Hey !
I have a problem with setting up a reverse proxy, I think it must be a small error but I don’t see where it comes from…
- I have a server with an Apache reverse proxy.
- It proxies to the server which carries nextcloud but I have a redirection loop (ERR_TOO_MANY_REDIRECTS)
- I would like to point out that it worked very well without the reverse proxy !
Nextcloud version : 27.1.7.2
OS : Ubuntu 22.04
Apache : 2.4.52
PHP version : 8.1.2-1ubuntu2.15
This is what I did :
Apache reverse proxy conf:
<VirtualHost *:80>
ServerName cloud.xxx.fr
Redirect permanent / https://cloud.xxx.fr/
</VirtualHost>
<VirtualHost *:443>
SSLEngine on
SSLCertificateFile /etc/letsencrypt/live/cloud.xxx.fr/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/cloud.xxx.fr/privkey.pem
<Location />
ProxyPass "http://192.168.1.194/"
ProxyPassReverse "http://192.168.1.194/"
ProxyPreserveHost On
RequestHeader set X-Forwarded-Proto "https"
</Location>
</VirtualHost>
Apache nextcloud conf :
Require all granted
AllowOverride All
Options FollowSymLinks MultiViews
<IfModule mod_dav.c>
Dav off
</IfModule>
</Directory>
<VirtualHost *:80>
DocumentRoot /var/www/nextcloud
Alias / "/var/www/nextcloud/"
Header always set Strict-Transport-Security "max-age=15552000; includeSubDomains"
<IfModule mod_rewrite.c>
RewriteEngine on
RewriteRule ^/\.well-known/carddav http://%{SERVER_NAME}/remote.php/dav [R=301,L]
RewriteRule ^/\.well-known/caldav http://%{SERVER_NAME}/remote.php/dav [R=301,L]
RewriteRule ^/\.well-known/webfinger http://%{SERVER_NAME}/index.php/.well-known/webfinger [R=301,L]
RewriteRule ^/\.well-known/nodeinfo http://%{SERVER_NAME}/index.php/.well-known/nodeinfo [R=301,L]
</IfModule>
Options -Indexes
AllowEncodedSlashes NoDecode
</VirtualHost>
Nextcloud conf :
?php
'instanceid' => 'xxxx',
'passwordsalt' => 'xxxxxx',
'secret' => 'xxxxxxx',
0 => '192.168.1.194',
1 => 'cloud.xxx.fr',
'trusted_proxies' => ['192.168.1.85'],
'overwritehost' => 'cloud.xxx.fr',
'overwritewebroot' => '/',
'overwritecondaddr' => '^192\.168\.0\.85$',
'overwrite.cli.url' => 'https://cloud.xxx.fr/',
'version' => '27.1.7.2',
'overwrite.cli.url' => 'https://cloud.xxx.fr',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'mat',
'dbpassword' => 'xxxxxxx',
'updater.secret' => 'xxxxxxxxx',
'theme' => '',
'loglevel' => 2,
If you know where this might come from, help would be greatly appreciated
