[help] Imaginary was not called
example
longer
example
here
Nextcloud version (eg, 29.0.5): Nextcloud Hub 8 (29.0.3)
Operating system and version (eg, Ubuntu 24.04): Debian 12.6
Apache or nginx version (eg, Apache 2.4.25): nginx 1.26.1
PHP version (eg, 8.3): 8.3.8
I have been using imaginary for Nextcloud preview for years. Recently after a couple migrations and several server upgrade, I have found that Nextcloud does not call imaginary for preview.
I installed Nextcloud and imaginary via docker. I am certain that the Nextcloud user abc can call imaginary and imaginary logs the calls as show below:
# docker exec -it -u 3008:5004 nextcloud bash
bash: /root/.bashrc: Permission denied
abc@cef674d6be6a:/$ id
uid=3008(abc) gid=5004(abc) groups=5004(abc)
abc@cef674d6be6a:/$ cd /mnt/logs
$ curl -O "http://imaginary:9000/crop?width=500&height=400&url=https://raw.githubusercontent.com/h2non/imaginary/master/testdata/large.jpg"
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100 38616  100 38616    0     0  51212      0 --:--:-- --:--:-- --:--:-- 51214
And the container log shows:
Imaginary has started
172.47.0.5 - - [06/Jul/2024 18:37:20] "GET /crop?width=500&height=400&url=https://raw.githubusercontent.com/h2non/imaginary/master/testdata/large.jpg HTTP/1.1" 200 38616 0.7436
However, when I opened folders with images on Nextcloud, no sign of imaginary being called.
Here is my compose.yaml:
services:
  imaginary:
    image: nextcloud/aio-imaginary:latest
    container_name: nextcloud-imaginary
    deploy:
      resources:
        limits:
          memory: 2G
    cap_add:
      - CAP_SYS_NICE
    environment:
       PORT: 9000
    command: -enable-url-source -concurrency 36 -log-level info
    restart: unless-stopped
  mariadb:
    image: "linuxserver/mariadb:latest"
    container_name: nextcloud-mariadb
    deploy:
      resources:
        limits:
          memory: 4G
    env_file:
      - ./secrets.env
    environment:
      - PUID=3008
      - PGID=5004
      - TZ=Europe/London
    volumes:
      - "./config:/config:rw"
      - "/mnt/nextcloud/mariadb/databases:/config/databases:rw"
      - "/mnt/nextcloud/mariadb/log:/config/log:rw"
      - "/mnt/logs/nc/mariadb:/mariadb/log:rw"
    ports:
      - "3306:3306"
  nextcloud:
    image: "linuxserver/nextcloud:latest"
    deploy:
      resources:
        limits:
          memory: 4G
    cap_add:
      - CAP_SYS_NICE
    environment:
      - PUID=3008
      - PGID=5004
      - TZ=Europe/London
      - DOCKER_MODS=linuxserver/mods:universal-cron
      - PHP_MEMORY_LIMIT=4G
    ports:
#      - "7443:443"
      - "1780:80"
    volumes:
      - type: tmpfs
        target: /tmp:exec
      - "./custom-cont-init.d:/custom-cont-init.d:ro"
      - "./custom-services.d:/custom-services.d:ro"
      - "./etc/watcher.ini:/etc/watcher.ini:ro"
      - "./etc/logrotate.d/watcher:/etc/logrotate.d/watcher:ro"
      - "./janus_bin:/janus_bin:r"  # bin directory for crontab
      - "/mnt/nextcloud/data:/data:rw"   # data directory
      - "/mnt/cctv:/mnt/cctv:rw"
      - "download:/mnt/download:rw"
      - "/mnt/infinityloop:/mnt/infinityloop:rw"
      - "/mnt/logs:/mnt/logs:rw"
      - "/mnt/media:/mnt/media:rw"
      - "/mnt/private:/mnt/private:rw"
    depends_on:
      imaginary:
        condition: service_started
        restart: false
      mariadb:
        restart: false
      redis:
        restart: false
  redis:
    image: "redis:latest"
    container_name: nextcloud-redis
    deploy:
      resources:
        limits:
          memory: 512M
    command: /usr/local/bin/redis-server /usr/local/etc/redis/redis.conf
    sysctls:
      - net.core.somaxconn=65535
    volumes:
      - "./config:/usr/local/etc/redis"
      - "redis-data:/data"
networks:
  default:
    ipam:
      config:
        - subnet: 172.47.0.0/16
          ip_range: 172.47.0.0/24
          gateway: 172.47.0.1
volumes:
  redis-data:
  download:
    external: true
How can I fix it?
