Reinstalled Nextcloud in /var/www/nextcloud but setup page won’t open, what I do now?
Not Found
The requested URL /nextcloud was not found on this server.
Apache/2.4.25 (Raspbian) Server at 192.168.2.10 Port 80
Not Found
By defaul the web-root directory is at /var/www/html
so you could try
mv /var/www/nextcloud /var/www/html/nextcloud
then your /nextcloud request should work
I suggest you follow a guide how to install Nextcloud on a Raspberry Pi if you still have problems.
This one should work for your Setup with Apache
@EV21 Yes, I know the default dir is /var/www/html but I need to install in /var/www to pass Host-Prefix in security scan. Moving the folder didn’t worked. If possible tell me what I should do most.
Edit: I can access the website. This topic is now solved.
