I am having difficulty restoring my ncp 1.53.2 instance from an nc-backup (including data), Please advise on what needs to be in place in order for a restore to complete successfully.
My situation is that my longtime external hdd failed, so I am restoring from a good backup (including data) .tar file that is about a month old.
Before running nc-restore, I re-built ncp by installing the downloaded 1.53.2 image, setting up the server, setting the datadir and database locations to the new HDD (SSD), enabling ssh, and installing a lets-encrypt certificate. However, I did not create the same nextcloud users, install the previous nextcloud apps, or perhaps other steps. I assumed that the restore would create the users apps and so on.
After running nc-restore, it appears that all the data is in place as expected, but the server does not start. The page served on port 443 reports Internal Server Error
, and the administration interface at port 4443 shows gibberish.
If I run sudo ncp-config
I see huge number of errors similar to:
tar: nextcloud: Cannot mkdir: No space left on device
despite that there is plenty of room on all of the filesystems (ie df -h
shows that no filesystem %use greater than 64%
My assumption is that I somehow did not properly prepare the server before doing the restore.
Do I need to create all the nextcloud users?
Do I need to install all the apps that I was using?
etc
Otherwise, what would be the steps necessary to restore an nc-backup file from one ncp instance to another.
Thanks for any help, and for a great project!
One other point to note is that in the logs I see a reference to automatic backups are enabled
, but there would not be enough space on the system to store a full backup. Is it possible that the system is trying to do an automatic backup and failing?
