Hi there,
Trying to setup Nextcloud on my server. I believe it’s installed but it’s like the package is missing all CSS. Please advise.
Hi there,
As a follow-up if any of this information is helpful,
your nginx doesn’t serve the static content (aka css etc.al.)
you make check your nginx config file.
might be helpfull -> https://www.c-rieger.de/nextcloud-installation-guide-debian/#c02
in case you want to start over with a new server but without all the typing:
