We just released 9.0.58 RC1, 10.0.5RC2 as well as 11.0.3RC2. These release candidates do fix a lot of issues and add some small enhancements. To make sure everything works as expected in your environment, weād greatly appreciate your help to test it.
While we expect the release not to eat any data and be stable, the usual disclaimer is still valid: Make sure to have backups before updating!
Once youāve done that you can download the release candidates, either use the URLs defined below to manually update or use the built-in updater and specify the ābetaā channel.
9.0.58 RC1
[details=Changelog and download]
https://download.nextcloud.com/server/prereleases/nextcloud-9.0.58RC1.zip
https://download.nextcloud.com/server/prereleases/nextcloud-9.0.58RC1.tar.bz2
9.0.58
Server
- Replace unecessary unescaped prints with print (server/4226)
User_SAML
- Bump to php-saml 2.10.5 (user_saml/102)[/details]
###10.0.5 RC2
https://download.nextcloud.com/server/prereleases/nextcloud-10.0.5RC2.zip
https://download.nextcloud.com/server/prereleases/nextcloud-10.0.5RC2.tar.bz2
10.0.5
Server
- Fix typo in advertisment footer (server/3664)
- Fix branding and show Nextcloud (server/3970)
- Make sure transparency is an integer when saving a calendar (server/4168)
- Reduce error message text (server/4227)
- Fix LDAP description (server/4239)
User_SAML
- Bump to php-saml 2.10.5 (user_saml/101)
11.0.3 RC2
https://download.nextcloud.com/server/prereleases/nextcloud-11.0.3RC2.zip
https://download.nextcloud.com/server/prereleases/nextcloud-11.0.3RC2.tar.bz2
11.0.3
Server
- Use the correct principal for shared addressbooks (server/3608)
- Fix saving backup codes by using a correct data uri (server/3652)
- Update icewind/streams to 0.5.2 (server/3293)
- Fix string comparison and return docs (server/3665)
- Typecast shared mountās storage_id to int as documented + some refactor to avoid similar bugs (server/3658)
- Use a proper date format for transfer ownership (server/3700)
- DAV sharing permissions should not depend on the order (server/3722)
- Add new user agent of windows 10 dav backend (server/3764)
- Add back appstoreenabled config switch (server/3767)
- Call right function after sudo mode (server/3820)
- Dont allow empty wildcard search (server/3842)
- Remove single quotes around search query like in user search (server/3849)
- Fix mimetype detection on public uploads for the workflow engine (server/3765)
- Fix branding and show Nextcloud (server/3969)
- Fix reshare with user activity message (server/3981)
- Create correct VCard and return correct error codes (server/4029)
- Prevent migration from ownCloud 10 to Nextcloud 11 (server/3415)
- Make sure transparency is an integer when saving a calendar (server/4167)
- Make public links work with master key (server/4207)
- Donāt try to render the avatars if avatars are disabled (server/4214)
- Reduce error message text (server/4228)
- Donāt list on public calendar endpoints (server/4229)
- Fix upload of folders in Chrome (server/4154)
- Make sure blob columns are correctly converted as parameters (server/4233)
- Save the scope of an auth token in the session (server/4225)
- Take share by mail into consideration if we calculate the access list (server/4242)
- Also add the root of external storages to the file id list (server/4237)
- Fix LDAP description (server/4238)
- Remove the double password confirmation on changing cron (server/4236)
- Fix scheduling plugin on legacy caldav endpoint (server/4235)
- Directly fix invalid values of DTEND and DTSTART (server/4234)
- Make JobList::next() lock free (server/4254)
- Donāt remove owner property for public calendars (server/4272)
- Add capabilities for share by mail (server/4251)
- Dont use the permissions mask while scanning (server/4278)
- Add missing maintenance plugin to new DAV endpoint (server/4290)
- Fix bug with shared_by for own calendars if shared (server/4301)
Activity
- Fix activities for āFiles dropā on external storages (activity/118)
User_SAML
- Bump to php-saml 2.10.5 (user_saml/100)
Logreader
- Small screen layout improvements (logreader/2bcd915969386ceb77c7f91dfd5fc19fd3212346
- Fix log filtering (logreader/4095dfc62dcceb3c59a3f581baa5589737d0e6f3)
- Greatly speedup log iteration (logreader/71a4c6849641f821e80d96674c57a69fe7a8aa9e)
- Search more rows (logreader/b9d00b5599ac8a76862895266f1c23096391aad8)
- Stop iterating if we dont have a valid file handle (logreader/a87a8e653ecae5efef6342e645b98f2878219c87)
- Donāt return a LogIterator on a broken handle (logreader/39069108f99d463b1cb8bc944f3ef24324b9f43d)
- More robust log iteration (logreader/c0eb04d55bf1dee94ef523dae0e3b0e6afc272a6)
- Use proper iso date format (logreader/13a31181a6d72d084797a71f49f2c5edee8c8dae)
- Automatically try to fix some common escape errors from copy-pasted log entries (logreader/031db2a7f9b9f8cee42acf6eae7d993d31d4660a)
- Fix stack trace parsing of incorrectly escaped logentries (logreader/538667770edfdd48374ef33e9c15498ed98ece60)
- Highlight entries from the same request when clicking on an entry (logreader/2d1ccd0e4cca32220fcbe0b4d79d1cd23f0e73a5)
- Fix copy paste info searchfield (logreader/0e91b2f46649a720feb7c3b6b8266b8657db5574)
- Fix reset search after 0 results (logreader/50bec8ecf7edd81cfb96a35089283c0d879b41f3)
- Allow searching for requestId and user (logreader/7f84e55bb4a1e4086ab0918a6bf58ad3885bbd91)
- Allow searching in url (logreader/7833d97cf85fd351d2f7550d67d21bd0c2a815f4)
- Fix infinite scroll (logreader/cbe874c6c068b9156ad8456edf31d112da40cbc9)
- Dont show loading indicator if we already have entries (logreader/d26a08dc0540126177e8d20c3e243b44c5a399c4)
Gallery
- Fix upload after core changes (gallery/b4ac4429841cfe2b7ea260dfb37fcde25580143c)
If you encounter any issues, please leave a comment here and file an issue at https://github.com/nextcloud/server/issues (or the appropriate repository of the component)
Thanks to all the awesome people that contributed in some way to this release! Be it with coding, translating, helping people, filing issues, etc.
Keep rocking
