Help with Nextcloud accessing drives exactly every 30 seconds
Hi, I am new to self-hosting in general.
I am using TrueNas Scale community edition 25.04.2.4 and I have installed and setup Nextcloud through the app store, following the directions from this guide youtu.be/1rpeKWGoMRY
My server is an HP Elitedesk 800 G2 SFF PC, with a core i5-6500 and 8 gigs of RAM
Storage:
Summary
2x Toshiba e300 low power 2tb sata drives (mirrored in TrueNas, this is the main data storage)
2.5 inch hard drive for boot drive
My issue is that a Nextcloud service is preventing the hard drives from spinning down, as there is activity exactly every 30 seconds. When I disable Nextcloud through TrueNas, the drive activity stops.
Nextcloud events, accessed through TrueNas
2025-10-11 13:19:42.674196+00:00Configuring Redis as session handler
2025-10-11 13:19:42.749465+00:00=> Searching for hook scripts (*.sh) to run, located in the folder “/docker-entrypoint-hooks.d/before-starting”
2025-10-11 13:19:42.752247+00:00==> Running the script (cwd: /var/www/html): “/docker-entrypoint-hooks.d/before-starting/ix-update-hosts-script.sh”
2025-10-11 13:19:42.760672+00:00Updating database and redis host in config.php
2025-10-11 13:19:43.108545+00:00System config value redis => host set to string redis
2025-10-11 13:19:43.116105+00:00==> Finished executing the script: “/docker-entrypoint-hooks.d/before-starting/ix-update-hosts-script.sh”
2025-10-11 13:19:43.116583+00:00==> Running the script (cwd: /var/www/html): “/docker-entrypoint-hooks.d/before-starting/ix-update-trusted-domains-script.sh”
2025-10-11 13:19:43.124476+00:00Updating trusted domains. It will append new domains to the existing list.
2025-10-11 13:19:43.124502+00:00If you see a domain that is not longer valid, you need to manually remove it from the list in the config.php file.
2025-10-11 13:19:43.766088+00:00System config value trusted_domains deleted
2025-10-11 13:19:44.075281+00:00System config value trusted_domains => 0 set to string 127.0.0.1
2025-10-11 13:19:44.382439+00:00System config value trusted_domains => 1 set to string 192.168.5.255
2025-10-11 13:19:44.690867+00:00System config value trusted_domains => 2 set to string localhost
2025-10-11 13:19:45.016099+00:00System config value trusted_domains => 3 set to string nextcloud
2025-10-11 13:19:45.023890+00:00==> Finished executing the script: “/docker-entrypoint-hooks.d/before-starting/ix-update-trusted-domains-script.sh”
2025-10-11 13:19:45.023950+00:00=> Completed executing scripts in the “before-starting” folder
2025-10-11 13:19:45.053954+00:00AH00558: apache2: Could not reliably determine the server’s fully qualified domain name, using fdd0:0:0:1::4. Set the ‘ServerName’ directive globally to suppress this message
2025-10-11 13:19:45.068959+00:00AH00558: apache2: Could not reliably determine the server’s fully qualified domain name, using fdd0:0:0:1::4. Set the ‘ServerName’ directive globally to suppress this message
2025-10-11 13:19:45.141826+00:00[Sat Oct 11 13:19:45.141621 2025] [mpm_prefork:notice] [pid 1:tid 1] AH00163: Apache/2.4.65 (Debian) PHP/8.3.26 configured – resuming normal operations
2025-10-11 13:19:45.141881+00:00[Sat Oct 11 13:19:45.141675 2025] [core:notice] [pid 1:tid 1] AH00094: Command line: ‘apache2 -D FOREGROUND’
2025-10-11 13:19:47.205587+00:00127.0.0.1 - - [11/Oct/2025:13:19:46 +0000] “GET /status.php HTTP/1.1” 200 1035 “-” “curl/8.14.1”
2025-10-11 13:20:17.301317+00:00127.0.0.1 - - [11/Oct/2025:13:20:17 +0000] “GET /status.php HTTP/1.1” 200 1035 “-” “curl/8.14.1”
2025-10-11 13:20:47.418194+00:00127.0.0.1 - - [11/Oct/2025:13:20:47 +0000] “GET /status.php HTTP/1.1” 200 1035 “-” “curl/8.14.1”
2025-10-11 13:21:17.543692+00:00127.0.0.1 - - [11/Oct/2025:13:21:17 +0000] “GET /status.php HTTP/1.1” 200 1035 “-” “curl/8.14.1”
2025-10-11 13:21:47.664766+00:00127.0.0.1 - - [11/Oct/2025:13:21:47 +0000] “GET /status.php HTTP/1.1” 200 1035 “-” “curl/8.14.1”
2025-10-11 13:22:17.789290+00:00127.0.0.1 - - [11/Oct/2025:13:22:17 +0000] “GET /status.php HTTP/1.1” 200 1035 “-” “curl/8.14.1”
2025-10-11 13:22:47.902284+00:00127.0.0.1 - - [11/Oct/2025:13:22:47 +0000] “GET /status.php HTTP/1.1” 200 1035 “-” “curl/8.14.1”
2025-10-11 13:23:18.010275+00:00127.0.0.1 - - [11/Oct/2025:13:23:17 +0000] “GET /status.php HTTP/1.1” 200 1035 “-” “curl/8.14.1”
2025-10-11 13:23:48.126705+00:00127.0.0.1 - - [11/Oct/2025:13:23:48 +0000] “GET /status.php HTTP/1.1” 200 1035 “-” “curl/8.14.1”
2025-10-11 13:24:18.234723+00:00127.0.0.1 - - [11/Oct/2025:13:24:18 +0000] “GET /status.php HTTP/1.1” 200 1035 “-” “curl/8.14.1”
2025-10-11 13:24:48.327926+00:00127.0.0.1 - - [11/Oct/2025:13:24:48 +0000] “GET /status.php HTTP/1.1” 200 1035 “-” “curl/8.14.1”
2025-10-11 13:25:18.431124+00:00127.0.0.1 - - [11/Oct/2025:13:25:18 +0000] “GET /status.php HTTP/1.1” 200 1035 “-” “curl/8.14.1”
2025-10-11 13:25:48.537893+00:00127.0.0.1 - - [11/Oct/2025:13:25:48 +0000] “GET /status.php HTTP/1.1” 200 1035 “-” “curl/8.14.1”
These GET requests seem to be correlated with disk writes. I am new so I don’t really know where these GET requests come from or what to do with them.
