Hello @wwe,
thanks for your reply.
I tested with a native user and you are right: app passwords work with 2FA enabled.
I tested again with a ldap user and found that you can create app passwords and they work with 2FA disabled (app deactivated).
With ldap user and 2FA enabled I cannot connect with gvfs on my setup. I have to admit that I made a mistake in testing the davx connection and I will have to repeat this.
I found a similar thread with some work arounds but no real solution here:
https://help.nextcloud.com/t/app-passwords-not-working-2fa-enabled/163332
The nextcloud.log shows this on trying to connect:
{"reqId":"N8NkZU5OstjatcSTMjcS","level":0,"time":"2024-08-20T08:57:37+02:00","remoteAddr":"192.168.91.24","user":"--","app":"webdav","method":"OPTIONS","url":"/remote.php/dav/files/carota","message":"No public access to this resource., No 'Authorization: Basic' header found. Either the client didn't send one, or the server is misconfigured, No 'Authorization: Bearer' header found. Either the client didn't send one, or the server is mis-configured, No 'Authorization: Basic' header found. Either the client didn't send one, or the server is misconfigured","userAgent":"gvfs/1.54.2","version":"29.0.3.4","exception":{"Exception":"Sabre\\DAV\\Exception\\NotAuthenticated","Message":"No public access to this resource., No 'Authorization: Basic' header found. Either the client didn't send one, or the server is misconfigured, No 'Authorization: Bearer' header found. Either the client didn't send one, or the server is mis-configured, No 'Authorization: Basic' header found. Either the client didn't send one, or the server is misconfigured","Code":0,"Trace":[{"file":"/var/www/owncloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"beforeMethod","class":"Sabre\\DAV\\Auth\\Plugin","type":"->"},{"file":"/var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":456,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/owncloud/apps/dav/lib/Server.php","line":379,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/owncloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/owncloud/remote.php","line":172,"args":["/var/www/owncloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php","Line":152,"message":"No public access to this resource., No 'Authorization: Basic' header found. Either the client didn't send one, or the server is misconfigured, No 'Authorization: Bearer' header found. Either the client didn't send one, or the server is mis-configured, No 'Authorization: Basic' header found. Either the client didn't send one, or the server is misconfigured","exception":{},"CustomMessage":"No public access to this resource., No 'Authorization: Basic' header found. Either the client didn't send one, or the server is misconfigured, No 'Authorization: Bearer' header found. Either the client didn't send one, or the server is mis-configured, No 'Authorization: Basic' header found. Either the client didn't send one, or the server is misconfigured"}}
{"reqId":"uL2H4ISs5V9Ttw34UK7Q","level":0,"time":"2024-08-20T08:57:38+02:00","remoteAddr":"192.168.91.24","user":"--","app":"no app in context","method":"OPTIONS","url":"/remote.php/dav/files/carota","message":"The loading of lazy AppConfig values have been requested","userAgent":"gvfs/1.54.2","version":"29.0.3.4","exception":{"Exception":"RuntimeException","Message":"ignorable exception","Code":0,"Trace":[{"file":"/var/www/owncloud/lib/private/AppConfig.php","line":1208,"function":"loadConfig","class":"OC\\AppConfig","type":"->"},{"file":"/var/www/owncloud/lib/private/AppConfig.php","line":127,"function":"loadConfigAll","class":"OC\\AppConfig","type":"->"},{"file":"/var/www/owncloud/lib/private/AllConfig.php","line":196,"function":"getKeys","class":"OC\\AppConfig","type":"->"},{"file":"/var/www/owncloud/apps/user_ldap/lib/Helper.php","line":133,"function":"getAppKeys","class":"OC\\AllConfig","type":"->"},{"file":"/var/www/owncloud/apps/user_ldap/lib/Helper.php","line":74,"function":"getServersConfig","class":"OCA\\User_LDAP\\Helper","type":"->"},{"file":"/var/www/owncloud/apps/user_ldap/lib/AppInfo/Application.php","line":133,"function":"getServerConfigurationPrefixes","class":"OCA\\User_LDAP\\Helper","type":"->"},{"file":"/var/www/owncloud/lib/private/AppFramework/Bootstrap/FunctionInjector.php","line":45,"function":"OCA\\User_LDAP\\AppInfo\\{closure}","class":"OCA\\User_LDAP\\AppInfo\\Application","