Is this the first time you’ve seen this error? (Y):
  1. Install relevant containers
  2. upload some images to nextcloud
  3. browse those images on File pane
There was nothing logged while browsing the images at around 2024-07-06T20:07:59+00:00. The following were the show before and after the browsing.
{"reqId":"RgUgp2MqeLWVNtI23nJE","level":3,"time":"2024-07-06T19:17:56+00:00","remoteAddr":"","user":"--","app":"memories","method":"","url":"--","message":"Failed to index file /janus/files/infinityloop/Pix/수진/極品韓模수진大尺度私拍套圖 Korean Model 수진 [NSFW][1195P-6.71GB]/DSC_5061.JPG: No MIMEType in EXIF data","userAgent":"--","version":"29.0.3.4","data":{"app":"memories"},"id":"6689991874926"}
{"reqId":"pVEh1SEPCqqtfpWXhgZ3","level":0,"time":"2024-07-06T16:07:36+00:00","remoteAddr":"10.27.0.14","user":"janus","app":"logreader","method":"PUT","url":"/apps/logreader/api/settings","message":"Updating AppConfig: logLevel => 2","userAgent":"Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/126.0.0.0 Safari/537.36","version":"29.0.3.4","data":{"app":"logreader"},"id":"6689991874936"}
  'datadirectory' => '/data',
  'instanceid' => '[removed for security]',
  'passwordsalt' => '[removed for security]',
  'secret' => '[removed for security]',
  'version' => '29.0.3.4',
  'default_phone_region' => 'GB',
  'loglevel' => 0,
  'theme' => '',
  'filesystem_check_changes' => 0,
  'remember_login_cookie_lifetime' => 2592000,
  'session_lifetime' => 604800,
  'memories.exiftool' => '/config/www/nextcloud/apps/memories/bin-ext/exiftool-amd64-musl',
  'memories.vod.path' => '/config/www/nextcloud/apps/memories/bin-ext/go-vod-amd64',
  'memories.gis_type' => 1,
  'memories.db.triggers.fcu' => true,
  'dbname' => 'nextcloud',
  'dbhost' => 'mariadb:3306',
  'dbuser' => '[removed for security]',
  'dbpassword' => '[removed for security]',
    0 => '[removed for security]',
    1 => '[removed for security]',
    2 => '[removed for security]',
    3 => '[removed for security]',
  'trusted_proxies' =>
  'overwrite.cli.url' => '[removed for security]',
  'overwritehost' => '[removed for security]',
  'mail_smtpmode' => 'smtp',
  'mail_smtpsecure' => 'tls',
  'mail_domain' => '[removed for security]',
  'mail_smtpauth' => 1,
  'mail_smtphost' => 'smtp.gmail.com',
  'mail_smtpport' => '587',
  'mail_smtpname' => '[removed for security]',
  'mail_smtppassword' => '[removed for security]',
  'enable_previews' => true,
  'preview_concurrency_all' => 72,
  'preview_concurrency_new' => 36,
  'preview_max_x' => 4096,
  'preview_max_y' => 4096,
  'jpeg_quality' => 80,
  'preview_max_scale_factor' => 1,
  'preview_max_filesize_image' => 50,
  'preview_max_memory' => 256,
  'enabledPreviewProviders' =>
    0 => 'OC\\Preview\\BMP',
    1 => 'OC\\Preview\\GIF',
    2 => 'OC\\Preview\\JPEG',
    3 => 'OC\\Preview\\Krita',
    4 => 'OC\\Preview\\MarkDown',
    5 => 'OC\\Preview\\OpenDocument',
    6 => 'OC\\Preview\\PNG',
    7 => 'OC\\Preview\\TXT',
    8 => 'OC\\Preview\\XBitmap',
  'preview_imaginary_url' => 'http://imaginary:9000',
  'redis' =>
    'host' => 'redis',
    'port' => 6379,
    'timeout' => 1.5,
The images were browsed at around 2024-07-06T20:07:59+00:00.
