### Describe the bug
Since several weeks (sure enough more than 12) I can't acc…ess my personal contacts anymore. Neither via the WebUI (it just says "no contacts") nor via external Tools (like Outlook Sychronizer - it throws me a 500 error)
In the meanwhile I'v upgraded NC server to 22.2.4 (from .3) hoping that it would solve the problem. And I can't remember clearly if I had updated my contacts version to v4.0.7 or if it happend even with v4.0.6 - could be that this error took place under 4.0.6 as well.
Important notice: I CAN see my contacts if I'd click the contacts icon in menubar in upper right corner.
**To Reproduce**
right now everytime I goto the contacts-app section under my WebGUI I never see any contacts there. But I dunno what I did to make this happen.
### Server configuration
Operating system: Linux 5.4.0-92-generic #103-Ubuntu SMP Fri Nov 26 16:13:00 UTC 2021 x86_64
Webserver: Apache (fpm-fcgi)
Database: pgsql PostgreSQL 12.9 (Ubuntu 12.9-0ubuntu0.20.04.1) on x86_64-pc-linux-gnu, compiled by gcc (Ubuntu 9.3.0-17ubuntu1~20.04) 9.3.0, 64-bit
PHP version: 7.4.3
Modules loaded: Core, date, libxml, openssl, pcre, zlib, filter, hash, Reflection, SPL, session, standard, sodium, cgi-fcgi, PDO, xml, bcmath, bz2, calendar, ctype, curl, dom, mbstring, FFI, fileinfo, ftp, gd, gettext, gmp, iconv, igbinary, imap, intl, json, ldap, exif, pdo_pgsql, pgsql, Phar, posix, readline, redis, shmop, SimpleXML, smbclient, soap, sockets, sysvmsg, sysvsem, sysvshm, tokenizer, xmlreader, xmlwriter, xsl, zip, libsmbclient, Zend OPcache
Nextcloud version: 22.2.4 - 22.2.4.3
Updated from an older Nextcloud/ownCloud or fresh install: 22.0.3
Where did you install Nextcloud from: it's a VM from HanssonIT
<details><summary>Signing status</summary>
Array ( )
</details>
<details><summary>List of activated apps</summary>
- accessibility: 1.8.0
- activity: 2.15.0
- admin_audit: 1.12.0
- apporder: 0.14.0
- audioplayer: 3.2.4
- bbb: 2.2.0
- bookmarks: 10.0.3
- calendar: 3.0.5
- carnet: 0.24.4
- cloud_federation_api: 1.5.0
- cms_pico: 1.0.17
- comments: 1.12.0
- contacts: 4.0.7
- contactsinteraction: 1.3.0
- cookbook: 0.9.9
- dashboard: 7.2.0
- dav: 1.20.0
- deck: 1.5.5
- event_update_notification: 1.4.0
- federatedfilesharing: 1.12.0
- federation: 1.12.0
- files: 1.17.0
- files_downloadactivity: 1.12.0
- files_external: 1.13.1
- files_pdfviewer: 2.3.1
- files_rightclick: 1.1.0
- files_sharing: 1.14.0
- files_trackdownloads: 1.11.0
- files_videoplayer: 1.11.0
- group_default_quota: 0.1.3
- groupfolders: 10.0.2
- groupquota: 0.1.7
- impersonate: 1.9.0
- integration_dropbox: 1.0.4
- logreader: 2.7.0
- lookup_server_connector: 1.10.0
- maps: 0.1.10
- mediadc: 0.1.8
- metadata: 0.15.0
- nextcloud_announcements: 1.11.0
- notifications: 2.10.1
- notify_push: 0.3.0
- oauth2: 1.10.0
- password_policy: 1.12.0
- passwords: 2021.12.20
- phonetrack: 0.7.0
- photos: 1.4.0
- privacy: 1.6.0
- provisioning_api: 1.12.0
- quota_warning: 1.13.0
- rainloop: 7.1.3
- richdocuments: 4.2.4
- richdocumentscode: 21.11.103
- sendent: 1.2.10
- serverinfo: 1.12.0
- settings: 1.4.0
- sharebymail: 1.12.0
- side_menu: 2.3.3
- socialsharing_diaspora: 2.4.0
- socialsharing_email: 2.4.0
- socialsharing_facebook: 2.4.0
- socialsharing_twitter: 2.4.0
- spreed: 12.2.3
- support: 1.5.0
- suspicious_login: 4.1.0
- systemtags: 1.12.0
- text: 3.3.0
- theming: 1.13.0
- theming_customcss: 1.10.0
- twofactor_backupcodes: 1.11.0
- twofactor_webauthn: 0.2.15
- updatenotification: 1.12.0
- user_saml: 4.1.1
- video_converter: 1.0.4
- viewer: 1.6.0
- workflow_media_converter: 1.3.3
- workflow_ocr: 1.22.4
- workflow_pdf_converter: 1.7.0
- workflowengine: 2.4.0
- circles: 22.1.1
- encryption
- files_trashbin: 1.11.0
