31.0.4
Debian 12 inside Proxmox LXC
nginx 1.22.1
nginx proxy manager
- PHP version (e.g, 8.3):
8.2.28
No
From the moment the server was setup
Bare Metal on LXC container in Proxmox
No
[Uploads Bottlenecked to 6MB/s]
N/A (All it has is warnings related to uploads I started and cancelled)
"cloud.encodedbird.com"
"dbtype": "mysql",
"version": "31.0.4.1",
"overwritehost": "cloud.encodedbird.com",
"overwriteprotocol": "https",
"overwritecondaddr": "^10\\.0\\.0\\.2$",
"overwrite.cli.url": "https:\/\/cloud.encodedbird.com",
"dbport": "",
"mysql.utf8mb4": true,
"redis": {
"port": 6379,
"timeout": 0
"default_phone_region": "US",
"skeletondirectory": "",
"mail_smtpmode": "smtp",
"mail_smtpsecure": "ssl",
"mail_sendmailmode": "smtp",
"mail_smtpauth": true,
"mail_smtpport": "465",
"app_install_overwrite": []
/etc/nginx/sites-available/nextcloud.conf
https://cloud.encodedbird.com/s/qWYF4fpKHjJo2EL
php-fpm.conf
All comments except including pool.d/www.conf
php.ini
https://cloud.encodedbird.com/s/56Ktisii7ajzqzd
pool.d/www.conf
https://cloud.encodedbird.com/s/zCoEaawnixxar8b
Nginx Proxy Manager custom settings
client_body_buffer_size 2m;
proxy_read_timeout 86400s;
client_max_body_size 0;
proxy_buffering off;
proxy_request_buffering off;
- activity: 4.0.0
- app_api: 5.0.2
- appointments: 2.4.3
- bruteforcesettings: 4.0.0
- calendar: 5.2.2
- circles: 31.0.0
- comments: 1.21.0
- contacts: 7.0.6
- contactsinteraction: 1.12.0
- dashboard: 7.11.0
- dav: 1.33.0
- deck: 1.15.1
- federation: 1.21.0
- files: 2.3.1
- files_downloadlimit: 4.0.0
- files_pdfviewer: 4.0.0
- files_reminders: 1.4.0
- files_sharing: 1.23.1
- files_trashbin: 1.21.0
- files_versions: 1.24.0
- firstrunwizard: 4.0.0
- forms: 5.1.0
- logreader: 4.0.0
- notes: 4.12.0
- notifications: 4.0.0
- oauth2: 1.19.1
- password_policy: 3.0.0
- photos: 4.0.0-dev.1
- privacy: 3.0.0
- profile: 1.0.0
- provisioning_api: 1.21.0
- recommendations: 4.0.0
- related_resources: 2.0.0
- serverinfo: 3.0.0
- settings: 1.14.0
- sharebymail: 1.21.0
- support: 3.0.0
- survey_client: 3.0.0
- systemtags: 1.21.1
- tasks: 0.16.1
- text: 5.0.0
- theming: 2.6.1
- updatenotification: 1.21.0
- user_status: 1.11.0
- viewer: 4.0.0
- weather_status: 1.11.0
- webhook_listeners: 1.2.0
- workflowengine: 2.13.0
- admin_audit: 1.21.0
- encryption: 2.19.0
- files_external: 1.23.0
- suspicious_login: 9.0.1
- user_ldap: 1.22.0
Description
I am trying to get my nextcloud setup tuned with nginx on debian.
I confirmed that my bandwidth is not a factor and you can see speedtest results at Speedtest by Ookla - The Global Broadband Speed Test.
I have it tuned so that no warnings appear in the administration page. When doing downloads, I have it working at a clean 100MB/s.
When doing uploads via browser, it is bottlenecked to 6-8MB/s.
When doing uploads via WebDAV, it performs around the same.
I do not believe this is a duplicate of other tickets because most others I read demonstrated little understanding of the web server configuration and didn’t provide complete config information.
I can’t figure out where the bottleneck is
Things I tried already
- Increasing php.ini memory_limit to 1G or 2G. This had no effect.
- Enabling/Disabling http/2 in Nginx Proxy Manager. I find enabling it improves webdav performance, but otherwise it has no impact on max upload speed.
- Testing Chunked vs Unchunked using a public upload link in incognito mode.
- Tuning linux kernel TCP settings in hypervisor. This did help to achieve the high download speeds.
