Sorry to hear you’re facing problems ![]()
example
longer
example
here
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can ![]()
Nextcloud version (eg, 20.0.5): 26
Operating system and version (eg, Ubuntu 20.04): debian 10 lxc
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.38
PHP version (eg, 7.4): 8.0
I entered some commands to connect a zerotier adapter and now I can’t access the dashboard with its internal IP. It just says ‘error_connection_timed_out’. The container is up, and I even reintalled apache2. Any ideas how I can get web access back up?
Is this the first time you’ve seen this error? (Y/N): YES
I had this error when trying to connect zerotier and wasn’t getting an IP. the commands below fixed it and I have an zerotier IP and I can access the zerotier network now, but I lost access to the dashboard.
On proxmox:
nano /etc/pve/lxc/container.conf lxc.cgroup2.devices.allow: c 10:200 rwm
lxc.mount.entry: /dev/net/tun dev/net/tun none bind,create=file
On nextcloud container:
sudo mkdir /dev/net sudo mknod /dev/net/tun c 10 200
sudo chmod 666 /dev/net/tun
I deleted the node after I realized and it needed to be done on proxmox.
I then did a chown 10000:10000 /dev/net/tun on proxmox
and changed it to chown root:root /dev/net/tun in attempt to remedy the problem. On nextcloud debian container, ls -l /dev/net/tun shows
crw-rw-rw- 1 root root 10, 200
can't access dashboard
'passwordsalt' => '<salt>',
'secret' => '<secret>',
0 => 'localhost',
1 => '<domain for cloudflare tunnel>',
2 => '<internal ip>',
3 => '<internal ip other device>',
4 => '<zerotier network 1 ip>',
5 => '<zerotier network 2 ip>,
6 => '*',
'datadirectory' => '/var/www/nextcloud-data',
'version' => '26.0.5.1',
'overwrite.cli.url' => '<internal ip>',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextcloud',
'dbpassword' => '<dbpassword>',
'redis' =>
'host' => '/var/run/redis/redis.sock',
'port' => 0,
'timeout' => 0.0,
'instanceid' => '30d174180aa93',
'theme' => '',
'loglevel' => 2,
'app_install_overwrite' =>
0 => 'files_external_onedrive',
'twofactor_enforced' => 'true',
0 => 'admin',
'upload_max_filesize' => '0',
'max_filesize' => '0',
The output of your Apache/nginx/system log in /var/log/apache2/error.log:
[Wed Aug 16 16:27:12.557886 2023] [mpm_prefork:notice] [pid 353] AH00169: caught SIGTERM, shutting down
[Wed Aug 16 16:44:35.691370 2023] [ssl:warn] [pid 301] AH01909: localhost:443:0 server certificate does NOT include an ID which matches the server name
[Wed Aug 16 16:44:35.692423 2023] [ssl:warn] [pid 301] AH01909: localhost:12322:0 server certificate does NOT include an ID which matches the server name
[Wed Aug 16 16:44:35.785702 2023] [ssl:warn] [pid 406] AH01909: localhost:443:0 server certificate does NOT include an ID which matches the server name
[Wed Aug 16 16:44:35.786019 2023] [ssl:warn] [pid 406] AH01909: localhost:12322:0 server certificate does NOT include an ID which matches the server name
[Wed Aug 16 16:44:35.793690 2023] [mpm_prefork:notice] [pid 406] AH00163: Apache/2.4.38 (Debian) mod_fcgid/2.3.9 OpenSSL/1.1.1n configured -- resuming normal operations
[Wed Aug 16 16:44:35.793709 2023] [core:notice] [pid 406] AH00094: Command line: '/usr/sbin/apache2'
I had this error and tried some SSL certs to fix it. but couldn’t so i reinstalled apache2. The error.log says resuming normal operations.
Output errors in nextcloud.log in /var/www/ or as admin user in top right menu, filtering for errors. Use a pastebin service if necessary. I think this entry is old since it is dated 2 years ago.
