Nextcloud version - Nextcloud Hub 3 (25.0.2) official base docker container.
Operating system and version: Linux openmediavault 5.19.0-0.deb11.2-amd64
Apache or nginx version: apache2 integrated in Nextcloud base docker container + separate nginx docker nginx/1.18.0
PHP version (eg, 7.4): idk it’s integrated in Nextcloud base docker container
I need your help to configure nginx with Nextcloud.
I was able to setup Nextcloud with offician base docker image. Everything works fine, even SSL. But I don’t understand how to configure nginx with Nextcloud. Any help will be highly appreciated.
When I try to configure Nginx with my configuration I have this error: “Access through untrusted domain
Please contact your administrator. If you are an administrator, edit the “trusted_domains” setting in config/config.php like the example in config.sample.php.”
I know it’s not easy but I’m ready to dig it no matter what.
- Install official Nextcloud base docker container with these parameters:
version: ‘2’
volumes:
nextcloud:
services:
app:
image: nextcloud
container_name: nextcloud
restart: always
network_mode: host
volumes:
- nextcloud:/var/www/html
- /distrib/nginx/ssl:/ssl
environment:
- MYSQL_PASSWORD=password
- MYSQL_DATABASE=nextcloud
- MYSQL_USER=root
- MYSQL_HOST=127.0.0.1
- add trusted domains to /var/www/html/config/config.php
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'instanceid' => 'oc9w2g0verl0',
'passwordsalt' => 'p+wNeVDQ0GA1UghAcN/VmsUAm1kDMV',
'secret' => '/vujqzqcegVy6GWz/eW6byJ/qBM0CJp6RcVbC9ExATzCnVen',
0 => '192.168.5.229:8899',
1 => 'my_external_ip_1:8899',
2 => 'my_external_ip_2:8899',
3 => 'my_external_ip_3:8899',
4 => 'my_external_ip_4:8899',
5 => '192.168.5.229:9999',
6 => 'my_external_ip_1:9999',
7 => 'my_external_ip_2:9999',
8 => 'my_external_ip_3:9999',
9 => 'my_external_ip_4:9999',
10 => '192.168.5.229:8999',
11 => 'my_external_ip_1:8999',
12 => 'my_external_ip_2:8999',
13 => 'my_external_ip_3:8999',
14 => 'my_external_ip_4:8999',
'version' => '25.0.2.3',
'overwrite.cli.url' => 'http://192.168.5.229:8899',
'dbname' => 'nextcloud',
'dbhost' => '127.0.0.1',
'dbuser' => 'oc_admin',
'dbpassword' => ' true,
). `Preformatted text`
3)
and this config to nginx:
upstream nextcloud {
server localhost:8899;
keepalive 100;
server {
listen 9999 ssl;
listen [::]:9999 ssl;
# server_name _;
server_name spacecraft.mywire.org;
# set max upload size
client_max_body_size 10G;
fastcgi_buffers 64 4K;
gzip off;
root /usr/share/nginx/html;
index index.html index.htm;
ssl_certificate /etc/nginx/ssl/chain.pem;
ssl_certificate_key /etc/nginx/ssl/key.pem;
access_log off;
location / {
root html;
proxy_pass http://nextcloud;
proxy_set_header HOST $host;
proxy_set_header X-Forwarded-Proto https;
proxy_set_header X-Forwarded-Ssl on;
location /accounts/logout {
proxy_no_cache 1;
proxy_cache_bypass 1;
add_header Last-Modified $date_gmt;
add_header Cache-Control 'no-cache, must-revalidate, proxy-revalidate, max-age=0';
if_modified_since off;
expires -1;
etag off;
4) Configure Apache to use 8899 for HTTP and 8999 for HTTPS
Warning no app in context Login failed: admin (Remote IP: 192.168.5.10) 2022-12-19T18:00:07+0300
Warning no app in context Login failed: admin (Remote IP: 192.168.5.1) 2022-12-19T12:46:19+0300
Warning no app in context Login failed: admin (Remote IP: 192.168.5.10) 2022-12-19T03:25:23+0300
Error PHP Error: exif_read_data(): File not supported at /var/www/html/lib/private/Metadata/Provider/ExifProvider.php#59 2022-12-18T23:06:26+0300
Warning no app in context Could not detect any host in https:///data/htaccesstest.txt 2022-12-18T23:06:10+0300
Warning no app in context Could not detect any host in http:///data/htaccesstest.txt 2022-12-18T23:06:10+0300
Warning no app in context Could not detect any host in https:///data/htaccesstest.txt 2022-12-18T23:00:19+0300
Warning no app in context Could not detect any host in http:///data/htaccesstest.txt 2022-12-18T23:00:19+0300
root@openmediavault:~# docker logs --follow nginx
/docker-entrypoint.sh: /docker-entrypoint.d/ is not empty, will attempt to perform configuration
/docker-entrypoint.sh: Looking for shell scripts in /docker-entrypoint.d/
/docker-entrypoint.sh: Launching /docker-entrypoint.d/10-listen-on-ipv6-by-default.sh
10-listen-on-ipv6-by-default.sh: info: /etc/nginx/conf.d/default.conf is not a file or does not exist
/docker-entrypoint.sh: Launching /docker-entrypoint.d/20-envsubst-on-templates.sh
/docker-entrypoint.sh: Launching /docker-entrypoint.d/30-tune-worker-processes.sh