error.log of nginx
There was nothing logged while browsing the images at around 2024-07-06T20:07:59+00:00. The following were the last line on nextcloud.log
{"reqId":"pVEh1SEPCqqtfpWXhgZ3","level":0,"time":"2024-07-06T16:07:36+00:00","remoteAddr":"10.27.0.14","user":"[removed for security]","app":"logreader","method":"PUT","url":"/apps/logreader/api/settings","message":"Updating AppConfig: logLevel => 2","userAgent":"Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/126.0.0.0 Safari/537.36","version":"29.0.3.4","data":{"app":"logreader"}}
I have further investigated. There was no logging message until I have changed the log level to debug. The following are a few lines of the log produced with log level set to debug when browsing image in Grid view.
  "reqId": "tfxsKHD3t6gHqdfmSCw9",
  "level": 0,
  "time": "2024-07-06T20:43:09+00:00",
  "remoteAddr": "10.27.0.14",
  "user": "janus",
  "app": "no app in context",
  "method": "GET",
  "url": "/core/preview?fileId=27268635&x=128&y=128&mimeFallback=true&a=0",
  "message": "dirty table reads: SELECT `filecache`.`fileid`, `storage`, `path`, `path_hash`, `filecache`.`parent`, `filecache`.`name`, `mimetype`, `mimepart`, `size`, `mtime`, `storage_mtime`, `encrypted`, `etag`, `filecache`.`permissions`, `checksum`, `unencrypted_size`, `metadata_etag`, `creation_time`, `upload_time`, `meta`.`json` AS `meta_json`, `meta`.`sync_token` AS `meta_sync_token` FROM `*PREFIX*filecache` `filecache` LEFT JOIN `*PREFIX*filecache_extended` `fe` ON `filecache`.`fileid` = `fe`.`fileid` LEFT JOIN `*PREFIX*files_metadata` `meta` ON `filecache`.`fileid` = `meta`.`file_id` WHERE (`storage` = :dcValue1) AND (`path_hash` = :dcValue2)",
  "userAgent": "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/126.0.0.0 Safari/537.36",
  "version": "29.0.3.4",
  "exception": {
    "Exception": "Exception",
    "Message": "dirty table reads: SELECT `filecache`.`fileid`, `storage`, `path`, `path_hash`, `filecache`.`parent`, `filecache`.`name`, `mimetype`, `mimepart`, `size`, `mtime`, `storage_mtime`, `encrypted`, `etag`, `filecache`.`permissions`, `checksum`, `unencrypted_size`, `metadata_etag`, `creation_time`, `upload_time`, `meta`.`json` AS `meta_json`, `meta`.`sync_token` AS `meta_sync_token` FROM `*PREFIX*filecache` `filecache` LEFT JOIN `*PREFIX*filecache_extended` `fe` ON `filecache`.`fileid` = `fe`.`fileid` LEFT JOIN `*PREFIX*files_metadata` `meta` ON `filecache`.`fileid` = `meta`.`file_id` WHERE (`storage` = :dcValue1) AND (`path_hash` = :dcValue2)",
    "Code": 0,
    "Trace": [
        "file": "/app/www/public/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php",
        "line": 344,
        "function": "executeQuery",
        "class": "OC\\DB\\Connection",
        "type": "->"
        "line": 384,
        "class": "Doctrine\\DBAL\\Query\\QueryBuilder",
        "type": "->"
        "file": "/app/www/public/lib/private/DB/QueryBuilder/QueryBuilder.php",
        "line": 280,
        "function": "execute",
        "type": "->"
        "file": "/app/www/public/lib/private/Files/Cache/Cache.php",
        "line": 164,
        "class": "OC\\DB\\QueryBuilder\\QueryBuilder",
        "type": "->"
        "file": "/app/www/public/lib/private/Files/View.php",
        "line": 1336,
        "function": "get",
        "class": "OC\\Files\\Cache\\Cache",
        "type": "->"
        "line": 1386,
        "function": "getCacheEntry",
        "class": "OC\\Files\\View",
        "type": "->"
        "file": "/app/www/public/lib/private/Files/Node/Node.php",
        "line": 108,
        "function": "getFileInfo",