{"reqId":"7W48fZ8iiJ0zjBr1gKLY","level":3,"time":"2021-04-15T23:37:02+00:00","remoteAddr":"","user":"admin","app":"no app in context","method":"","url":"--","message":{"Exception":"OCP\\AppFramework\\QueryException","Message":"Could not resolve trashManager! Class trashManager does not exist","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":126,"function":"resolve","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["trashManager"]},{"file":"/var/www/nextcloud/lib/private/ServerContainer.php","line":162,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["trashManager",true]},{"file":"/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":434,"function":"query","class":"OC\\ServerContainer","type":"->","args":["trashManager",true]},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":56,"function":"query","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->","args":["trashManager"]},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/FunctionInjector.php","line":58,"function":"get","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["trashManager"]},{"function":"OC\\AppFramework\\Bootstrap\\{closure}","class":"OC\\AppFramework\\Bootstrap\\FunctionInjector","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/FunctionInjector.php","line":68,"function":"array_map","args":[{"__class__":"Closure"},[{"name":"serverContainer","__class__":"ReflectionParameter"},{"name":"logger","__class__":"ReflectionParameter"},{"name":"appManager","__class__":"ReflectionParameter"},"*** sensitive parameter replaced ***"]]},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/BootContext.php","line":52,"function":"injectFn","class":"OC\\AppFramework\\Bootstrap\\FunctionInjector","type":"->","args":[[{"__class__":"OCA\\Files_Trashbin\\AppInfo\\Application"},"registerTrashBackends"]]},{"file":"/var/www/nextcloud/apps/files_trashbin/lib/AppInfo/Application.php","line":57,"function":"injectFn","class":"OC\\AppFramework\\Bootstrap\\BootContext","type":"->","args":[[{"__class__":"OCA\\Files_Trashbin\\AppInfo\\Application"},"registerTrashBackends"]]},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php","line":176,"function":"boot","class":"OCA\\Files_Trashbin\\AppInfo\\Application","type":"->","args":[{"__class__":"OC\\AppFramework\\Bootstrap\\BootContext"}]},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":197,"function":"bootApp","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->","args":["files_trashbin"]},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":137,"function":"loadApp","class":"OC_App","type":"::","args":["files_trashbin"]},{"file":"/var/www/nextcloud/apps/dav/lib/AppInfo/Application.php","line":124,"function":"loadApps","class":"OC_App","type":"::","args":[["dav"]]},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php","line":176,"function":"boot","class":"OCA\\DAV\\AppInfo\\Application","type":"->","args":[{"__class__":"OC\\AppFramework\\Bootstrap\\BootContext"}]},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":197,"function":"bootApp","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->","args":["dav"]},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":137,"function":"loadApp","class":"OC_App","type":"::","args":["dav"]},{"file":"/var/www/nextcloud/lib/private/legacy/OC_Util.php","line":203,"function":"loadApps","class":"OC_App","type":"::","args":[["filesystem"]]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":554,"function":"setupFS","class":"OC_Util","type":"::","args":["*** sensitive parameter replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":415,"function":"prepareUserLogin","class":"OC\\User\\Session","type":"->","args":[true,"*** sensitive parameter replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":624,"function":"completeLogin","class":"OC\\User\\Session","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":367,"function":"loginWithPassword","class":"OC\\User\\Session","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/Setup.php","line":440,"function":"login","class":"OC\\User\\Session","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/core/Command/Maintenance/Install.php","line":108,"function":"install","class":"OC\\Setup","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/symfony/console/Command/Command.php","line":255,"function":"execute","class":"OC\\Core\\Command\\Maintenance\\Install","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/nextcloud/3rdparty/symfony/console/Application.php","line":1009,"function":"run","class":"Symfony\\Component\\Console\\Command\\Command","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/nextcloud/3rdparty/symfony/console/Application.php","line":273,"function":"doRunCommand","class":"Symfony\\Component\\Console\\Application","type":"->","args":[{"__class__":"OC\\Core\\Command\\Maintenance\\Install"},{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/nextcloud/3rdparty/symfony/console/Application.php","line":149,"function":"doRun","class":"Symfony\\Component\\Console\\Application","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/nextcloud/lib/private/Console/Application.php","line":215,"function":"run","class":"Symfony\\Component\\Console\\Application","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/nextcloud/console.php","line":100,"function":"run","class":"OC\\Console\\Application","type":"->","args":[]},{"file":"/var/www/nextcloud/occ","line":11,"args":["/var/www/nextcloud/console.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","Line":115,"CustomMessage":"Could not boot files_trashbinCould not resolve trashManager! Class trashManager does not exist"},"userAgent":"--","version":"21.0.1.1"}
