Whilst trying to add certbot certification my instance no longer runs. When I try to connect I get server refused to connect.
Is there a way I can reset this config to restore access or do I need a fresh install?
Most liklely yes. But no one will be able to help you if you don’t provide any information about your system and your setup. Please use the issue template and try to provide as many information as possible. At least OS and webserver config is needed here to help…
Otherwise, you need to tag the thread “guessing game” and send a prize to whoever gets a hit…
