Help understanding scheduled background tasks as they relate to performance?
    • 31.0.7
    • Ubuntu 24.04.2
    • Apache 2.4.65
    • Apache 2.4.65
    • 8.3.23
    • Yes
    • Months
    • Bare Metal
My infrastructure was on under-powered hardware that has since been migrated to properly scaled hardware. A recurring issue I was experiencing was periodic overnight extreme resource loads; I had assumed this was due to the limited hardware, but it is persisting now that I should have no hardware limit. For example, last night at Midnight, my web server and database went into a period of extreme CPU load which took hours to resolve, and actualy disrupted my monitoring for several hours:
Going back 3 months, the spikes seem to happen roughly every 3-4 days:
I have looked into tasks for the web user, the DB user, inside the sql database, but I cannot find a list of recurring maintenance tasks other than the “cron” cronjob running as the apache user on the nextcloud web server, which handles many more tasks than just this periodic spike. I also think it may be mysql tuning, through I’ve been through a lot of mysql tuning and it seems to not be helping; it’s a separate mysql server well-resourced and on flash storage.
I’m looking for help identifying and mitigating the cyclic task that is causing resource spiking impacting the function of the DB server.
Nothing, this is a cyclically recurring issue
There are some log entries about query timeouts exceeded, but nothing specific about what queries they are.
MySQL
There are some errors in the logs
---TRANSACTION 131813048, ACTIVE (PREPARED) 3 sec
mysql tables in use 1, locked 1
2 lock struct(s), heap size 1128, 1 row lock(s), undo log entries 1
MySQL thread id 34342, OS thread handle 131120923432640, query id 868327 sr66-nxt-01.sub.domain.com xx.xx.xx.207 usr_nextcloud waiting for handler commit
UPDATE `oc_preferences` SET `configvalue` = '1754293298', `lazy` = 0, `type` = 0, `flags` = 0, `indexed` = '' WHERE (`userid` = '6c7cc23e-52c9-103b-8e51-0fc031bcb58e') AND (`appid` = 'login') AND (`configkey` = 'lastLogin')
---TRANSACTION 131813047, ACTIVE (PREPARED) 57 sec
MySQL thread id 34241, OS thread handle 131120794339008, query id 868262 sr66-nxt-01.sub.domain.com xx.xx.xx.207 usr_nextcloud waiting for handler commit
UPDATE `oc_jobs` SET `reserved_at` = '1754293244', `last_checked` = '1754293244' WHERE (`id` = '2195') AND (`reserved_at` = '0') AND (`last_checked` = '1754291151')
---TRANSACTION 131813046, ACTIVE (PREPARED) 57 sec
MySQL thread id 34310, OS thread handle 131119778346688, query id 868258 sr66-nxt-01.sub.domain.com xx.xx.xx.207 usr_nextcloud waiting for handler commit
UPDATE `oc_authtoken` SET `last_check` = 1754293244, `last_activity` = 1754293244 WHERE `id` = 468
---TRANSACTION 131813045, ACTIVE (PREPARED) 57 sec
MySQL thread id 34273, OS thread handle 131120791176896, query id 868243 sr66-nxt-01.sub.domain.com xx.xx.xx.207 usr_nextcloud waiting for handler commit
UPDATE `oc_appconfig` SET `configvalue` = '4876', `lazy` = 0, `type` = 2 WHERE (`appid` = 'backgroundjob') AND (`configkey` = 'lastjob')
---TRANSACTION 131813043, ACTIVE (PREPARED) 57 sec
MySQL thread id 34304, OS thread handle 131120796448448, query id 868239 sr66-nxt-01.sub.domain.com xx.xx.xx.207 usr_nextcloud waiting for handler commit
UPDATE `oc_jobs` SET `last_run` = 1754293244 WHERE `id` = 21
            "sub.domain.com",
            "domain.com",
            "nextcloud.domain.com",
            "sr66-nxt-01.sub.domain.com"
        "dbtype": "mysql",
        "defaultapp": "files",
        "version": "31.0.7.1",
        "overwritehost": "nextcloud.domain.com",
        "overwriteprotocol": "https",