/docker-entrypoint.sh: Configuration complete; ready for start up
192.168.5.10 - - [19/Dec/2022:16:43:03 +0000] "GET /apps/dashboard/ HTTP/1.1" 404 450 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36"
NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 Edg/108.0.1462.54"
192.168.5.1 - - [19/Dec/2022:17:11:01 +0000] "-" 408 511 "-" "-"
127.0.0.1 - - [19/Dec/2022:17:11:45 +0000] "PUT /ocs/v2.php/apps/user_status/api/v1/heartbeat?format=json HTTP/1.0" 400 13914 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36"
192.168.5.1 - - [19/Dec/2022:17:11:45 +0000] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 304 1339 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 Edg/108.0.1462.54"
192.168.5.1 - - [19/Dec/2022:17:12:05 +0000] "-" 408 511 "-" "-"
127.0.0.1 - - [19/Dec/2022:17:12:45 +0000] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.0" 400 13914 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36"
192.168.5.1 - - [19/Dec/2022:17:12:45 +0000] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 304 1339 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 Edg/108.0.1462.54"
192.168.5.1 - - [19/Dec/2022:17:13:05 +0000] "-" 408 511 "-" "-"
192.168.5.1 - - [19/Dec/2022:17:13:45 +0000] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 304 1339 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 Edg/108.0.1462.54"
192.168.5.1 - - [19/Dec/2022:17:14:05 +0000] "-" 408 511 "-" "-"
[Mon Dec 19 17:14:22.856439 2022] [mpm_prefork:notice] [pid 1] AH00170: caught SIGWINCH, shutting down gracefully
[Mon Dec 19 17:14:29.491099 2022] [ssl:warn] [pid 1] AH01909: openmediavault.local:8999:0 server certificate does NOT include an ID which matches the server name
[Mon Dec 19 17:14:29.517476 2022] [ssl:warn] [pid 1] AH01909: openmediavault.local:8999:0 server certificate does NOT include an ID which matches the server name
[Mon Dec 19 17:14:29.521232 2022] [mpm_prefork:notice] [pid 1] AH00163: Apache/2.4.54 (Debian) PHP/8.1.13 OpenSSL/1.1.1n configured -- resuming normal operations
[Mon Dec 19 17:14:29.521267 2022] [core:notice] [pid 1] AH00094: Command line: 'apache2 -D FOREGROUND'
192.168.5.1 - - [19/Dec/2022:17:14:45 +0000] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 304 4908 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 Edg/108.0.1462.54"
192.168.5.1 - - [19/Dec/2022:17:15:05 +0000] "-" 408 511 "-" "-"
192.168.5.1 - - [19/Dec/2022:17:15:41 +0000] "PUT /ocs/v2.php/apps/user_status/api/v1/heartbeat?format=json HTTP/1.1" 200 1462 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 Edg/108.0.1462.54"
192.168.5.1 - - [19/Dec/2022:17:15:45 +0000] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 304 830 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 Edg/108.0.1462.54"
127.0.0.1 - - [19/Dec/2022:17:15:48 +0000] "GET /csrftoken HTTP/1.0" 400 13914 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36"
192.168.5.1 - - [19/Dec/2022:17:16:01 +0000] "-" 408 511 "-" "-"
127.0.0.1 - - [19/Dec/2022:17:16:11 +0000] "GET /apps/dashboard/ HTTP/1.0" 400 13795 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:108.0) Gecko/20100101 Firefox/108.0"
127.0.0.1 - - [19/Dec/2022:17:16:11 +0000] "GET /js/core/merged-template-prepend.js?v=7cbb2a8a-0 HTTP/1.0" 400 13795 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:108.0) Gecko/20100101 Firefox/108.0"
127.0.0.1 - - [19/Dec/2022:17:16:11 +0000] "GET /cron.php HTTP/1.0" 400 13795 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:108.0) Gecko/20100101 Firefox/108.0"
127.0.0.1 - - [19/Dec/2022:17:16:14 +0000] "GET / HTTP/1.0" 400 13905 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36"
127.0.0.1 - - [19/Dec/2022:17:16:14 +0000] "GET /core/css/server.css?v=7cbb2a8a-0 HTTP/1.0" 200 26862 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36"
127.0.0.1 - - [19/Dec/2022:17:16:14 +0000] "GET /apps/theming/css/default.css?v=47354877-0 HTTP/1.0" 200 1515 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36"
127.0.0.1 - - [19/Dec/2022:17:16:14 +0000] "GET /core/css/guest.css?v=7cbb2a8a-0 HTTP/1.0" 200 5839 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36"
127.0.0.1 - - [19/Dec/2022:17:16:14 +0000] "GET /js/core/merged-template-prepend.js?v=7cbb2a8a-0 HTTP/1.0" 400 13905 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36"
127.0.0.1 - - [19/Dec/2022:17:16:15 +0000] "GET /core/img/favicon.ico HTTP/1.0" 200 3756 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36"
127.0.0.1 - - [19/Dec/2022:17:16:15 +0000] "GET /cron.php HTTP/1.0" 400 13905 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36"
