- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can. ![]()
Nextcloud Hub 10 (31.0.9)
Linux 6.6.44-production+truenas x86_64
nginx version: nginx/1.28.0
caddy v2.10.2
- PHP version (e.g, 8.3):
PHP 8.4.11
yes
I don't know
docker from image "linuxserver/nextcloud:latest"
no
I have just cleared all tags from recognize with command occ recognize:reset-tags. The tags shown on the WebUI Photos->Tags remain there, completed with previous photos as preview and incorrect photo counts. It presists after restart of the docker.
- get into command line and enter
occ recognize:clear-background-jobs - run
occ recognize:reset-tags - run
occ recognize:cleanup-tags - browse Nextcloud webUI Photos->Tags
PASTE
PASTE
PASTE HERE
"version": "31.0.9.1",
"overwriteprotocol": "https",
"default_phone_region": "GB",
"loglevel": 2,
"theme": "",
"filelocking.enabled": true,
"upgrade.disable-web": true,
"filesystem_check_changes": 0,
"remember_login_cookie_lifetime": 2592000,
"session_lifetime": 604800,
"memories.exiftool": "\/config\/www\/nextcloud\/apps\/memories\/bin-ext\/exiftool-amd64-musl",
"memories.vod.path": "\/config\/www\/nextcloud\/apps\/memories\/bin-ext\/go-vod-amd64",
"memories.gis_type": 1,
"dbtype": "mysql",
"dbport": "",
"mysql.utf8mb4": true,
"nc.chubbie.duckdns.org",
"nextcloud.chubbie.duckdns.org",
"nc.ng.home",
"nextcloud.ng.home"
"overwrite.cli.url": "https:\/\/nc.chubbie.duckdns.org",
"overwritehost": "nc.chubbie.duckdns.org",
"mail_smtpmode": "smtp",
"mail_smtpsecure": "tls",
"mail_sendmailmode": "smtp",
"mail_smtpauthtype": "LOGIN",
"mail_smtpauth": 1,
"mail_smtpport": "587",
"enable_previews": true,
"preview_concurrency_all": 72,
"preview_concurrency_new": 36,
"preview_max_x": 4096,
"preview_max_y": 4096,
"jpeg_quality": 80,
"preview_max_scale_factor": 1,
"preview_max_filesize_image": 50,
"preview_max_memory": 256,
"enabledPreviewProviders": [
"OC\\Preview\\Imaginary",
"OC\\Preview\\Krita",
"OC\\Preview\\MarkDown",
"OC\\Preview\\OpenDocument",
"OC\\Preview\\TXT",
"OC\\Preview\\Movie"
"redis": {
"port": 0
"app_install_overwrite": {
"1": "memories"
- activity: 4.0.0
- app_api: 5.0.2
- bruteforcesettings: 4.0.0
- circles: 31.0.0
- comments: 1.21.0
- contactsinteraction: 1.12.0
- dashboard: 7.11.0
- dav: 1.33.0
- external: 6.0.2
- federation: 1.21.0
- files: 2.3.1
- files_downloadlimit: 4.0.0
- files_external: 1.23.0
- files_pdfviewer: 4.0.0
- files_reminders: 1.4.0
- files_sharing: 1.23.1
- files_trashbin: 1.21.0
- files_versions: 1.24.0
- firstrunwizard: 4.0.0
- imageconverter: 2.0.5
- logreader: 4.0.0
- maps: 1.6.0
- memories: 7.6.2
- notifications: 4.0.0
- oauth2: 1.19.1
- password_policy: 3.0.0
- photos: 4.0.0
- privacy: 3.0.0
- profile: 1.0.0
- provisioning_api: 1.21.0
- recognize: 9.0.7
- recommendations: 4.0.0
- related_resources: 2.0.0
- serverinfo: 3.0.0
- settings: 1.14.0
- sharebymail: 1.21.0
- support: 3.0.0
- survey_client: 3.0.0
- suspicious_login: 9.0.1
- systemtags: 1.21.1
- text: 5.0.0
- theming: 2.6.1
- updatenotification: 1.21.0
- user_status: 1.11.0
- viewer: 4.0.0
- weather_status: 1.11.0
- webhook_listeners: 1.2.0
- workflowengine: 2.13.0
- admin_audit: 1.21.0
- encryption: 2.19.0
- files_inotify: 0.2.3 (installed 0.1.16)
- user_ldap: 1.22.0
- Use the
preformatted textformatting option in the editor for all log entries and configuration output. - If screenshots are useful, feel free to include them.
- If possible, also include key error output in text form so it can be searched for.
- Try to edit log output only minimally (if at all) so that it can be ran through analyzers / formatters by those trying to help you.