- files_versions: 1.14.0
- firstrunwizard: 2.11.0
- music: 1.5.1
- recommendations: 1.1.0
- survey_client: 1.10.0
- user_ldap
- user_status: 1.1.1
- weather_status: 1.1.0
</details>
<details><summary>Configuration (config/config.php)</summary>
"localhost",
"a.loc.al.ip",
"cloud.mydomain.tld",
"cloud.mydomain2.tld"
"dbtype": "pgsql",
"version": "22.2.4.3",
"overwrite.cli.url": "https:\/\/cloud.mydomain.tld\/",
"dbport": "",
"upgrade.disable-web": true,
"log_type": "file",
"logfile": "\/var\/log\/nextcloud\/nextcloud.log",
"loglevel": "2",
"log.condition": {
"apps": [
"admin_audit"
"mail_smtpmode": "smtp",
"remember_login_cookie_lifetime": "1800",
"log_rotate_size": "10485760",
"trashbin_retention_obligation": "auto, 60",
"versions_retention_obligation": "auto, 180",
"activity_expire_days": "120",
"filelocking.enabled": true,
"redis": {
"port": 0,
"timeout": 0.5,
"dbindex": 0,
"default_phone_region": "de",
"logtimezone": "Europe\/Berlin",
"default_language": "de",
"default_locale": "de_DE",
"allow_user_to_change_display_name": true,
"htaccess.RewriteBase": "\/",
"mail_sendmailmode": "smtp",
"mail_smtpport": "587",
"mail_smtpsecure": "tls",
"app.mail.verify-tls-peer": false,
"mail_smtpauthtype": "LOGIN",
"mail_smtpauth": 1,
"has_rebuilt_cache": true,
"trusted_proxies": "***REMOVED SENSITIVE VALUE***"
</details>
External storages: yes
<details><summary>External storage configuration</summary>
| Mount ID | Mount Point | Storage | Authentication Type | Configuration | Options | Applicable Users | Applicable Groups | Type |
| 4 | /Fotos | SMB/CIFS | Username and password | share: "osna\/Fotos", root: "", domain: "", show_hidden: false, check_acl: false, timeout: "", user: "dingdong", password: "***", host: "192.168.192.199" | readonly: false, enable_sharing: true | dongdong | | Personal |
| 2 | /extHDD/O-Drive | SMB/CIFS | Username and password | host: "internal ip", share: "osna\/users\/office", root: "", domain: "", show_hidden: true, check_acl: false, timeout: "", user: "dingdong", password: "***" | enable_sharing: true, readonly: false | dongdong | | Personal |
| 5 | /Fotos | SMB/CIFS | Username and password | host: "internal IP", share: "osna\/Fotos", root: "", domain: "", show_hidden: false, check_acl: false, timeout: "", user: "dingdong", password: "***" | enable_sharing: true, readonly: false | dingding | | Personal |
| 6 | /Fotos | SMB/CIFS | Username and password | host: "internal IP", share: "osna\/Fotos", root: "", domain: "", show_hidden: false, check_acl: false, timeout: "", user: "dingdong", password: "***" | enable_sharing: true, readonly: false | dingding | | Personal |
| 8 | /extHDD/N-Drive | Local | None | datadir: "\/mnt\/smbshares\/1" | readonly: true, enable_sharing: true | | admin, Benutzer | Admin |
</details>
Encryption: no
User-backends:
OC\User\Database
OCA\User_SAML\UserBackend
Talk configuration:
STUN servers
cloud.mydomain.tld:3478
TURN servers
turn:cloud.mydomain.tld:3478 - udp,tcp
Signaling servers (mode: internal):
no custom server configured
Browser: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:97.0) Gecko/20100101 Firefox/97.0
You can use the Issue Template application to prefill most of the required information: https://apps.nextcloud.com/apps/issuetemplate
Login as admin user into your Nextcloud and access
http://example.com/index.php/settings/integrity/failed
"No errors have been found"
### Logs
### Nextcloud log
<html><body>
Error | PHP | Allowed memory size of 536870912 bytes exhausted (tried to allocate 406881344 bytes) at /var/www/nextcloud/apps/dav/lib/CardDAV/CardDavBackend.php#972
</body>
</html>
Insert your Nextcloud log here
if there's some info missing pls don't hesitate and let me know so that I could add itr