        "type": "->"
        "line": 209,
        "class": "OC\\Files\\Node\\Node",
        "type": "->"
        "file": "/app/www/public/lib/private/Preview/Watcher.php",
        "line": 64,
        "function": "getId",
        "type": "->"
        "line": 54,
        "function": "deleteNode",
        "class": "OC\\Preview\\Watcher",
        "type": "->"
        "file": "/app/www/public/lib/private/Preview/WatcherConnector.php",
        "line": 62,
        "function": "postWrite",
        "type": "->"
        "function": "OC\\Preview\\{closure}",
        "class": "OC\\Preview\\WatcherConnector",
        "type": "->",
        "args": [
          "*** sensitive parameters replaced ***"
        "file": "/app/www/public/lib/private/Hooks/EmitterTrait.php",
        "line": 105,
        "function": "call_user_func_array"
        "file": "/app/www/public/lib/private/Hooks/PublicEmitter.php",
        "line": 40,
        "function": "emit",
        "class": "OC\\Hooks\\BasicEmitter",
        "type": "->"
        "file": "/app/www/public/lib/private/Files/Node/Root.php",
        "line": 150,
        "function": "emit",
        "class": "OC\\Hooks\\PublicEmitter",
        "type": "->"
        "line": 133,
        "function": "emit",
        "class": "OC\\Files\\Node\\Root",
        "type": "->"
        "file": "/app/www/public/lib/private/Files/Node/Folder.php",
        "line": 196,
        "function": "sendHooks",
        "type": "->"
        "file": "/app/www/public/lib/private/Files/SimpleFS/NewSimpleFile.php",
        "line": 121,
        "function": "newFile",
        "class": "OC\\Files\\Node\\Folder",
        "type": "->"
        "file": "/app/www/public/lib/private/Preview/Generator.php",
        "line": 561,
        "function": "putContent",
        "class": "OC\\Files\\SimpleFS\\NewSimpleFile",
        "type": "->"
        "line": 193,
        "function": "generatePreview",
        "class": "OC\\Preview\\Generator",
        "type": "->"
        "line": 110,
        "function": "generatePreviews",
        "type": "->"
        "file": "/app/www/public/lib/private/PreviewManager.php",
        "line": 187,
        "function": "getPreview",
        "type": "->"
        "file": "/app/www/public/core/Controller/PreviewController.php",
        "line": 174,
        "class": "OC\\PreviewManager",
        "type": "->"
        "line": 142,
        "function": "fetchPreview",
        "class": "OC\\Core\\Controller\\PreviewController",
        "type": "->"
        "file": "/app/www/public/lib/private/AppFramework/Http/Dispatcher.php",
        "line": 232,
        "function": "getPreviewByFileId",
        "type": "->"
        "line": 138,
        "function": "executeController",
        "class": "OC\\AppFramework\\Http\\Dispatcher",
        "type": "->"
        "file": "/app/www/public/lib/private/AppFramework/App.php",
        "line": 184,
        "function": "dispatch",
        "type": "->"
        "file": "/app/www/public/lib/private/Route/Router.php",
        "line": 338,
        "function": "main",
        "class": "OC\\AppFramework\\App",
        "type": "::"
        "file": "/app/www/public/lib/base.php",
        "line": 1050,
        "function": "match",
        "class": "OC\\Route\\Router",
        "type": "->"
        "file": "/app/www/public/index.php",
        "line": 49,
        "function": "handleRequest",
        "class": "OC",
        "type": "::"
    "File": "/app/www/public/lib/private/DB/Connection.php",
    "Line": 316,
    "tables": [
      "oc_filecache"
    "reads": [
      "oc_filecache",
      "oc_filecache_extended",
