Found this error message in the next logs :
{"Exception":"Doctrine\\DBAL\\Exception","Message":"Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [2054] Server sent charset (0) unknown to the client. Please, report to the developers","Code":2054,"Trace":[{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1654,"function":"connect","class":"OC\\DB\\Connection","type":"->","args":[]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1081,"function":"getWrappedConnection","class":"Doctrine\\DBAL\\Connection","type":"->","args":[]},{"file":"/var/www/html/lib/private/DB/Connection.php","line":261,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[],null]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":337,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[],null]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":377,"function":"executeQuery","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":280,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppConfig.php","line":421,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppConfig.php","line":187,"function":"loadConfigValues","class":"OC\\AppConfig","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppConfig.php","line":377,"function":"getApps","class":"OC\\AppConfig","type":"->","args":[]},{"file":"/var/www/html/lib/private/App/AppManager.php","line":128,"function":"getValues","class":"OC\\AppConfig","type":"->","args":[false,"enabled"]},{"file":"/var/www/html/lib/private/App/AppManager.php","line":149,"function":"getInstalledAppsValues","class":"OC\\App\\AppManager","type":"->","args":[]},{"file":"/var/www/html/lib/private/legacy/OC_App.php","line":231,"function":"getInstalledApps","class":"OC\\App\\AppManager","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppFramework/Bootstrap/Coordinator.php","line":90,"function":"getEnabledApps","class":"OC_App","type":"::","args":[]},{"file":"/var/www/html/lib/base.php","line":700,"function":"runInitialRegistration","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->","args":[]},{"file":"/var/www/html/lib/base.php","line":1200,"function":"init","class":"OC","type":"::","args":[]},{"file":"/var/www/html/index.php","line":37,"args":["/var/www/html/lib/base.php"],"function":"require_once"}],"File":"/var/www/html/lib/private/DB/Connection.php","Line":139,"message":"Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [2054] Server sent charset (0) unknown to the client. Please, report to the developers","exception":{},"CustomMessage":"Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [2054] Server sent charset (0) unknown to the client. Please, report to the developers"}