{"reqId":"7W48fZ8iiJ0zjBr1gKLY","level":3,"time":"2021-04-15T23:37:02+00:00","remoteAddr":"","user":"admin","app":"no app in context","method":"","url":"--","message":{"Exception":"OCP\\AppFramework\\QueryException","Message":"Could not resolve OCA\\Files_Versions\\Versions\\IVersionManager! Class can not be instantiated","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":126,"function":"resolve","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OCA\\Files_Versions\\Versions\\IVersionManager"]},{"file":"/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":459,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OCA\\Files_Versions\\Versions\\IVersionManager"]},{"file":"/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":431,"function":"queryNoFallback","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->","args":["OCA\\Files_Versions\\Versions\\IVersionManager"]},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":56,"function":"query","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->","args":["OCA\\Files_Versions\\Versions\\IVersionManager"]},{"file":"/var/www/nextcloud/apps/files_versions/lib/AppInfo/Application.php","line":121,"function":"get","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OCA\\Files_Versions\\Versions\\IVersionManager"]},{"file":"/var/www/nextcloud/apps/files_versions/lib/AppInfo/Application.php","line":108,"function":"loadBackend","class":"OCA\\Files_Versions\\AppInfo\\Application","type":"->","args":[{"@attributes":{"for":"OCP\\Files\\Storage\\IStorage"},"@value":"OCA\\Files_Versions\\Versions\\LegacyVersionsBackend"},{"__class__":"OC\\AppFramework\\DependencyInjection\\DIContainer"},{"__class__":"OC\\AppFramework\\Logger"}]},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/FunctionInjector.php","line":68,"function":"registerVersionBackends","class":"OCA\\Files_Versions\\AppInfo\\Application","type":"->","args":[{"__class__":"OC\\AppFramework\\DependencyInjection\\DIContainer"},{"__class__":"OC\\App\\AppManager"},{"__class__":"OC\\AppFramework\\Logger"}]},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/BootContext.php","line":52,"function":"injectFn","class":"OC\\AppFramework\\Bootstrap\\FunctionInjector","type":"->","args":[{"__class__":"Closure"}]},{"file":"/var/www/nextcloud/apps/files_versions/lib/AppInfo/Application.php","line":93,"function":"injectFn","class":"OC\\AppFramework\\Bootstrap\\BootContext","type":"->","args":[{"__class__":"Closure"}]},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php","line":176,"function":"boot","class":"OCA\\Files_Versions\\AppInfo\\Application","type":"->","args":[{"__class__":"OC\\AppFramework\\Bootstrap\\BootContext"}]},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":197,"function":"bootApp","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->","args":["files_versions"]},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":137,"function":"loadApp","class":"OC_App","type":"::","args":["files_versions"]},{"file":"/var/www/nextcloud/apps/dav/lib/AppInfo/Application.php","line":124,"function":"loadApps","class":"OC_App","type":"::","args":[["dav"]]},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php","line":176,"function":"boot","class":"OCA\\DAV\\AppInfo\\Application","type":"->","args":[{"__class__":"OC\\AppFramework\\Bootstrap\\BootContext"}]},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":197,"function":"bootApp","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->","args":["dav"]},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":137,"function":"loadApp","class":"OC_App","type":"::","args":["dav"]},{"file":"/var/www/nextcloud/lib/private/legacy/OC_Util.php","line":203,"function":"loadApps","class":"OC_App","type":"::","args":[["filesystem"]]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":554,"function":"setupFS","class":"OC_Util","type":"::","args":["*** sensitive parameter replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":415,"function":"prepareUserLogin","class":"OC\\User\\Session","type":"->","args":[true,"*** sensitive parameter replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":624,"function":"completeLogin","class":"OC\\User\\Session","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":367,"function":"loginWithPassword","class":"OC\\User\\Session","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/Setup.php","line":440,"function":"login","class":"OC\\User\\Session","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/core/Command/Maintenance/Install.php","line":108,"function":"install","class":"OC\\Setup","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/symfony/console/Command/Command.php","line":255,"function":"execute","class":"OC\\Core\\Command\\Maintenance\\Install","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/nextcloud/3rdparty/symfony/console/Application.php","line":1009,"function":"run","class":"Symfony\\Component\\Console\\Command\\Command","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/nextcloud/3rdparty/symfony/console/Application.php","line":273,"function":"doRunCommand","class":"Symfony\\Component\\Console\\Application","type":"->","args":[{"__class__":"OC\\Core\\Command\\Maintenance\\Install"},{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/nextcloud/3rdparty/symfony/console/Application.php","line":149,"function":"doRun","class":"Symfony\\Component\\Console\\Application","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/nextcloud/lib/private/Console/Application.php","line":215,"function":"run","class":"Symfony\\Component\\Console\\Application","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/nextcloud/console.php","line":100,"function":"run","class":"OC\\Console\\Application","type":"->","args":[]},{"file":"/var/www/nextcloud/occ","line":11,"args":["/var/www/nextcloud/console.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","Line":111,"CustomMessage":"Could not boot files_versionsCould not resolve OCA\\Files_Versions\\Versions\\IVersionManager! Class can not be instantiated"},"userAgent":"--","version":"21.0.1.1"}
