Help with NAT Hairpinning in a Podman container
    • latest
    • Fedora 42 IoT
    • `Yes
    • On install
    • `I’m installing AIO using Podman, I followed the instructions here
I’m running nextcloud using podman quadlets following the guide linked above. I’m using a dynamic dns to access my web server but because my home network doesn’t allow NAT hairpinning I had to set a local dns entry on a pihole server I run. This just redirects my DDNS domain to the LAN ip of my server. The issue is when I try to enter a domain on the AIO install page, it errors with The domain is not reachable on Port 443 from within this container. Have you opened port 443/tcp in your router/firewall? If yes is the problem most likely that the router or firewall forbids local access to your domain. You can work around that by setting up a local DNS-server.
From the nextcloud aio container:
NOTICE: PHP message: Info: It seems like the ip-address of <domain name>.duckdns.org is set to an internal or reserved ip-address. (It was found to be set to '192.168.0.89')
From the domain check container:
2025-06-08 18:53:54: (../src/server.c.1974) server started (lighttpd/1.4.79)
Final Thoughts
I’m sure the issue has something to do with my networking and I’d love some help there, but if there’s a better way to install with Podman I’d be happy to reexamine my strategy here. Thanks!
Hi, please post this in this thread: Rootless Podman Quadlet · nextcloud/all-in-one · Discussion #3487 · GitHub
Alright will do!