      "oc_files_metadata"
    "exception": {},
    "CustomMessage": "dirty table reads: SELECT `filecache`.`fileid`, `storage`, `path`, `path_hash`, `filecache`.`parent`, `filecache`.`name`, `mimetype`, `mimepart`, `size`, `mtime`, `storage_mtime`, `encrypted`, `etag`, `filecache`.`permissions`, `checksum`, `unencrypted_size`, `metadata_etag`, `creation_time`, `upload_time`, `meta`.`json` AS `meta_json`, `meta`.`sync_token` AS `meta_sync_token` FROM `*PREFIX*filecache` `filecache` LEFT JOIN `*PREFIX*filecache_extended` `fe` ON `filecache`.`fileid` = `fe`.`fileid` LEFT JOIN `*PREFIX*files_metadata` `meta` ON `filecache`.`fileid` = `meta`.`file_id` WHERE (`storage` = :dcValue1) AND (`path_hash` = :dcValue2)"
  "level": 0,
  "user": "janus",
  "method": "GET",
  "exception": {
    "Code": 0,
    "Trace": [
        "line": 344,
        "type": "->"
        "line": 384,
        "type": "->"
        "line": 280,
        "type": "->"
        "line": 164,
        "type": "->"
        "line": 1336,
        "function": "get",
        "type": "->"
        "line": 1386,
        "type": "->"
        "line": 208,
        "type": "->"
        "file": "/app/www/public/lib/private/Files/Node/LazyFolder.php",
        "line": 161,
        "function": "get",
        "type": "->"
        "file": "/app/www/public/lib/private/Files/AppData/AppData.php",
        "line": 132,
        "function": "get",
        "class": "OC\\Files\\Node\\LazyFolder",
        "type": "->"
        "file": "/app/www/public/lib/private/Preview/Storage/Root.php",
        "line": 48,
        "function": "getFolder",
        "class": "OC\\Files\\AppData\\AppData",
        "type": "->"
        "line": 67,
        "class": "OC\\Preview\\Storage\\Root",
        "type": "->"
        "line": 54,
        "type": "->"
        "line": 62,
        "type": "->"
        "type": "->",
        "args": [
        "line": 105,
        "line": 40,
        "function": "emit",
        "type": "->"
        "line": 150,
        "function": "emit",
        "type": "->"
        "line": 133,
        "function": "emit",
        "type": "->"
        "line": 196,
        "type": "->"
        "line": 121,
        "type": "->"
        "line": 561,
        "type": "->"
        "line": 193,
        "type": "->"
        "line": 110,
        "type": "->"
        "line": 187,
        "type": "->"
        "line": 174,
        "type": "->"
        "line": 142,
        "type": "->"
        "line": 232,
        "type": "->"
        "line": 138,
        "type": "->"
        "line": 184,
        "type": "->"
        "line": 338,
        "function": "main",
        "type": "::"
        "line": 1050,
        "type": "->"
        "line": 49,
        "class": "OC",
        "type": "::"
    "Line": 316,
    "tables": [
      "oc_filecache"
    "reads": [
      "oc_filecache",
      "oc_files_metadata"
    "exception": {},
  "reqId": "Gw5ulI0L7PBvpfGaTBy5",
  "level": 0,
  "user": "janus",
  "method": "GET",
  "url": "/core/preview?fileId=27268592&x=128&y=128&mimeFallback=true&a=0",
  "message": "dirty table reads: SELECT `path` FROM `*PREFIX*filecache` WHERE (`storage` = :dcValue1) AND (`fileid` = :dcValue2)",
  "exception": {
    "Message": "dirty table reads: SELECT `path` FROM `*PREFIX*filecache` WHERE (`storage` = :dcValue1) AND (`fileid` = :dcValue2)",
    "Code": 0,
    "Trace": [
        "line": 344,
        "type": "->"
        "line": 384,
        "type": "->"
        "line": 280,
        "type": "->"
        "line": 1102,
        "type": "->"
        "line": 419,
        "function": "getPathById",
        "type": "->"
