Help setting up Apache2 site configuration to pointing to subdomain
I’m new to NextCloud and has just installed it on my own server. I really like it but I have problems setting up the nextcloud.conf (Apache2 Site configuration) to directing to my subdomain: https://cloud.mydomain.net
I’m also new to Apache so i’m sorry if it is a simple Apache configuration question. I have searched online but can’t find a solution that works for me.
Here is my setup:
  • Running my nextcloud server on a Debian 10 machine
  • The nextcloud folder is located at /var/www/html/nextcloud
My nextcloud.conf contains this
<VirtualHost *:80>
       ServerName cloud.mydomain.net
       Redirect permanent / https://cloud.mydomain.net
    </VirtualHost>
    <VirtualHost *:443>
      ServerAdmin admin@example.com
      DocumentRoot /var/www/html/nextcloud/
      Alias /nextcloud "/var/www/html/nextcloud/"
      <Directory /var/www/html/nextcloud/>
        Options +FollowSymlinks
        AllowOverride All
       <IfModule mod_headers.c>
         Header always set Strict-Transport-Security "max-age=15552000; includeSubDomains; preload"
       </IfModule>
       <IfModule mod_dav.c>
         Dav off
       </IfModule>
       SetEnv HOME /var/www/html/nextcloud
       SetEnv HTTP_HOME /var/www/html/nextcloud
      </Directory>
    </VirtualHost>
I have no problems reaching the nextcloud webinterface on https://cloud.mydomain.net/nextcloud/. But what should I do to access it on https://cloud.mydomain.net?
What do I do wrong? Is it my Apache site configuration file that is setup wrong? Or is it something else?
Again, sorry if it is a rudimental issue but all help is highly appreciated.This text will be hidden
What do you get when you laod https://cloud.mydomain.net?
If I get a servername/domain/subdomain for the nextcloud itself (what i highly recommend) then i leave the Alias line out.
Thanks for your reply.
I get redirected to: https://cloud.mydomain.net/login and it says:
## Internal Server Error
The server was unable to complete your request.
If this happens again, please send the technical details below to the server administrator.
If I remove the Alias line. I get a 500 Internal server Error page.
Then I’d recommend you to enable the log:
ErrorLog ${APACHE_LOG_DIR}/nextcloud_error.log
CustomLog ${APACHE_LOG_DIR}/nextcloud_access.log combined
I put them between ServerName and Alias, but I dont think the place realy matters.
Then you can read the errorlog sudo less /var/log/apache2/nextcloud_error.log
Please share the content with us - perhaps even with the solution to it :wink:
Thanks for the suggestion.
I have added the lines between ServerName and Alias. However, the nextcloud_error.log is empty.
BTW - should I have placed my nextcloud folder in /var/www/ instead of /var/www/html/?
Okay, now the error log contains:
[Sun Jun 07 13:02:21.573603 2020] [core:error] [pid 20230] [client 192.168.1.1:22435] AH00124: Request exceeded the limit of 10 internal redirects due to probable configuration error. Use 'LimitInternalRecursion' to increase the limit if necessary. Use 'LogLevel debug' to get a backtrace.
[Sun Jun 07 13:02:23.803628 2020] [core:error] [pid 20231] [client 192.168.1.1:1500] AH00124: Request exceeded the limit of 10 internal redirects due to probable configuration error. Use 'LimitInternalRecursion' to increase the limit if necessary. Use 'LogLevel debug' to get a backtrace.
[Sun Jun 07 13:02:31.678932 2020] [core:error] [pid 20233] [client 192.168.1.1:58831] AH00124: Request exceeded the limit of 10 internal redirects due to probable configuration error. Use 'LimitInternalRecursion' to increase the limit if necessary. Use 'LogLevel debug' to get a backtrace.
I don’t know if that helps?
Ah yes. I havent recognize that in your conifg.
I’d recommend to put nextcloud in /var/www/nextcloud directly and chang the nextcloud.conf file. You can then disable the site 000-default.conf by sudo a2dissite 000-default.conf. That site is in the folder /var/www/html.
Change your redirect in the http (*:80) section.
    RewriteEngine On
    RewriteCond %{HTTPS} off
    RewriteCond %{REQUEST_URI} !^/.well-known
    RewriteRule (.*) https://%{HTTP_HOST}%{REQUEST_URI} [NC,NE,R=permanent,L]
The line with .well-known is to allow certbot automatic renewals.
Once your site is working you might want to setup php-fpm, which will give a good performance boost.
Okay, can I just use the mv -R command or will the settings in the nextcloud setup be broke if I manually move the folder?
Thanks for the suggestion. I have inserted in the *:80 section.
I’d recommend you to cange a line in /var/www/nextcloud/config/config.php
Thanks for your help.
Now I have:
  • Moved the folder “sudo mv /var/www/html/nextcloud /var/www/nextcloud”
  • Changed the path my nextcloud.conf to /var/www/nextcloud
  • Disabled the default site
  • Set the parameters in the nextcloud config to: ‘overwrite.cli.url’ => ‘https://cloud.mydomain.net/’,
    ‘htaccess.RewriteBase’ => ‘/’,
  • Reloaded Apache “sudo systemctl reload apache2”
However, it still doesn’t work. I get the internal error message. And if I go to https://cloud.mydomain.net/nextcloud is works.
I think I solved it.
I ran the sudo -u www-data php /var/www/nextcloud/occ maintenance:update:htaccess and now it works.
I guess that I should have ran that update:htaccess before?
But thanks for Your replies and help with solving the issue.
I’m happy to hear it’s solved.
