Hey, I’m running into a ton of issues. First issues I ran into and I wasn’t able to solve before I broke my nextcloud instance.
- Some files have not passed the integrity check. Further information on how to resolve this issue can be found in the [code-integrity). ([List of invalid files - INVALID_HASH - .htaccess - FILE_MISSING - .user.ini
- PHP configuration option output_buffering must be disabled
- The “Strict-Transport-Security” HTTP header is not set to at least “15552000” seconds. For enhanced security, it is recommended to enable HSTS as described in the security tips .
- Your web server is not properly set up to resolve “/.well-known/webfinger”. Further information can be found in the [documentation]p-well-known-URL).
- Your web server is not properly set up to resolve “/.well-known/nodeinfo”. Further information can be found in the [documentation]setup-well-known-URL).
- Your web server is not properly set up to resolve “/.well-known/caldav”. Further information can be found in the [documentation]?to=admin-setup-well-known-URL).
- Your web server is not properly set up to resolve “/.well-known/carddav”. Further information can be found in the documentation.
Also as i’m a noob and don’t really know much about htaccess, I went to /etc/apache2/sites-available/mydomain.net.conf also note I’m not actually using mydomain.net as I’m using a sub domain so I’m actually using subdomain.net
<VirtualHost *:443>
ServerName mydomainname
DocumentRoot /var/www/html/xbackbone/
SSLEngine on
RewriteEngine On
RewriteCond %{HTTPS} !=on
RewriteRule ^/?(.*) https://%{SERVER_NAME}/$1 [R,L]
SSLCertificateFile /etc/letsencrypt/live/domainname/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/domainname/privkey.pem
RewriteEngine on
RewriteRule ^.well-known/host-meta /var/www/sites/domainname/public.php?service=host-meta [QSA,L]
RewriteRule ^.well-known/host-meta.json /var/www/sites/domainname/public.php?service=host-meta-json [QSA,L]
RewriteRule ^.well-known/webfinger /var/www/sites/domainname/public.php?service=webfinger [QSA,L]
RewriteRule ^.well-known/carddav /var/www/sites/domainname/remote.php/dav [R=301,L]
RewriteRule ^.well-known/caldav /var/www/sites/domainname/remote.php/dav [R=301,L]
as well as adding ‘htaccess.RewriteBase’ => ‘/’, in the config of nextcloud and it still doesn’t work any idea?
Also now it just keeps refreshing ltself
every 2 seconds not letting me in oops