        "file": "/app/www/public/lib/private/Files/Cache/Updater.php",
        "line": 264,
        "function": "update",
        "type": "->",
        "args": [
        "line": 145,
        "function": "correctParentStorageMtime",
        "class": "OC\\Files\\Cache\\Updater",
        "type": "->"
        "line": 298,
        "type": "->",
        "args": [
        "line": 1188,
        "function": "writeUpdate",
        "type": "->"
        "line": 683,
        "function": "basicOperation",
        "type": "->"
        "line": 188,
        "function": "file_put_contents",
        "type": "->"
        "line": 121,
        "type": "->"
        "line": 561,
        "type": "->"
        "line": 193,
        "type": "->"
        "line": 110,
        "type": "->"
        "line": 187,
        "type": "->"
        "line": 174,
        "type": "->"
        "line": 142,
        "type": "->"
        "line": 232,
        "type": "->"
        "line": 138,
        "type": "->"
        "line": 184,
        "type": "->"
        "line": 338,
        "function": "main",
        "type": "::"
        "line": 1050,
        "type": "->"
        "line": 49,
        "class": "OC",
        "type": "::"
    "Line": 316,
    "tables": [
      "oc_filecache"
    "reads": [
      "oc_filecache"
    "exception": {},
    "CustomMessage": "dirty table reads: SELECT `path` FROM `*PREFIX*filecache` WHERE (`storage` = :dcValue1) AND (`fileid` = :dcValue2)"
  "level": 0,
  "user": "janus",
  "method": "GET",
  "exception": {
    "Code": 0,
    "Trace": [
        "line": 344,
        "type": "->"
        "line": 384,
        "type": "->"
        "line": 280,
        "type": "->"
        "line": 164,
        "type": "->"
        "line": 1336,
        "function": "get",
        "type": "->"
        "line": 1386,
        "type": "->"
        "line": 108,
        "type": "->"
        "line": 209,
        "type": "->"
        "line": 64,
        "type": "->"
        "line": 54,
        "type": "->"
        "line": 62,
        "type": "->"
        "type": "->",
        "args": [
        "line": 105,
        "line": 40,
        "function": "emit",
        "type": "->"
        "line": 150,
        "function": "emit",
        "type": "->"
        "line": 133,
        "function": "emit",
        "type": "->"
        "line": 196,
        "type": "->"
        "line": 121,
        "type": "->"
        "line": 561,
        "type": "->"
        "line": 193,
        "type": "->"
        "line": 110,
        "type": "->"
        "line": 187,
        "type": "->"
        "line": 174,
        "type": "->"
        "line": 142,
        "type": "->"
        "line": 232,
        "type": "->"
        "line": 138,
        "type": "->"
        "line": 184,
        "type": "->"
        "line": 338,
        "function": "main",
        "type": "::"
        "line": 1050,
        "type": "->"
        "line": 49,
        "class": "OC",
        "type": "::"
    "Line": 316,
    "tables": [
      "oc_filecache"
    "reads": [
      "oc_filecache",
      "oc_files_metadata"
    "exception": {},
  "level": 0,
  "user": "janus",
  "method": "GET",
  "exception": {
    "Code": 0,
    "Trace": [
        "line": 344,
        "type": "->"
        "line": 384,
        "type": "->"
        "line": 280,
        "type": "->"
        "line": 164,
        "type": "->"
        "line": 1336,
        "function": "get",
        "type": "->"
        "line": 1386,
        "type": "->"
        "line": 208,
        "type": "->"
        "line": 161,
        "function": "get",
        "type": "->"
        "line": 132,