I got around to installing a few apps, but I haven’t fully set them up yet.
occ app:list
  • activity: 5.0.0-dev.0
  • app_api: 32.0.0
  • circles: 32.0.0
  • comments: 1.22.0
  • contactsinteraction: 1.13.1
  • dav: 1.34.2
  • federation: 1.22.0
  • files: 2.4.0
  • files_reminders: 1.5.0
  • files_sharing: 1.24.0
  • files_trashbin: 1.22.0
  • files_versions: 1.25.0
  • firstrunwizard: 5.0.0-dev.0
  • guests: 4.5.2
  • logreader: 5.0.0-dev.0
  • memories: 7.7.0
  • notifications: 5.0.0-dev.0
  • oauth2: 1.20.0
  • photos: 5.0.0-dev.1
  • privacy: 4.0.0-dev.0
  • profile: 1.1.0
  • provisioning_api: 1.22.0
  • recognize: 10.0.4
  • richdocuments: 9.0.0
  • richdocumentscode: 25.4.504
  • serverinfo: 4.0.0-dev.0
  • settings: 1.15.1
  • sharebymail: 1.22.0
  • support: 4.0.0-dev.0
  • survey_client: 4.0.0-dev.0
  • systemtags: 1.22.0
  • text: 6.0.0-dev.0
  • theming: 2.7.0
  • updatenotification: 1.22.0
  • user_status: 1.12.0
  • viewer: 5.0.0-dev.0
  • weather_status: 1.12.0
  • webhook_listeners: 1.3.0
  • workflowengine: 2.14.0
  • admin_audit: 1.22.0
  • dashboard: 7.12.0 (installed 7.12.0)
  • encryption: 2.20.0
  • files_external: 1.24.0
  • twofactor_totp: 14.0.0
  • user_ldap: 1.23.0
This is the disk read and write graph from TrueNas. The pink line means write.
Where do these GET requests come from, and what do they do? How can I stop Nextcloud from writing to the drives every 30 seconds?
Thanks.
probably unrelated, occ config:list system
“system”: {
“htaccess1.RewriteBase”: “/”,
“memcache.local”: “\OC\Memcache\APCu”,
“apps_paths”: [
“path”: “/var/www/html/apps”,
“url”: “/apps”,
“writable”: false
“path”: “/var/www/html/custom_apps”,
“url”: “/custom_apps”,
“writable”: true
“memcache.distributed”: “\OC\Memcache\Redis”,
“memcache.locking”: “\OC\Memcache\Redis”,
“redis”: {
“host”: “REMOVED SENSITIVE VALUE”,
“password”: “REMOVED SENSITIVE VALUE”,
“port”: 6379
“upgrade.disable-web”: true,
“passwordsalt”: “REMOVED SENSITIVE VALUE”,
“secret”: “REMOVED SENSITIVE VALUE”,
“datadirectory”: “REMOVED SENSITIVE VALUE”,
“dbtype”: “pgsql”,
“version”: “32.0.0.13”,
“overwrite.cli.url”: “http://localhost”,
“dbname”: “REMOVED SENSITIVE VALUE”,
“dbhost”: “REMOVED SENSITIVE VALUE”,
“dbtableprefix”: “oc_”,
“dbuser”: “REMOVED SENSITIVE VALUE”,
“dbpassword”: “REMOVED SENSITIVE VALUE”,
“installed”: true,
“instanceid”: “REMOVED SENSITIVE VALUE”,
“htaccess.RewriteBase”: “/”,
“config_preset”: 2,
“defaultapp”: “”,
“memories.db.triggers.fcu”: true,
“memories.exiftool”: “/var/www/html/custom_apps/memories/bin-ext/exiftool-amd64-glibc”,
“memories.vod.path”: “/var/www/html/custom_apps/memories/bin-ext/go-vod-amd64”,
“memories.vod.ffmpeg”: “/usr/bin/ffmpeg”,
“memories.vod.ffprobe”: “/usr/bin/ffprobe”,
“app_install_overwrite”: ,
“loglevel”: 3,
“trusted_domains”: [
“127.0.0.1”,
“192.168.5.255”,
“localhost”,
“nextcloud”
Hello @Directive0-Frail8,
welcome to the Nextcloud community! :handshake:
this GET requests are caused by something external. your GET requests are coming from ip 127.0.0.1 - so this is either the system running your Nextcloud or your networking doesn’t expose the real-ip of the client. GET requests to the status.php sounds like a health check maybe used by TrueNas to check if the application is healthy - but you better ask truenas support.
@Directive0-Frail8, you might want to look under Apps → Advanced Settings in TrueNAS and see if there’s an option to reduce the health check interval or disable it. That should stop the disks from waking up constantly.
Marvin
Accuweb.Cloud Support Engineer