        "overwritewebroot": "\/",
        "overwrite.cli.url": "https:\/\/nextcloud.domain.com",
        "htaccess.RewriteBase": "\/",
        "dbport": "",
        "mysql.utf8mb4": true,
        "theme": "",
        "localstorage.umask": 2,
        "log_type": "file",
        "logfile": "\/var\/log\/nextcloud\/nextcloud.log",
        "loglevel": 2,
        "mail_smtpmode": "sendmail",
        "mail_sendmailmode": "smtp",
        "mail_smtpport": "25",
        "default_phone_region": "US",
       "app_install_overwrite": [],
        "trashbin_retention_obligation": "auto,15",
        "mail_smtpsecure": "ssl",
        "filelocking.enabled": "true",
        "redis": {
            "port": 0,
            "dbindex": 0,
            "timeout": 1.5
        "enforce_theme": "",
        "maintenance_window_start": 9
  - activity: 4.0.0
  - admin_audit: 1.21.0
  - app_api: 5.0.2
  - bruteforcesettings: 4.0.0
  - calendar: 5.3.8
  - circles: 31.0.0
  - comments: 1.21.0
  - contacts: 7.2.3
  - contactsinteraction: 1.12.0
  - dashboard: 7.11.0
  - dav: 1.33.0
  - federation: 1.21.0
  - files: 2.3.1
  - files_3dmodelviewer: 0.0.15
  - files_downloadlimit: 4.0.0
  - files_external: 1.23.0
  - files_pdfviewer: 4.0.0
  - files_reminders: 1.4.0
  - files_sharing: 1.23.1
  - files_trashbin: 1.21.0
  - files_versions: 1.24.0
  - firstrunwizard: 4.0.0
  - logreader: 4.0.0
  - mail: 5.1.10
  - notes: 4.12.2
  - notifications: 4.0.0
  - oauth2: 1.19.1
  - password_policy: 3.0.0
  - photos: 4.0.0
  - privacy: 3.0.0
  - profile: 1.0.0
  - provisioning_api: 1.21.0
  - related_resources: 2.0.0
  - richdocuments: 8.7.3
  - serverinfo: 3.0.0
  - settings: 1.14.0
  - sharebymail: 1.21.0
  - spreed: 21.1.2
  - support: 3.0.0
  - survey_client: 3.0.0
  - suspicious_login: 9.0.1
  - systemtags: 1.21.1
  - tables: 0.9.5
  - tasks: 0.16.1
  - text: 5.0.0
  - theming: 2.6.1
  - theming_customcss: 1.18.0
  - updatenotification: 1.21.0
  - user_ldap: 1.22.0
  - user_status: 1.11.0
  - viewer: 4.0.0
  - weather_status: 1.11.0
  - webhook_listeners: 1.2.0
  - workflowengine: 2.13.0
  - encryption: 2.19.0 (installed 2.10.0)
  - epubviewer: 1.8.0 (installed 1.8.0)
  - files_texteditor: 2.15.1 (installed 2.15.1)
  - ldap_write_support: 1.13.0 (installed 1.13.0)
  - printer: 0.0.5 (installed 0.0.5)
  - recommendations: 4.0.0 (installed 3.0.0)
The oc_jobs table should contain a bit of information of all the background jobs Nextcloud is running, including when a job was run for the last time and how long it took.
With the very resource intensive jobs that do not run all the time, with the last date executed, it should be possible to identify them.
From your logs, you can already check what ids 2195 and 21 refer to.
2195 is “OCA\Mail\BackgroundJob\DraftsJob” which is strange, I’m not using mail in Nextcloud and should have no drafts, unless that job is something else.
21 is “OCA\Files\BackgroundJob\CleanupFileLocks” which is more interesting; the main bugs in my logs are file access issues. Since I share the home folder of a bunch of my users (over nfs), and www-data has its id synced across all my systems, and is in the group for all the users, for anything without group read permissions I get errors, which has always been expected.
I’ve searched for a way to exclude “.local” from the home directories of the users, but the previous exclude files plugin has been abandoned. I have a few symlinks as well (users have a few directories which are synced with syncthing, then the dotfiles are symlinked to those) and symlinks are an issue.
I still am not sure how to figure out what the specific issue is if it’s those jobs. I don’t want to add www-data to .local on that nfs share.