        "function": "get",
        "type": "->"
        "line": 48,
        "type": "->"
        "line": 67,
        "type": "->"
        "line": 54,
        "type": "->"
        "line": 62,
        "type": "->"
        "type": "->",
        "args": [
        "line": 105,
        "line": 40,
        "function": "emit",
        "type": "->"
        "line": 150,
        "function": "emit",
        "type": "->"
        "line": 133,
        "function": "emit",
        "type": "->"
        "line": 196,
        "type": "->"
        "line": 121,
        "type": "->"
        "line": 561,
        "type": "->"
        "line": 193,
        "type": "->"
        "line": 110,
        "type": "->"
        "line": 187,
        "type": "->"
        "line": 174,
        "type": "->"
        "line": 142,
        "type": "->"
        "line": 232,
        "type": "->"
        "line": 138,
        "type": "->"
        "line": 184,
        "type": "->"
        "line": 338,
        "function": "main",
        "type": "::"
        "line": 1050,
        "type": "->"
        "line": 49,
        "class": "OC",
        "type": "::"
    "Line": 316,
    "tables": [
      "oc_filecache"
    "reads": [
      "oc_filecache",
      "oc_files_metadata"
    "exception": {},
  "level": 0,
  "user": "janus",
  "method": "GET",
  "exception": {
    "Code": 0,
    "Trace": [
        "line": 344,
        "type": "->"
        "line": 384,
        "type": "->"
        "line": 280,
        "type": "->"
        "line": 164,
        "type": "->"
        "line": 1336,
        "function": "get",
        "type": "->"
        "line": 1386,
        "type": "->"
        "line": 208,
        "type": "->"
        "line": 161,
        "function": "get",
        "type": "->"
        "line": 132,
        "function": "get",
        "type": "->"
        "line": 57,
        "type": "->"
        "line": 67,
        "type": "->"
        "line": 54,
        "type": "->"
        "line": 62,
        "type": "->"
        "type": "->",
        "args": [
        "line": 105,
        "line": 40,
        "function": "emit",
        "type": "->"
        "line": 150,
        "function": "emit",
        "type": "->"
        "line": 133,
        "function": "emit",
        "type": "->"
        "line": 196,
        "type": "->"
        "line": 121,
        "type": "->"
        "line": 561,
        "type": "->"
        "line": 193,
        "type": "->"
        "line": 110,
        "type": "->"
        "line": 187,
        "type": "->"
        "line": 174,
        "type": "->"
        "line": 142,
        "type": "->"
        "line": 232,
        "type": "->"
        "line": 138,
        "type": "->"
        "line": 184,
        "type": "->"
        "line": 338,
        "function": "main",
        "type": "::"
        "line": 1050,
        "type": "->"
        "line": 49,
        "class": "OC",
        "type": "::"
    "Line": 316,
    "tables": [
      "oc_filecache"
    "reads": [
      "oc_filecache",
      "oc_files_metadata"
    "exception": {},
linuxserverio images sometimes have specialities I would recommend you consult linuxserver.io Nextcloud docs and reach out to linuxserver.io Support
Hi @janusng,
This is the reason:
That way, Imaginary will never be involved. You must explicitly enable it as the default Preview Provider. and since Imaginary supports the mimetypes: bmp, x-bitmap, png, jpeg, gif, heic, heif, svg+xml, tiff, webp, pdf and illustrator
… as you can see in the publicly available source code:
… you should remove the other Providers for those mimetypes that use imagemagick as backend.