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/owncloud/lib/private/AppFramework/Bootstrap/BootContext.php","line":50,"function":"injectFn","class":"OC\\AppFramework\\Bootstrap\\FunctionInjector","type":"->"},{"file":"/var/www/owncloud/apps/user_ldap/lib/AppInfo/Application.php","line":124,"function":"injectFn","class":"OC\\AppFramework\\Bootstrap\\BootContext","type":"->"},{"file":"/var/www/owncloud/lib/private/AppFramework/Bootstrap/Coordinator.php","line":200,"function":"boot","class":"OCA\\User_LDAP\\AppInfo\\Application","type":"->"},{"file":"/var/www/owncloud/lib/private/App/AppManager.php","line":437,"function":"bootApp","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->"},{"file":"/var/www/owncloud/lib/private/App/AppManager.php","line":216,"function":"loadApp","class":"OC\\App\\AppManager","type":"->"},{"file":"/var/www/owncloud/lib/private/legacy/OC_App.php","line":128,"function":"loadApps","class":"OC\\App\\AppManager","type":"->"},{"file":"/var/www/owncloud/remote.php","line":155,"function":"loadApps","class":"OC_App","type":"::"}],"File":"/var/www/owncloud/lib/private/AppConfig.php","Line":1222,"message":"The loading of lazy AppConfig values have been requested","exception":{},"CustomMessage":"The loading of lazy AppConfig values have been requested"}}
{"reqId":"uL2H4ISs5V9Ttw34UK7Q","level":0,"time":"2024-08-20T08:57:38+02:00","remoteAddr":"192.168.91.24","user":"--","app":"user_ldap","method":"OPTIONS","url":"/remote.php/dav/files/carota","message":"Calling LDAP function ldap_explode_dn with parameters [\"carota\",0]","userAgent":"gvfs/1.54.2","version":"29.0.3.4","data":{"app":"user_ldap"}}
{"reqId":"uL2H4ISs5V9Ttw34UK7Q","level":0,"time":"2024-08-20T08:57:38+02:00","remoteAddr":"192.168.91.24","user":"--","app":"no app in context","method":"OPTIONS","url":"/remote.php/dav/files/carota","message":"Token is not valid: Token does not exist: token does not exist","userAgent":"gvfs/1.54.2","version":"29.0.3.4","exception":{"Exception":"OC\\Authentication\\Exceptions\\InvalidTokenException","Message":"Token does not exist: token does not exist","Code":0,"Trace":[{"file":"/var/www/owncloud/lib/private/Authentication/Token/Manager.php","line":135,"function":"getToken","class":"OC\\Authentication\\Token\\PublicKeyTokenProvider","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/owncloud/lib/private/User/Session.php","line":550,"function":"getToken","class":"OC\\Authentication\\Token\\Manager","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/owncloud/lib/private/User/Session.php","line":450,"function":"isTokenPassword","class":"OC\\User\\Session","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/owncloud/apps/dav/lib/Connector/Sabre/Auth.php","line":113,"function":"logClientIn","class":"OC\\User\\Session","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Auth/Backend/AbstractBasic.php","line":103,"function":"validateUserPass","class":"OCA\\DAV\\Connector\\Sabre\\Auth","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/owncloud/apps/dav/lib/Connector/Sabre/Auth.php","line":231,"function":"check","class":"Sabre\\DAV\\Auth\\Backend\\AbstractBasic","type":"->"},{"file":"/var/www/owncloud/apps/dav/lib/Connector/Sabre/Auth.php","line":138,"function":"auth","class":"OCA\\DAV\\Connector\\Sabre\\Auth","type":"->"},{"file":"/var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php","line":179,"function":"check","class":"OCA\\DAV\\Connector\\Sabre\\Auth","type":"->"},{"file":"/var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php","line":135,"function":"check","class":"Sabre\\DAV\\Auth\\Plugin","type":"->"},{"file":"/var/www/owncloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"beforeMethod","class":"Sabre\\DAV\\Auth\\Plugin","type":"->"},{"file":"/var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":456,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/owncloud/apps/dav/lib/Server.php","line":379,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/owncloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/owncloud/remote.php","line":172,"args":["/var/www/owncloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/owncloud/lib/private/Authentication/Token/PublicKeyTokenProvider.php","Line":181,"Previous":{"Exception":"OCP\\AppFramework\\Db\\DoesNotExistException","Message":"token does not