In brief, I tried to follow the instruction on “how to allow the Nextcloud container to access directories on the host” from this link:
but instead of removing the mastercontainer, I removed the nextcloud-aio-nextcloud container. Shame on me!
so I then removed the mastercontainer, added the environment required to access external drive, and tried to redo the mastercontainer but it is failing now with this error in the log:
+ '[' -n '' ']'
+ set +x
Configuring Redis as session handler...
Appdata is not present. Did you maybe change the datadir after the initial Nextcloud installation? This is not supported!
See https://github.com/nextcloud/all-in-one#how-to-change-the-default-location-of-nextclouds-datadir
If you adjusted the datadir to be located on an external drive, make sure that the drive is still mounted!
In the datadir was found:
total 8
drwxr-x--- 2 www-data root 4096 Mar 6 10:07 .
drwxr-xr-x 1 root root 4096 Mar 6 10:06 ..
But I did not want to change the datadir (if I did). I only added an external drive.
My docker run command was:
sudo docker run
–sig-proxy=false
–name nextcloud-aio-mastercontainer
–restart always
–publish 80:80
–publish 8080:8080
–publish 8443:8443
–volume nextcloud_aio_mastercontainer:/mnt/docker-aio-config
–volume /var/run/docker.sock:/var/run/docker.sock:ro
–env NEXTCLOUD_MEMORY_LIMIT=1024M
–env NEXTCLOUD_DATADIR=“/USBdrive/nextcloud”
nextcloud/all-in-one:latest
I understood that I needed to add these 2 lines to be able to access the external drive:
–env NEXTCLOUD_MOUNT=“/mnt/”
–env NEXTCLOUD_MOUNT=“/media/” \
How can I correct my screw up?
