.0"
192.168.1.144 - - [01/Jan/2026:05:01:12 -0500] "GET /apps/logreader/api/poll?lastReqId=buZ6cTjLErc4TjL1kq4a HTTP/2.0" 200 546 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:146.0) Gecko/20100101 Firefox/146.0"
            "www.webhoran.com"
        "allowed_admin_ranges": [
            "127.0.0.1\/8",
            "127.0.1.1\/8",
            "192.168.1.0\/24"
        "forwarded_for_headers": [
            "HTTP_CF_CONNECTING_IP",
            "HTTP_X_FORWARDED_FOR"
        "dbtype": "mysql",
        "overwrite.cli.url": "https:\/\/www.webhoran.com",
        "htaccess.RewriteBase": "\/",
        "maintenance_window_start": 6,
        "default_phone_region": "US",
        "dbport": "",
        "mysql.utf8mb4": true,
        "filelocking.enabled": "true",
        "redis": {
            "port": 0,
            "dbindex": 0,
            "timeout": 1.5
        "app_install_overwrite": {
            "0": "otpmanager",
            "1": "passman",
            "2": "passwords",
            "4": "maps"
        "enabledPreviewProviders": [
            "OC\\Preview\\PNG",
            "OC\\Preview\\JPEG",
            "OC\\Preview\\GIF",
            "OC\\Preview\\HEIC",
            "OC\\Preview\\BMP",
            "OC\\Preview\\XBitmap",
            "OC\\Preview\\MP3",
            "OC\\Preview\\TXT",
            "OC\\Preview\\MarkDown",
            "OC\\Preview\\Krita",
            "OC\\Preview\\OpenDocument",
            "OC\\Preview\\SVG",
            "OC\\Preview\\MSOffice2003",
            "OC\\Preview\\MSOffice2007",
            "OC\\Preview\\MSOfficeDoc",
            "OC\\Preview\\PDF",
            "OC\\Preview\\Font",
            "OC\\Preview\\Movie",
            "OC\\Preview\\TIFF",
            "OC\\Preview\\Postscript"
        "log_type": "file",
        "logfile": "\/var\/www\/html\/nextcloud\/data\/nextcloud.log",
        "loglevel": 2,
        "logtimezone": "UTC",
        "log_rotate_size": 10485760,
        "php.allow_deprecation_logs": false,
        "twofactor_enforced": "false",
            "admin"
        "onlyoffice": {
            "allow_local_remote_service": true,
            "verify_peer_off": true,
            "jwt_leeway": 120
        "theme": "",
        "mail_smtpmode": "smtp",
        "mail_sendmailmode": "smtp",
        "config_preset": 1
  • activity: 5.0.0-dev.0
  • admin_audit: 1.22.0
  • app_api: 32.0.0
  • appointments: 2.6.2
  • assistant: 2.12.0
  • bookmarks: 16.0.1
  • calendar: 6.1.2
  • comments: 1.22.0
  • contacts: 8.1.2
  • contactsinteraction: 1.13.1
  • context_chat: 5.1.0
  • dashboard: 7.12.0
  • dav: 1.34.2
  • deck: 1.16.3
  • external: 7.0.0
  • federation: 1.22.0
  • files: 2.4.0
  • files_antivirus: 6.1.0
  • files_external: 1.24.0
  • files_reminders: 1.5.0
  • files_sharing: 1.24.1
  • files_trashbin: 1.22.0
  • files_versions: 1.25.0
  • fileslibreofficeedit: 2.0.1
  • firstrunwizard: 5.0.0-dev.0
  • forms: 5.2.3
  • guests: 4.6.0
  • integration_openai: 3.9.1
  • logreader: 5.0.0-dev.0
  • maps: 1.6.0
  • notes: 4.12.4
  • notifications: 5.0.0-dev.0
  • notify_push: 1.2.1
  • oauth2: 1.20.0
  • onlyoffice: 9.12.0
  • otpmanager: 0.5.4
  • passwords: 2025.12.21
  • photos: 5.0.0-dev.1
  • privacy: 4.0.0-dev.0
  • profile: 1.1.0
  • provisioning_api: 1.22.0
  • recognize: 10.0.7
  • serverinfo: 4.0.0-dev.0
  • settings: 1.15.1
  • sharebymail: 1.22.0
  • spreed: 22.0.7
  • support: 4.0.0-dev.0
  • survey_client: 4.0.0-dev.0
  • systemtags: 1.22.0
  • talk_matterbridge: 1.32.1026000
  • tasks: 0.17.1
  • text: 6.0.1
  • theming: 2.7.0
  • twofactor_totp: 14.0.0
  • twofactor_webauthn: 2.4.1
  • updatenotification: 1.22.0
  • user_status: 1.12.0
  • viewer: 5.0.0-dev.0
  • weather_status: 1.12.0
  • webhook_listeners: 1.3.0
  • welcome: 1.4.0
  • workflowengine: 2.14.0
  • announcementcenter: 7.2.2 (installed 7.2.2)
  • circles: 32.0.0 (installed 31.0.0)
  • encryption: 2.20.0
  • terms_of_service: 4.6.1 (installed 4.6.1)
  • user_ldap: 1.23.0
What can I do to fix this error that is reoccuring regular 10x per day. Also sometimes the log reader in the nextcloud admin entyries appear in sets of 2 of the same item at exact same time. Do I wait longer for fail2ban to work or is this anther issue that I can fix?
I updated my fail2ban to use cloudflare to block the ips with the action file cloudflare-token.conf which is included in the fail2ban. Hopefully this will improve the fail2ban and fix my problem. I was unaware of this option until I did some research.
Hi @Richard_Horan,
You (like all of us) are simply being scanned by Microsoft. It’s really annoying, but it can definitely be fixed with fail2ban. I’ve already described how to do that (I think I need to write a how-to guide about it).
Please read this post very carefully
h.t.h.
ernolf
In this case, if it is always the same ip/network, perhaps an abuse report would be a good idea? Perhaps something goes wrong and they are not aware of it?
Thank you. @ernolf My problem is solved for this past day I have no errors. I added multiple fail2ban jails including what is in the article, which block the ip addresses with cloudflare and there are 100+ ips blocked through clouldflare now with fail2ban and I no longer get the error. I was getting traffic from Hong Kong, China, Japan, Europe, Saudi Arabia and more. I used some cloudflare regional blocking.