So this would be the array as you need it to get imaginary to work:
    0 => 'OC\\Preview\\Imaginary',
    1 => 'OC\\Preview\\Krita',
    2 => 'OC\\Preview\\MarkDown',
    3 => 'OC\\Preview\\OpenDocument',
    4 => 'OC\\Preview\\TXT',
It is possible that it was not sufficiently documented when you activated it “for years” but this is nothing of a secret, it is documented well meanwhile on multiple places in the manual, so you could have known it. :wink:
Nextcloud is available as a gift, but not for free! The minimum compensation is the in-depth study of the documentation.
Much and good luck,
ernolf
Thanks a ton for the pointer. You are a life-saver! :pray:t3:
I do appreciate the effort of the people behind Nextcloud and other open source contributors. In fact, I have spent days and nights studying the document and many online materials.
With that being said, I was so stupid and overlooked that line. :flushed:
Strangely now imaginary keep crashing with calls from Nextcloud but not with the following command.
curl -O "http://192.168.0.99:9001/crop?width=500&height=400&url=https://raw.githubusercontent.com/h2non/imaginary/master/testdata/large.jpg"
I gotta investigate this new issue.:sob:
Could you provide the container log while crashing?
Does this message apear:
some font thing failed
ernolf
Thanks for your reply.
The following is the docker log:
/start.sh: line 8:     6 Killed                  imaginary -return-size -max-allowed-resolution 222.2 "$@"
Is there any other log I should look into?
As a reference, when called from the shell with the following command:
curl -O "http://10.27.0.50:9000/crop?width=500&height=400&url=https://raw.githubusercontent.com/h2non/imaginary/master/testdata/large.jpg"
The docker log looks like this:
10.27.0.14 - - [09/Jul/2024 14:20:40] "GET /crop?width=500&height=400&url=https://raw.githubusercontent.com/h2non/imaginary/master/testdata/large.jpg HTTP/1.1" 200 38616 0.3050
What is the output of
docker images
ernolf
# docker images
REPOSITORY                          TAG           IMAGE ID       CREATED         SIZE
ghcr.io/alexta69/metube             latest        6c643fd5699f   17 hours ago    294MB
linuxserver/tautulli                latest        f1dfae37c792   41 hours ago    180MB
linuxserver/prowlarr                latest        46640fd3e858   42 hours ago    178MB
linuxserver/radarr                  latest        975a5ca2e433   42 hours ago    201MB
linuxserver/sonarr                  latest        0b1a36d85e32   42 hours ago    199MB
linuxserver/lidarr                  latest        1539eea9d5db   42 hours ago    276MB
linuxserver/homeassistant           latest        b1deeafab346   4 days ago      1.45GB
linuxserver/bazarr                  latest        81a5ccc1bde0   4 days ago      427MB
nicolargo/glances                   latest-full   1aeaedfad210   5 days ago      271MB
linuxserver/nextcloud               latest        0e900fa1c6f6   7 days ago      988MB
linuxserver/mariadb                 latest        453704f906ee   7 days ago      334MB
ghcr.io/flaresolverr/flaresolverr   latest        9b9d9f3704a2   13 days ago     610MB
nextcloud/aio-imaginary             latest        a43ca3e9a1a2   2 weeks ago     114MB
mongo                               latest        95b3ba6bed35   6 weeks ago     797MB
redis                               latest        9c893be668ac   6 weeks ago     116MB
portainer/agent                     2.20.3        d7fadca55188   7 weeks ago     204MB
containrrr/watchtower               latest        e7dd50d07b86   8 months ago    14.7MB
smeagolworms4/mqtt-explorer         latest        7967f3bf4153   11 months ago   282MB