exist","Code":0,"Trace":[{"file":"/var/www/owncloud/lib/private/Authentication/Token/PublicKeyTokenProvider.php","line":173,"function":"getToken","class":"OC\\Authentication\\Token\\PublicKeyTokenMapper","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/owncloud/lib/private/Authentication/Token/Manager.php","line":135,"function":"getToken","class":"OC\\Authentication\\Token\\PublicKeyTokenProvider","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/owncloud/lib/private/User/Session.php","line":550,"function":"getToken","class":"OC\\Authentication\\Token\\Manager","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/owncloud/lib/private/User/Session.php","line":450,"function":"isTokenPassword","class":"OC\\User\\Session","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/owncloud/apps/dav/lib/Connector/Sabre/Auth.php","line":113,"function":"logClientIn","class":"OC\\User\\Session","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Auth/Backend/AbstractBasic.php","line":103,"function":"validateUserPass","class":"OCA\\DAV\\Connector\\Sabre\\Auth","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/owncloud/apps/dav/lib/Connector/Sabre/Auth.php","line":231,"function":"check","class":"Sabre\\DAV\\Auth\\Backend\\AbstractBasic","type":"->"},{"file":"/var/www/owncloud/apps/dav/lib/Connector/Sabre/Auth.php","line":138,"function":"auth","class":"OCA\\DAV\\Connector\\Sabre\\Auth","type":"->"},{"file":"/var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php","line":179,"function":"check","class":"OCA\\DAV\\Connector\\Sabre\\Auth","type":"->"},{"file":"/var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php","line":135,"function":"check","class":"Sabre\\DAV\\Auth\\Plugin","type":"->"},{"file":"/var/www/owncloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"beforeMethod","class":"Sabre\\DAV\\Auth\\Plugin","type":"->"},{"file":"/var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":456,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/owncloud/apps/dav/lib/Server.php","line":379,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/owncloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/owncloud/remote.php","line":172,"args":["/var/www/owncloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/owncloud/lib/private/Authentication/Token/PublicKeyTokenMapper.php","Line":97},"message":"Token is not valid: Token does not exist: token does not exist","exception":{},"CustomMessage":"Token is not valid: Token does not exist: token does not exist"}}
{"reqId":"uL2H4ISs5V9Ttw34UK7Q","level":0,"time":"2024-08-20T08:57:38+02:00","remoteAddr":"192.168.91.24","user":"--","app":"webdav","method":"OPTIONS","url":"/remote.php/dav/files/carota","message":"Exception thrown: OCA\\DAV\\Connector\\Sabre\\Exception\\PasswordLoginForbidden","userAgent":"gvfs/1.54.2","version":"29.0.3.4","exception":{"Exception":"OCA\\DAV\\Connector\\Sabre\\Exception\\PasswordLoginForbidden","Message":"","Code":0,"Trace":[{"file":"/var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Auth/Backend/AbstractBasic.php","line":103,"function":"validateUserPass","class":"OCA\\DAV\\Connector\\Sabre\\Auth","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/owncloud/apps/dav/lib/Connector/Sabre/Auth.php","line":231,"function":"check","class":"Sabre\\DAV\\Auth\\Backend\\AbstractBasic","type":"->"},{"file":"/var/www/owncloud/apps/dav/lib/Connector/Sabre/Auth.php","line":138,"function":"auth","class":"OCA\\DAV\\Connector\\Sabre\\Auth","type":"->"},{"file":"/var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php","line":179,"function":"check","class":"OCA\\DAV\\Connector\\Sabre\\Auth","type":"->"},{"file":"/var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php","line":135,"function":"check","class":"Sabre\\DAV\\Auth\\Plugin","type":"->"},{"file":"/var/www/owncloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"beforeMethod","class":"Sabre\\DAV\\Auth\\Plugin","type":"->"},{"file":"/var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":456,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/owncloud/apps/dav/lib/Server.php","line":379,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/owncloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/owncloud/remote.php","line":172,"args":["/var/www/owncloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/owncloud/apps/dav/lib/Connector/Sabre/Auth.php","Line":123,"message":"","exception":{},"CustomMessage":"Exception thrown: OCA\\DAV\\Connector\\Sabre\\Exception\\PasswordLoginForbidden"}}
