example
longer
example
here
Nextcloud version: 18.0.1-RC2
Operating system and version: Docker image nextcloud:18-rc-apache on Debian 9
PHP version: 7.3.14
I get the notification “Help improve Nextcloud” since NC 18.0. But when I try to answer by clicking on either one of the two buttons, I get the error message “Failed to perform action”.
Is this the first time you’ve seen this error? (Y/N): Since NC 18.0-RC, I see this message again and again.
- Click on the button “Notifications”
- Click on one of the two buttons of the message “Help improve Nextcloud”.
No related messages.
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'instanceid' => 'XXX',
'passwordsalt' => 'XXX',
'secret' => 'XXX',
0 => 'cloud-test.fwidmann.net',
'overwrite.cli.url' => 'https://cloud-test.fwidmann.net',
'dbtype' => 'pgsql',
'version' => '18.0.1.1',
'dbname' => 'nextcloud',
'dbhost' => 'db',
'dbtableprefix' => '',
'dbuser' => 'XXX',
'dbpassword' => 'XXX',
'loglevel' => 2,
'theme' => '',
'mail_from_address' => 'info',
'mail_smtpmode' => 'smtp',
'mail_domain' => 'XXX',
'mail_smtpauth' => 1,
'mail_smtphost' => 'XXX',
'mail_smtpport' => '587',
'mail_smtpname' => 'XXX',
'mail_smtppassword' => 'XXX',
'mail_smtpsecure' => 'tls',
'updater.release.channel' => 'beta',
'app_install_overwrite' =>
0 => 'drop_account',
'updater.secret' => 'XXX',
No related messages
