Hey everyone,
we just released the release candidates for the next maintenance releases that are planned next week.
Those release candidates are available as of now on the beta channels of the updater server.
We would like to ask you to test those release candidates and report issues here or in the issue tracker on github: https://github.com/nextcloud/server.
Happy testing!
16.0.1 RC 1
- Fix setupcheck for intl module (server#15223)
- Take return of mkdir into consideration; photocache to not create a folder for deletion (server#15303)
- Remove the custom prefix from the table name length when checking on β¦ (server#15312)
- Check if the data is in the lookup server (server#15341)
- Do NOT assume all files are selected if the first checkbox is (server#15345)
- Fix collapse button in app navigation in IE11 (server#15389)
- Make sure all middlewares are only registered once (server#15399)
- Allow to send the password of protected conversations (server#15405)
- Remove extra margin from warning messages in authenticate page (server#15409)
- Set Edge < 16 as incompatible with css vars (server#15417)
- Remove extra param in cache update call (server#15418)
- Handle 0 B default quota properly in the web UI (server#15424)
- Fix multiselect min width (server#15433)
- Make access column a real boolean (server#15434)
- Fix public upload by also load the semaphore method (server#15439)
- Remove setup args from logging (server#15442)
- Use non-absolute logout URL to fix wrong URL in reverse proxy scenario (server#15452)
- Fix mobile vertical scrolling (server#15469)
- Remove recommendation for opcache on CLI (server#15471)
- Update file-upload.js (server#15482)
- Only call setViewerMode if FileList is available (files_pdfviewer#132)
- Use correct CSS URL, remove default marked settings and change to GFM rendering (files_texteditor#150)
- Use correct method to determine if HTTPS is used (firstrunwizard#189)
15.0.8 RC 1
- Reconnect to DB after timeout for Notify command. Fixes #14479 (server#15006)
- Respect the setting if the lookup server is disabled (server#15021)
- Disable the injected snapper logic when apps want to ship their own (server#15046)
- Do not allow invalid users to be created (server#15071)
- Prevent a reinstall (server#15112)
- Do not use spaces in generated passwords (server#15119)
- Improve the share link password error feedback with a red border (server#15128)
- Use slient option to switch for regular file actions as well (server#15131)
- Backport/15129/stable15 (server#15139)
- Load apps before running repair steps (server#15158)
- Always use a temp file for swift writes (server#15205)
- Prefetching blows up if there are a lot of files. (server#15206)
- Take return of mkdir into consideration; photocache to not create a folder for deletion (server#15307)
- [Security] Bump tar from 4.4.1 to 4.4.8 in /apps/oauth2 (server#15332)
- [Security] Bump tar from 4.4.1 to 4.4.8 in /apps/accessibility (server#15333)
- [Security] Bump tar from 4.4.1 to 4.4.8 in /apps/updatenotification (server#15334)
- Check if the data is in the lookup server (server#15342)
- Do NOT assume all files are selected if the first checkbox is (server#15346)
- Remove orphan event and contacts data (server#15387)
- Fix collapse button in app navigation in IE11 (server#15390)
- Set Edge < 16 as incompatible with css vars (server#15421)
- Handle 0 B default quota properly in the web UI (server#15425)
- Remove setup args from logging (server#15443)
- Use non-absolute logout URL to fix wrong URL in reverse proxy scenario (server#15456)
- Remove recommendation for opcache on CLI (server#15472)
- Update file-upload.js (server#15485)
- Fix missing translation for βHome folderβ (activity#362)
- Only call setViewerMode if FileList is available (files_pdfviewer#133)
- Use correct CSS URL, remove default marked settings and change to GFM rendering (files_texteditor#151)
- Fix drone (firstrunwizard#186)
14.0.11 RC 1
- Reconnect to DB after timeout for Notify command. Fixes #14479 (server#15007)
- [3rdparty] Bump sabre to 3.2.3 (server#15070)](https://github.com/nextcloud/server/pull/15070)
- Do not allow invalid users to be created (server#15072)
- Do not use spaces in generated passwords (server#15120)
- Backport/15129/stable14 (server#15140)
- Load apps before running repair steps (server#15159)
- Prefetching blows up if there are a lot of files. (server#15207)
- [Security] Bump tar from 4.4.1 to 4.4.8 in /apps/updatenotification (server#15329)
- [Security] Bump tar from 4.4.1 to 4.4.8 in /apps/accessibility (server#15330)
- [Security] Bump tar from 4.4.1 to 4.4.8 in /apps/oauth2 (server#15331)
- [Security] Bump tar from 4.4.1 to 4.4.8 in /settings (server#15335)
- Check if the data is in the lookup server (server#15343)
- Do NOT assume all files are selected if the first checkbox is (server#15347)
- Fix collapse button in app navigation in IE11 (server#15391)
- Set Edge < 16 as incompatible with css vars (server#15423)
- Remove setup args from logging (server#15444)
- Remove recommendation for opcache on CLI (server#15473)
- Update file-upload.js (server#15484)
- Bump sabre/dav to 3.2.3 (3rdparty#266)
- Use correct CSS URL, remove default marked settings and change to GFM rendering (files_texteditor#152)
- Do not call invalid function (survey_client#92)
